How to safely exit my program before KEY_POWER shutdown?
The gpio-shutdown overlay shuts down the system, but how can I monitor this KEY_POWER event and safely shuts down my own program (save import files) before the system shutdown?
- thagrol
- Contact: Website
Re: How to safely exit my program before KEY_POWER shutdown?
Given that AIUI all the overlay does is send a KEY_POWER event you'd do it the same way you'd trap a clean shutdown by any other means: trap a few signals and act on them.
The exact way you do that depends on which language your programme is written in.
Arguing with strangers on the internet since 1993.
Does it mean I won't be able to act upon the KEY_POWER event? If so can I register a system event and act on it, so I don't have to constantly monitor the gpio pin. I use c++ but has limited knowledge about Linux.thagrol wrote: Given that AIUI all the overlay does is send a KEY_POWER event you'd do it the same way you'd trap a clean shutdown by any other means: trap a few signals and act on them.
- thagrol
- Contact: Website
Can't help you with C++, I don't know it. My understanding is that when the switch is pressed the kernel sees a KEY_POWER event which triggers the normal shutdown process. You shouldn't need to monitor the gpio yourself, just have your programme trap and respond to a SIGTERM (I think it's SIGTERM, google will probably know).njsss wrote: ↑Mon Feb 25, 2019 7:28 pmDoes it mean I won't be able to act upon the KEY_POWER event? If so can I register a system event and act on it, so I don't have to constantly monitor the gpio pin. I use c++ but has limited knowledge about Linux.thagrol wrote: Given that AIUI all the overlay does is send a KEY_POWER event you'd do it the same way you'd trap a clean shutdown by any other means: trap a few signals and act on them.
- DougieLawson
- Contact: Website Twitter
Normal shutdown sends SIGTERM to every process. If the process doesn't end normally then 90s later it sends SIGKILL.
You can trap SIGTERM with a C++ signal handler. You can't trap SIGKILL.
https://www.tutorialspoint.com/cplusplu ... ndling.htm gives you an example of trapping signals.
You need to write a signal handler for your program. SIGTERM is the one you should take care of first.
ghans
ghans
I tried to implement a simple test in both c++ and python, but couldn't trap SIGTERM. Shutdown happens immediately either by pull the shutdown-pin down or just type "sudo shutdown now".
