Failed to apply overlay
Posted: Thu Apr 05, 2018 9:56 pm
by uranusb
Hi everyone,
I am working on a project of CAN-FD based on mcp2517fd. Currently, I have modified the driver and recompiled the kernel. However, when I tried to apply the overlay, it keeps showing "Failed to apply overlay."
Following is the code of dtbo file for mcp2517fd:
 * Device tree overlay for mcp251x/can0 on spi0.0
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2835", "brcm,bcm2836", "brcm,bcm2708", "brcm,bcm2709";
    /* disable spi-dev for spi0.0 */
    [email protected] {
        target = <&spi0>;
        __overlay__ {
            status = "okay";
            [email protected]{
                status = "disabled";
    /* the interrupt pin of the can-controller */
    [email protected] {
        target = <&gpio>;
        __overlay__ {
            can0_pins: can0_pins {
                brcm,pins = <25>;
                brcm,function = <0>; /* input */
    /* the clock/oscillator of the can-controller */
    [email protected] {
        target-path = "/clocks";
        __overlay__ {
            /* external oscillator of mcp2517fd on SPI0.0 */
            can0_osc: can0_osc {
                compatible = "fixed-clock";
                #clock-cells = <0>;
                clock-frequency  = <16000000>;
    /* the spi config of the can-controller itself binding everything together */
    [email protected] {
        target = <&spi0>;
        __overlay__ {
            /* needed to avoid dtc warning */
            #address-cells = <1>;
            #size-cells = <0>;
            can0: [email protected] {
                reg = <0>;
                compatible = "microchip,mcp2517fd";
                pinctrl-names = "default";
                pinctrl-0 = <&can0_pins>;
                spi-max-frequency = <10000000>;
                interrupt-parent = <&gpio>;
                interrupts = <25 0x2>;
                clocks = <&can0_osc>;
    __overrides__ {
        oscillator = <&can0_osc>,"clock-frequency:0";
        spimaxfrequency = <&can0>,"spi-max-frequency:0";
        interrupt = <&can0_pins>,"brcm,pins:0",<&can0>,"interrupts:0";
Also, I checked the process with dmesg and it shows like following:
OF: overlay: Failed to apply single node @/soc/[email protected]/can0_pins
OF: overlay: apply failed '@/soc/[email protected]'
Failed to create overlay (err=-22)
I have no idea where is the problem. Can anyone show me how to solve this problem?
Thank you.
Re: Failed to apply overlay
Posted: Fri Apr 06, 2018 5:35 am
by PhilE
I am away from a Pi for the day but we can get started in the diagnosis.
At first sight the overlay looks OK. I see from the error messages that you are using the dtoverlay utility to load the overlay at runtime - have you tried from config.txt? If nothing else, the error reporting will be different - read the logging using "sudo vcdbg log msg".
Is it possible that a can0_pins node already exists? Look in /proc/device-tree to check, and try renaming that node in your overlay.
