GPCLK1 at GPIO42
Posted: Thu Sep 27, 2018 4:33 pm
by inac
Hello all,
We have a CM3 and try to enable the GPCLK1 at pin 42 with the 19.2MHz clock (or something else at > 16MHz).
In the config.txt I set the GPIO mux at ALT0 (GPCLK1)
gpio=42=a0
But the output stays low. Probably the clock source is not set right.
1) How can I set the clock source for GPCLK1 at 19.2MHz?
2) Is this pin shared with e.g. ETH can that cause problems?
Or maybe I missed some other things?
Kind regards
Re: GPCLK1 at GPIO42
Posted: Wed Oct 03, 2018 4:06 pm
by PhilE
Sorry I missed this one earlier.
Although the gpio directive will map the GPCLK1 function onto GPIO 42, it won't configure or start the clock. There isn't currently a way to do that in config.txt, so you have to fall back to using a custom dt-blob.bin - described here.
Posted: Mon Oct 08, 2018 3:27 pm
by inac
Nice to know. Is there more documentation about the configuration of the clock?
I added
     clock_setup
        [email protected] { freq = <19200000>; }; // Camera clock
     }; // clock_setup
That gives a clock but it's far from a nice block wave (but triangular). E.g. I see in https://pinout.xyz/pinout/gpclk# different clock sources but no idea how to set them via the dt-blob.dts. I also see things as
clock_routing {
   [email protected] { pll = "PLLA"; chan = "APER"; };
But how to set the fixed 19.2 clock at the output without PLL?
- Is there a way to set the e.g. output driver strength to get a better clock (block wave)?
- How to set the clock source?
I need a clock (fixed frequency somewhere between 15Mhz - 25MHz) of a block wave.
Posted: Thu Oct 11, 2018 8:55 am
by PhilE
The USB hub+Ethernet devices on most Pis use a 24/25MHz clock from GPCLK1 via GPIO 42, so the outputs are definitely capable of generating a usable clock. The dt-blob.dts format defines a "drive_strength_mA" property for each pin - you can see it being used in the default dt-blob source. However, the drive strength can only be set on a per-bank basis - the firmware calculates the maximum drive strength required by the pins in a bank and uses that value for the whole bank. There are 3 banks available - 0-27, 28-45 and 46-53 - and the drive strength can be set to 2, 4, 6, 8, 10, 12, 14 or 16mA; the default is 2mA.
Here's an extract of the 3B+ pin configuration:
            [email protected] { function = "pwm";    termination = "no_pulling"; drive_strength_mA = < 16 >; }; // Right audio
            [email protected] { function = "pwm";    termination = "no_pulling"; drive_strength_mA = < 16 >; }; // Left audio
            [email protected] { function = "gp_clk"; termination = "pull_down"; }; // ETH_CLK - Ethernet 25MHz output
            [email protected] { function = "gp_clk"; termination = "pull_down"; }; // WIFI_CLK - Wifi 32kHz output
You'll see that no drive strength is not set for ETH_CLK or WIFI_CLK, but both inherit the 16mA setting specified for the PWM pins in the same bank; you may find you can manage with less.
