fjordan2020
Touch was working after some long time stopped working
Mon Aug 24, 2020 5:15 pm
I have an official 7in touchscreen with Raspberry 3B and Raspbian; I assembled it about 2 years ago and it worked for a long time.
Then I left it unused for about 6 months.
Yesterday I turned it on again and the touch is not working anymore (the display still works ok).
Any ideas about what went wrong and what could I do to try to fix it?
Note: lsmod | grep -i FT shows rpi_ft5406... so I assume the touch controller is connected and working.
fjordan2020
Re: Touch was working after some long time stopped working
Tue Aug 25, 2020 6:42 am
PS: Just forgot to say that it also did not work with the new Raspberry OS and that it is assembled in a case and stayed upright during the “shelf” period.
alanmalk
Tue Oct 06, 2020 5:01 pm
Going to post a "Me Too" - with hope that someone can help.
Same setup as the OP. Touch was working for a few years but now only a fraction of the screen responds. There are a couple of "dead" areas that extend from left to right across the screen, about 1 inch high.
No changes to the code or pi system, just ignored the unit for a few months.
I pulled and re-seated the ribbon cable from screen to pi - both ends. Wiggled the very fragile looking brown ribbon that goes from front to the backside of the screen. I actually think this movement of ribbons made matters worse - getting a bad feeling.
knight_parn
Mon Oct 19, 2020 10:52 am
Same issue here.
The screen was bought back in 2016 and has been working fine for a long time. It was left un-used for about 2 months until yesterday. Now only the top 1/3 of the display works with the touch. I re-seated the ribbon cables but it didn't help. I also checked the front and back surface of the display control board, but no visible damage at all. I even swapped the rpi 4B 4GB with an old rpi 3B+ thinking the DSI port on the 4B might be broken, but the result remained the same.
Quchi
Sun Oct 25, 2020 2:07 pm
Same here
2 of them - stopped detecting large areas
1 no touch, the other only on (top right) a corner
Dussler
Tue Feb 23, 2021 10:48 am
Same here.
Is there a solutions right now?
Dussler
Wed Feb 24, 2021 9:30 am
Sorry for bothering, but is there a chance to get the touch working again?
This is the original Pi display! Is there no statement from the producer?
Thx
captainsemtex
Sat Mar 06, 2021 7:22 am
:( Another ME TOO.
My original 7" display has been in a Smarti Pi Touch case since purchase and previously worked but has been unused for a couple of years.
I am using it with a Pi3B and a 2.5A supply with the USB Y cable. The display itself works perfectly, but no touch... and there are no rainbow low power warnings.
I followed the tests at https://www.raspberrypi.org/documentati ... hooting.md.
When I enter:
dmesg | grep -i ft5406
there is *no* result. This is an obvious problem but it doesn't say anywhere how to fix this!?!
Also, when I enter:
cat /proc/cmdline | grep bcm2708_fb
I correctly get fbheight = 480 and fbwidth = 800.
But when I open Raspberry Pi Configuration and go to the Display tab and click "Set Resolution", it shows the default is 720x480 and there is no 800x480 option.
I am running the latest Raspbian and latest updates.
Return to “Official Foundation Display”
