ousan
Add new driver
Mon Aug 06, 2018 7:54 am
Hello Dear All,
I have linux experiences however I am new on Device tree. I want to add module to kernel and I have lots of research. I could not get clearly how I add driver to kernel.
In below link, there is the source code of what I want to add as driver. It seems, the driver is in linux kernel mainline. I can see the related driver when I open menuconfig. But I could not enable this module. How can I enable this module?
https://github.com/qca/qca7000
Re: Add new driver
Mon Aug 06, 2018 8:40 am
So, when you run menuconfig, you can see the driver, but when you press space, you don't get an <*>x or an <M>?
Which driver is it?
ousan
Re: Add new driver
Mon Aug 06, 2018 11:51 am
Actually, there is just explanation about the location of the driver when I search the kernel configuration by pressing "/" character.
Driver is qca7000. When I search the driver in menuconfig, it seems the driver is located on Device Drivers -> Network Device Support -> Ethernet Driver Support -> Qualcomm Devices.
However there is no QCA7000 device under Qualcomm Devices.
Re: Add new driver
Mon Aug 06, 2018 12:28 pm
Selecting the QCA7000 UART or SPI support seems to bring it in as a module.
ousan
Re: Add new driver
Mon Aug 06, 2018 12:32 pm
So, Should I try to write a dts file?
Re: Add new driver
Mon Aug 06, 2018 1:26 pm
You need to revbuild the kernel with those settings added. Not sure if you need any DT changes.
ousan
Re: Add new driver
Mon Aug 06, 2018 1:52 pm
So, if we assume we have to add a dts file, how can I do it? And also there is an explanation about adding the driver to device tree.
https://elixir.bootlin.com/linux/v4.17. ... ca7000.txt
Re: Add new driver
Mon Aug 06, 2018 2:41 pm
ousan
Re: Add new driver
Tue Aug 07, 2018 2:20 pm
Thank you for your sharing.
ousan
Re: Add new driver
Fri Aug 10, 2018 6:17 pm
I've found the overlay for qca7000 for raspberry pi in the (https://github.com/raspberrypi/linux/bl ... verlay.dts) link. It is already written.
And in "/boot/overlays/" there is qca7000.dtbo file. When I open it with fdtdump, it prints:
/dts-v1/;
// magic: 0xd00dfeed
// totalsize: 0x523 (1315)
// off_dt_struct: 0x38
// off_dt_strings: 0x454
// off_mem_rsvmap: 0x28
// version: 17
// last_comp_version: 16
// boot_cpuid_phys: 0x0
// size_dt_strings: 0xcf
// size_dt_struct: 0x41c
compatible = "brcm,bcm2708";
[email protected] {
target = <0xdeadbeef>;
__overlay__ {
#address-cells = <0x00000001>;
#size-cells = <0x00000000>;
status = "okay";
[email protected] {
status = "disabled";
[email protected] {
compatible = "qca,qca7000";
reg = <0x00000000>;
pinctrl-names = "default";
pinctrl-0 = <0x00000001>;
interrupt-parent = <0xdeadbeef>;
interrupts = <0x00000017 0x00000001>;
spi-max-frequency = <0x00b71b00>;
status = "okay";
phandle = <0x00000002>;
[email protected] {
__overlay__ {
eth1_pins {
brcm,pins = <0x00000017>;
brcm,function = <0x00000000>;
brcm,pull = <0x00000000>;
phandle = <0x00000001>;
__overrides__ {
int_pin = [00 00 00 02 69 6e 74 65 72 72 75 70 74 73 3a 30 00 00 00 00 01 62 72 63 6d 2c 70 69 6e 73 3a 30 00];
speed = <0x00000002 0x7370692d 0x6d61782d 0x66726571 0x75656e63 0x793a3000>;
__symbols__ {
eth1 = "/[email protected]/__overlay__/[email protected]";
eth1_pins = "/[email protected]/__overlay__/eth1_pins";
__local_fixups__ {
[email protected] {
__overlay__ {
[email protected] {
pinctrl-0 = <0x00000000>;
__overrides__ {
int_pin = <0x00000000 0x00000011>;
speed = <0x00000000>;
__fixups__ {
spi0 = "/[email protected]:target:0";
gpio = "/[email protected]/__overlay__/[email protected]:interrupt-parent:0", "/[email protected]:target:0";
I enable this overlay by typing "dtoverlay=qca7000" in /boot/config.txt as below:
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
dtoverlay=qca7000
Then I reboot the device. At the moment, I have 2 questions.
1) Do I need to resolve __fixups__ and __local_fixups__? If so, how?
2) How can I understand whether this module enabled or not? Do I need to do more things to use this driver?
Btw, when I print "sudo vcdbg log msg" I see below log,
001666.749: No kernel trailer - assuming DT-capable
001666.778: brfs: File read: 4579248 bytes
001671.744: brfs: File read: /mfs/sd/bcm2710-rpi-3-b.dtb
001671.769: Loading 'bcm2710-rpi-3-b.dtb' to 0x465fb0 size 0x44d8
001777.703: brfs: File read: 17624 bytes
001781.238: brfs: File read: /mfs/sd/config.txt
001781.768: dtparam: spi=on
001789.399: brfs: File read: 1667 bytes
001804.557: brfs: File read: /mfs/sd/overlays/qca7000.dtbo
001812.863: Loaded overlay 'qca7000'
001812.935: dtparam: audio=on
ousan
Re: Add new driver
Tue Aug 21, 2018 2:59 pm
Hello again,
I solved the problem just enable qca7000 overlay by updating /boot/config.txt
the qca7000 driver is already written and prepared to use.
Thank you for all reply
Return to “Device Tree”
