hardikharpal
SC16IS752 Interfacing Issue
Tue Apr 24, 2018 3:43 am
I am Interfacing SC16IS752(Custom Board) on SPI0 of raspberry pi.I have latest stretch lite version as on 24-April-2018.
I created dts file and generated dtbo file copied it to /boot/overlay. Also edited /boot/config.txt to load overlay.
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
        [email protected] {
        target = <&spidev0>;
        __overlay__ {
            status = "disabled";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        spi0_pins: spi0_pins {
                                brcm,pins = <9 10 11>;
                                brcm,function = <4>; /* alt 0 */
                        spi0_cs_pins: spi0_cs_pins {
                                brcm,pins = <8>;
                                brcm,function = <1>; /* output */
        [email protected] {
        target = <&spi0>;
        frag1: __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            pinctrl-names = "default";
            pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
            cs-gpios = <&gpio 8 1>;
            status = "okay";
            sc16is752: [email protected] {
                compatible = "nxp,sc16is752";
                reg = <0>; /* CE0 */
                clocks = <&sc16is752_clk>;
                interrupt-parent = <&gpio>;
                interrupts = <24 2>; /* IRQ_TYPE_EDGE_FALLING */
                gpio-controller;
                #gpio-cells = <2>;
                spi-max-frequency = <4000000>;
                sc16is752_clk: sc16is752_clk {
                   compatible = "fixed-clock";
                   #clock-cells = <0>;
                   clock-frequency = <14745600>;
        [email protected] {
                target = <&aux>;
                __overlay__ {
                        status = "okay";
    __overrides__ {
      int_pin = <&sc16is752>,"interrupts:0";
My problem is when open port on minicom . IRQ pin remains low for all time and UART communication not working.
Getting below message on dmesg .
[1293.489435] sc16is7xx spi0.0: ttySC0: Unexpected interrupt: 8
[ 1293.490328] sc16is7xx spi0.0: ttySC0: Unexpected interrupt: 0
[ 1293.490460] sc16is7xx spi0.0: ttySC0: Unexpected interrupt: 0
Getting bellow output for
sudo vcdbg log msg
002047.676: dtparam: spi=on
002062.027: brfs: File read: 1630 bytes
002075.726: brfs: File read: /mfs/sd/overlays/sc16is752-spi0.dtbo
002097.865: Loaded overlay 'sc16is752-spi0'
So I tried with SC16IS750(SparkFun Breakout Board ) which has one UART channel. I have connected to same pins on raspberry pi and made changes(just replaced sc16is752 with sc16is750) to dts file and generated dtbo file copied to /boot/overlay and edited /boot/config.txt to load overlay.
And It works perfectly able to send data and receive data.
Am I missing something ? Any Hint will be Helpful.
Thank you.
hardikharpal
Re: SC16IS752 Interfacing Issue
Tue Apr 24, 2018 12:01 pm
I read here https://raw.githubusercontent.com/janzt ... c16is7xx.c in that sc16is7xx_startup() one comment is there
/* ama 2016-12: fixed error message "unexpected interrupt: 8" in dmesg by added mdelay(1)
* without delay, after enabling the interrupts in IER, set_baud/set_termios is immediatly called,
* enables enhanced register ("config mode") with LCR = 0xBF and the first interrupt occurs at
* the same time, resulting in reading the IIR interrupt status register in the wrong mode.
* This problematic time window, from enabling the interrupts to handling them, is about 100µs, so a
* delay of 1000µs=1ms was choosen
mdelay(1);
But in case of raspberry pi driver for SC16IS7XX https://github.com/raspberrypi/linux/bl ... c16is7xx.c the delay is no there.
Do you think this is the cause of my issue?
Thanks and Regards,
Hardik Harpal
Return to “Device Tree”
