Killertechno
USB to serial adapter: ttyUSBx identification?
Fri Apr 19, 2019 1:36 pm
Hi to all, I donìt know if this is correct section....
I'm using several devices with serial to USB bridge, so I have ttyUSB0, ttyUSB1, ttyUSB2, ttyUSB3, up to 8 ttyUSBx entries.
Here dmesg log:
[178399.675164] usbcore: registered new interface driver pl2303
[178399.675250] usbserial: USB Serial support registered for pl2303
[178399.675269] pl2303 1-1.1:1.0: pl2303 converter detected
[178399.681292] usb 1-1.1: pl2303 converter now attached to ttyUSB0
[178440.346398] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[178667.204867] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[178742.386178] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[178742.609318] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -19
[178742.609324] pl2303 ttyUSB0: error sending break = -19
[178742.609426] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[178742.609444] pl2303 1-1.1:1.0: device disconnected
To understand which device type I'm using I need to poll every ttyUSBx.
If I correctly remember I can program chip, so I would like to know if there is a way to tell linux to use specific desctiption for every ttyUSBx so I can detect specific device in dmesg?
PhilE
Re: USB to serial adapter: ttyUSBx identification?
Fri Apr 19, 2019 2:12 pm
This isn't really a Device Tree question, but I'll have a go at answering. FTDI adaptors have unique serial identifiers, and you can use udev to associate specific names with them. From https://gist.github.com/cbrake/4337154:
SUBSYSTEM=="tty", ATTRS{serial}=="FT4M9NIU", ENV{ID_USB_INTERFACE_NUM}=="00", SYMLINK+="ttyUSB_du"
SUBSYSTEM=="tty", ATTRS{serial}=="FT4M9NIU", ENV{ID_USB_INTERFACE_NUM}=="01", SYMLINK+="ttyUSB_redcloud"
SUBSYSTEM=="tty", ATTRS{serial}=="FT4M9NJ7", ENV{ID_USB_INTERFACE_NUM}=="00", SYMLINK+="ttyUSB_unused1"
SUBSYSTEM=="tty", ATTRS{serial}=="FT4M9NJ7", ENV{ID_USB_INTERFACE_NUM}=="01", SYMLINK+="ttyUSB_twister"
However, it sounds like your adaptors are Prolific pl2303 devices, and the same page says:
# single blue USB serial adapter, prolific devices don't seem to have a serial number that I can find
SUBSYSTEM=="tty", DRIVERS=="pl2303", SYMLINK+="ttyUSB_panda"
so you may be unlucky. I was going to suggest using the udevadm tool to look for a device-specific identifier of some kind, but someone else has already looked for (and failed to find) one. From https://stackoverflow.com/questions/544 ... e-in-linux:
i run:
udevadm info -a -n /dev/ttyUSB0
i get:
KERNELS=="1-2"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{authorized}=="1"
ATTRS{avoid_reset_quirk}=="0"
ATTRS{bConfigurationValue}=="1"
ATTRS{bDeviceClass}=="00"
ATTRS{bDeviceProtocol}=="00"
ATTRS{bDeviceSubClass}=="00"
ATTRS{bMaxPacketSize0}=="64"
ATTRS{bMaxPower}=="100mA"
ATTRS{bNumConfigurations}=="1"
ATTRS{bNumInterfaces}==" 1"
ATTRS{bcdDevice}=="0400"
ATTRS{bmAttributes}=="80"
ATTRS{busnum}=="1"
ATTRS{configuration}==""
ATTRS{devnum}=="27"
ATTRS{devpath}=="2"
ATTRS{idProduct}=="2303"
ATTRS{idVendor}=="067b"
ATTRS{ltm_capable}=="no"
ATTRS{manufacturer}=="Prolific Technology Inc. "
ATTRS{maxchild}=="0"
ATTRS{product}=="USB-Serial Controller D"
ATTRS{quirks}=="0x0"
ATTRS{removable}=="removable"
ATTRS{speed}=="12"
ATTRS{urbnum}=="20"
ATTRS{version}==" 1.10"
But no
ATTRS{serial}
scruss
Fri Apr 19, 2019 3:42 pm
pl2303s don't have serial numbers, as PhilE said. As long as you're not unplugging the cables and moving them around, /dev/serial/by-id/ or /dev/serial/by-path/ should stay the same over system restarts.
If you are unplugging the cables and moving them around on the Raspberry Pi, you really need to replace them with real FTDI cables. These give you constant locations in /dev/serial/by-id/
Return to “Device Tree”
