MrBool
dtoverlay disable from command line
Sat Sep 21, 2019 9:46 am
I use in my config.txt file
dtoverlay=mcp23017
Is possible to disable that dtoverlay from the command line?
I know that I can remove this line from config.txt but I need to disable it from the command line during test procedure and keep original config.txt
Re: dtoverlay disable from command line
Sat Sep 21, 2019 10:15 am
You can't do that.
The way to disable it is edit /boot/config.txt and change
dtoverlay=mcp23017
to
#dtoverlay=mcp23017
then reboot. To re-enable it reverse that change.
PhilE
Sat Sep 21, 2019 1:46 pm
Either my eyesight is failing or the after looks a lot like the before - should there have been a # comment character at the start of the edited version?
Sat Sep 21, 2019 1:55 pm
No comment.
:lol:
Unreadable squiggle
Sat Sep 21, 2019 6:34 pm
The postie delivered my new glasses this afternoon.
PhilE
Sat Sep 21, 2019 7:02 pm
Although you can't remove an overlay applied from config.txt, you could apply it at runtime instead which would then allow you to subsequently remove it.
Try the following:
1. Comment out the line in the config file and reboot.
2. Run "sudo dtoverlay mcp23017"
3. Verify that it works.
4. Run "sudo dtoverlay -r" to remove the most recent overlay.
5. Confirm that the functionality has been disabled.
N.B. Some subsystems don't react to runtime overlays being applied, but SPI and I2C should be okay.
Return to “Device Tree”
