HermannSW
[SOLVED] RB-LCD-7P4-Case problems
Fri Dec 25, 2020 9:11 pm
I got real surprised by the Christmas presents from my adult children and wife (never stated to want this):
Official foundation display, RB-LCD-7P4-Case and Logitech K400+ wireless keyboard.
Today my older son and I tried to install my 8GB Pi4B and the display into the case according instructions:
https://joy-it.net/en/products/RB-LCD-7P4-Case
The instructions were good, but the case openings for USB-C, HDMI connectors and 3.5mm jack were completely wrong:
Only with force it was possible to get the power cable connected at all.
I thought on using my Dremel (will have to use that for CSI-2 camera cable anyway).
But found a simpler solution.
The <M3 screws that fixate Pi4B on standoffs were long enough.
I searched and found four M3 nuts, reopened the case, inserted between standoffs and Pi4B.
Now everything is where it should be -- unlikely that nuts were missing, since they are not mentioned in instructions:
(you can see one added nut left below USB-C PCB)
The fan is quite loud, and therefore I disconnected it for testing without.
With fan temperature rose from 37°C to only 54°C when running cpuburn-a53.
Perhaps I was a bit too used to using my Pi400 (same 37..54 range without fan), I did measure with cpuburn again.
Started with 41°C ... and ended with 80°C -- I had forgotton about that.
My Pi4B did hang on bookshelf before, with air on both sides, no fan needed.
In case the new case will turn out to be a real (not artificial cpubrun) heat problem, I will reopen and connect fan, but with an on/off switch on the outside.
The 3.5mm Jack was too near to case for my newer loudspeakers, but a very old one with bendable jack fits perfectly. After using raspi-config for Audio on 3.5mm jack, youtube video sound is good to hear:
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
HermannSW
Re: [SOLVED] RB-LCD-7P4-Case problems
Mon Jan 18, 2021 12:13 pm
First I used the display mostly with wireless keybord, lately with touch. While 7" display size is acceptable (I prefer 26$ in total 1024x600 9" HDMI no-touch display), with touch 800x480 is definitely too small display resolution. Even with wireless keyboard some gui software is unusable, when popups are much larger than 480 pixels vertically.
HermannSW
Sun Apr 11, 2021 7:47 pm
Sadly I am in hospital again. This time it was easy for my family to collect just my 8GB Pi4B in case with official display, K400+ keyboard dongle and keyboard as well as power supply. I got Pico+(DVI) and Arducam Pico4ML as well.
It turned out that the 800x480 is not that bad as I stated previously.
I need to read the Pico PDF documentation, and after I found out to click on the three horizontal bars to make the left contents menu disappear, documention is good to read just in browser.
I had turned off the (loud) fan, and saw temperature go above 80°C with cpuburn, but running "pico_setup.sh" reaches 69°C, but kept below 70°C.
With Logitech K400+ wireless keyboard I use the official display as display only, no use of touch functionality.
When back at home I will dremel away part of case to make GPIO pins accessible as in Pi400 -- now the case does not let me use UART connection to the Picos, but USB works.
aBUGSworstnightmare
Mon Apr 12, 2021 6:50 am
Gute Besserung!
You may want to try this viewtopic.php?f=140&p=1850254#p1850254 as it should give you 'some more pixels'. The 7in screen is DSI-1, so change the command.
Or change the framebuffer settings to 1024x614 when using legacy driver.
HermannSW
Mon Apr 19, 2021 9:19 pm
I found a better arrangement of Pi4B with official display and RB-LCD-7P4 case in hospital:
The hospital scissor does not only help as stand for Arducam Pico4ML (100% part of previous 16MP photo) ...
... but was a good tool for providing access to Pi4B GPIOs in absence of Dremel or other tools from home. With endurance I did drill holes into the case first with scissor, and then forced away bigger parts of acryllic case. The open part allows access to GND+GPIO14+GPIO15 I need for UART connection to Pico for adding networking over USB for Pico Micropython (REPL over UART)
viewtopic.php?f=146&t=309936
Only these pins are used from Pi4B for driving officila display:
display  Pi4B
GND      Pin14
5V       Pin2
SDA      Pin3
SCL      Pin5
P.S:
Really works:
viewtopic.php?f=146&p=1854481#p1854481
Return to “Official Foundation Display”
