Schorschi
Anyway to reset a dtoverlay driver other than reboot?
Mon Aug 10, 2020 6:41 am
I am using dtoverlay method to read data from a bme280 sensor. This works, but once in a while, randomly, after several hours, issues result. For example, today I could read temperature and pressure from the bme280 sensor, but trying to read relative humidity from the bme280 sensor stopped working, and would return a remote IO error. No matter what I tried once the first failed relative humidity occurs I could not read the humidity value again. But reading temperature and pressure continued to work. My python code to read the same bme280 sensor, works for months without issue. But the dtoverlay method, only works for hours before issues, like noted above. The only way to clear the issue is to reboot the hardware, i.e. Pi? Is this true, or is there some way I can get the dtoverlay to reload, reapply, or whatever, to reset the sensor, i2c bus, whatever to avoid a reboot?
Re: Anyway to reset a dtoverlay driver other than reboot?
Mon Aug 10, 2020 7:44 am
You could try removing the overlay and then adding it back in again using the dtoverlay command. I can't guarantee it will work though.
rpdom@raspi12:~ $ dtoverlay -h
Usage:
  dtoverlay <overlay> [<param>=<val>...]
                           Add an overlay (with parameters)
  dtoverlay -D             Dry-run (prepare overlay, but don't apply -
                           save it as dry-run.dtbo)
  dtoverlay -r [<overlay>] Remove an overlay (by name, index or the last)
  dtoverlay -R [<overlay>] Remove from an overlay (by name, index or all)
  dtoverlay -l             List active overlays/params
  dtoverlay -a             List all overlays (marking the active)
  dtoverlay -h             Show this usage message
  dtoverlay -h <overlay>   Display help on an overlay
  dtoverlay -h <overlay> <param>..  Or its parameters
    where <overlay> is the name of an overlay or 'dtparam' for dtparams
Options applicable to most variants:
    -d <dir>        Specify an alternate location for the overlays
                    (defaults to /boot/overlays or /flash/overlays)
    -p <string>     Force a compatible string for the platform
    -v              Verbose operation
Adding or removing overlays and parameters requires root privileges.
Unreadable squiggle
6by9
Mon Aug 10, 2020 9:21 am
Note that you can only unload an overlay that was loaded with the dtoverlay command, not dtoverlay=<foo> in config.txt.
cleverca22
Mon Aug 10, 2020 9:25 am
you could check lsmod, find the driver for the bme280 sensor, then just unload with rmmod and reload with modprobe
Return to “Device Tree”
