di11on
Dimensions of touchscreen without bezel?
Sun Aug 11, 2019 9:35 am
Hi folks,
Can anyone tell me the dimensions of the official touchscreen with the bezel removed?
Also, I presume it is easy enough to remove?
Thanks in advance
Re: Dimensions of touchscreen without bezel?
Sun Aug 11, 2019 11:43 am
Hi folks,
Thanks in advance
https://www.raspberrypi.org/documentati ... /README.md
Retired disgracefully.....
aBUGSworstnightmare
Sun Aug 11, 2019 12:03 pm
What is the bezel from your POV?
di11on
Sun Aug 11, 2019 10:47 pm
Thanks @fruitoftheloom - I had actually come across that drawing but somehow didn't notice that it gave the dimensions of the panel also.
I presume the bezel comes off easily enough? To answer @aBUGSworstnightmare - what I am referring to is the black plastic surround that defines the viewing area.
trejan
Sun Aug 11, 2019 11:10 pm
It isn't a plastic bezel. That black surround is on the reverse of the front glass which also has the capacitive touch layer on it. The actual LCD + backlight is sandwiched between that glass and the metal frame on the back.
Return to “Official Foundation Display”
