Schorschi
Request adding additional sensors to dtoverlay sensor supported list?
Fri Aug 07, 2020 4:35 am
Request adding additional sensors to dtoverlay sensor supported list? The following sensors are requested to be added to the supported list of sensors via dtoverlay:
MPL115A2
MCP9808
AP3216
DS3231 AT24C32
HDC1080
BH1750FVI
TSL2561
TEMT6000
MAX31865
6by9
Re: Request adding additional sensors to dtoverlay sensor supported list?
Fri Aug 07, 2020 8:57 am
It's not rocket science, but it also doesn't happen by magic. There's also a requirement for drivers to exist in the kernel, and someone to have the hardware to test the overlays with.
Looking down your list, DS3231 is already supported via the i2c-rtc overlay. I haven't checked for the other ones.
MPL115A2 seems to be under drivers/iio/pressure/mpl115_i2c.c
MCP9808 is under drivers/hwmon/jc42.c
AP3216 I don't see.
AT24C32 is under drivers/i2c/i2c-slave-eeprom.c
HDC1080 is under drivers/iio/humidity/hdc100x.c
BH1750 is under drivers/iio/light/bh1750.c
TSL2561 is under drivers/iio/light/tsl2563.c
TEMT6000 I don't see.
MAX31865 I don't see.
I'm only looking at the 5.4 kernel, so drivers may have been added in later versions. In which case it may be possible to backport them.
Schorschi
Sun Aug 09, 2020 8:05 am
I can test most of these as needed if you need someone to help test. I am also familiar with C programming (not C# or C++)... which seems to be(coming) a lost art now? Other than when developing firmware images for ESP nodes (8266, 32, etc.) and Arduino micro controllers.
Return to “Device Tree”
