bedtime
How to switch initial brightness?
Fri Jun 18, 2021 2:46 pm
Is there away that the brightness of the screen can be changed earlier in the boot process? I'd like to lower the brightness or even have the screen off until it is fully booted.
Re: How to switch initial brightness?
Fri Jun 18, 2021 2:53 pm
Not that I can think of.
Working in the Application's Team.
gordon77
Fri Jun 18, 2021 3:29 pm
How is the brightness controlled ?
If you can control it with a gpio could you use one that if off at boot ?
Fri Jun 18, 2021 4:23 pm
No, it's controlled from a I2C message to the display board on the screen, via the firmware and some mailboxes.
If you are using KMS (unlikely) then you could mod the driver to start up with 0 brightness.
gordon77
Fri Jun 18, 2021 4:39 pm
My mistake , l missed it was a pi official display.
Fri Jun 18, 2021 5:48 pm
You write a brightness value (0 to 255) to /sys/class/backlight/rpi_backlight/brightness. You can do that with a sudo echo command or with something like my code at https://github.com/DougieLawson/backlight_dimmer
Return to “Official Foundation Display”
