ab1jx
Re: Official Touchscreen Display Questions
Tue Feb 20, 2018 4:09 am
JamesPi123 wrote:
Thu Apr 13, 2017 8:43 pm
billintad wrote:I think you are supposed to use "Recommended peripherals", but a forum dedicated to "screens" might be a good idea as there have been many threads about that topic.
The desktop display (startx) does go blank after a period of no input . It is immediately refreshed by just touching the screen. I suppose there must be a parameter somewhere that controls the length of time spent waiting for input. I haven't looked.
I have not experienced screen blanking when the command line is being used, but I don't use the command line for any length of time. I will just leave it running for a while and see what happens.
It's designed to stop screen burn-in, although it dosen't really happen anymore.
For blanking try this at a command line:
setterm --blank 0
It's at a lower level than X so it affects both. See the setterm man page. I used to spend hours getting just the right setup on xscreensaver but no matter how much I messed around in X the screen would shut off after 10 minutes. It comes from the kernel.
edit: well, neither xterm or rxvt supports blanking is the message I get, I thought it would apply to the whole screen. This is related to "cat /sys/module/kernel/parameters/consoleblank" which by default seems to be 600 (10 minutes). Good discussion of it at https://superuser.com/questions/152347/ ... g-behavior There's also a VESA powerdown interval, I'm not sure when that comes into play.
Oh, I just ordered one of the official LED displays after thinking about it for a year or so. I want to build a little tablet with some 18650 lithium cells powering it and an LM2596 switching regulator. I came to this FAQ because there's precious little info about the backlight, it's not mentioned in the PDF from Newark at all. I gather there is one but somebody wanted to know how you turn it off and got no answer. I'd like to know can I break out the lead to it and put a dimmer on it?
Oh, and LCDs aren't totally immune to screen burn. I used one once that had to be driven by AC. It would work on DC but after a while it turned black. The polarity had to be carefully reversed 50% of the time so you had to use an inverter. I know I've seen LCD TVs with screen burn from having something fixed on the screen for a long time, like a kiosk where they're on for years..
