epoch1970
I need clarification on pi3-act-led
Fri Sep 14, 2018 1:28 pm
I understand pi3-act-led gives control of the ACT led via GPIO: select a pin, connect your external led and it operates as the ACT led.
What I want to do is control (simple on/off would suffice) the built-in ACT led via GPIO. Is this possible?
Return to “Device Tree”
