gorunks2001
Pi4 + official Display calibration problem
Fri Nov 22, 2019 1:58 pm
Hi guys,
I need to calibrate the touch of the pi on a official 7' display, in vertical position. I use the screen utility to rotate, and I see DSI-1 & HDMI-1.
then is use this string :
#!/bin/bash
DISPLAY=:0.0 xinput --set-prop 'FT5406 memory based' 'Coordinate Transformation Matrix' 0 -1 1 1 0 0 0 0 1
With the Pi3 (display_rotate=3 ) works, and the touch is perfect.
with pi4, it works only on half screen because on the top I see the second desktop (hdmi-1) so I can't calibrate.
is there a way for solve this problem?
thanks
Re: Pi4 + official Display calibration problem
Fri Nov 22, 2019 4:26 pm
Drag the HDMI screen off the DSI screen using the screen config utility, does that help?
gorunks2001
Fri Nov 22, 2019 4:34 pm
unfortunately no :(
gorunks2001
Mon Nov 25, 2019 7:07 am
Any other have an idea for solve this problem?
thanks
gorunks2001
Tue Dec 03, 2019 6:53 am
Any other have this issue with the new pi4 ?
I need to solve this problem, because here in my country is a bit hard found the pi3, so now I need to use the pi4 in my factory.
Return to “Official Foundation Display”
