Virt-Pieter
[solved] Chromium in kiosk mode on 7" display: image & cursor are offscreen
Fri Jan 29, 2021 12:02 pm
Hi guys
I have an official 7" touchscreen with a RPi 3B+ and I'm trying to create a kiosk for my home automation.
I installed latest PI OS Lite, 64-bit image (need docker) and xorg + openbox + chromium.
So far this works fine but I have just 1 minor problem: the image is a little off screen, ~30pixels maybe.
Is there a way to solve this?
TIA, Pieter
stevenbowyer
Re: 7" touchscreen: kiosk => image a little bigger then display
Sat Jan 30, 2021 9:02 am
Have you had a look at the overscan settings in /boot/config.txt?
Virt-Pieter
Sat Jan 30, 2021 12:27 pm
Hi @stevenbowyer! thanks for this hint, didn't know where to begin.
I have enabled framebuffer_width & _height with the correct dimensions, that didn't make a difference.
Enabling the overscan_right (with a positive value) also didn't do anything.
As a test I have configured the left side with +100px and at the start of the boot process this setting is used/visible but during boot it gets auto corrected.
I just saw that these settings in config.txt explicitly mention "console"..
Now I'm searching in the direction of xserver (totally unknown terrain for me)
EDIT: it seems to be related to running chromium in kiosk mode.
Chromium also has display size switches and it's only when using the kiosk switch that the picture is off screen..
stevenbowyer
Sat Jan 30, 2021 1:37 pm
If it's only Chromium in kiosk mode that exhibits the issue, I would try either using a different browser (I believe firefox-esr now has a kiosk mode), or try Chromium in non kiosk mode and use different switches to force Chromium to a specific size and position (don't think.this can be done in kiosk mode).
Virt-Pieter
Re: Chromium in kiosk mode on 7" display: image & cursor are offscreen
Sat Jan 30, 2021 2:59 pm
You are right: it seems definitely to be related to using Chromium in kiosk mode... will try FF.
Do you, or anybody else, know if there are any other lightweight browsers that support kiosk mode?
The system will be only used to access the webUI of a local server, so security is not an issue.
stevenbowyer
Sat Jan 30, 2021 3:41 pm
Try looking at the options (the arguments section in particular) in post below before giving up on Chromium:
https://blog.r0b.io/post/minimal-rpi-kiosk/
Virt-Pieter
Sat Jan 30, 2021 10:12 pm
THANK YOU BIG TIME again @stevenbowyer!
That link with the chromium arguments was the solution.
I still had a problem with the cursor: the x value/distance seemed to be multiplied by 2.
By disabling (in /boot/config.txt):
#dtoverlay=vc4-fkms-v3d
#max_framebuffers=2
this also got solved
BTW: FF (is my preferred browser though) was not that straight forward at all
6by9
Sun Jan 31, 2021 8:35 am
#max_framebuffers=2
xinput for the touchscreen is largely independent of the display configuration.
DSI with no HDMI will enable the composite as a second screen. xinput then stretches the touch input across both display devices.
xinput map-to-output raspberrypi-ts DSI-1
or similar to associate it with only a single display device.
Virt-Pieter
Mon Feb 01, 2021 10:41 am
Thank you @6by9 for that info!
GeekFisher
Thu Jun 17, 2021 3:51 am
#max_framebuffers=2
I am having the same problem on a 3.5" touchscreen. Which flags did you use to correct your problem ?
Return to “Official Foundation Display”
