urosg
RPI CM3 / GPIO27 as output - doesn't boot anymore
Sat Dec 09, 2017 8:25 am
I have made a simple DT overlay to use GPIO27 as output:
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835", "brcm,bcm2836", "brcm,bcm2708", "brcm,bcm2709", "brcm,bcm2710";
        part-number = "ugController";
        version = "0001";
        /* define GPIO27 as OUTPUT LOW to enable ETH controller */
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        ugcontroller: ugcontroller {
                                brcm,pins = <27>;
                                brcm,function = <1>;
                                brcm,pull = <1>;
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        pinctrl-names = "default";
                        pinctrl-0 = <&ugcontroller>;
                        status = "okay";
when this overlay is enabled the module doesn't boot, this are the last lines from the bootup:
[    1.851381] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.868838] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    1.885080] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.901852] of_cfs_init
[    1.906998] of_cfs_init: OK
[    1.912718] Waiting for root device /dev/mmcblk0p2...
[    2.006766] Indeed it is in host mode hprt0 = 00021501
[    2.103018] random: fast init done
[    2.206698] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.215809] Indeed it is in host mode hprt0 = 00001101
[    2.446953] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.456321] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.466927] hub 1-1:1.0: USB hub found
[    2.473401] hub 1-1:1.0: 5 ports detected
[    2.481547] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    2.498119] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    2.796696] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.926934] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.936568] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.949287] smsc95xx v1.0.5
[    3.040308] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6f:e7:fb
[    3.057273] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    3.074182] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected]7e00b200, deferring probe
I am at a loss here as the default state for this pin is INPUT so I really don't quite get what it has to do with the sdhost module.
Fortunately this pin is used for LAN9514 reset so it's not a show stopper at the moment if it doesn't work, but I would like to have it all enabled as designed.
Any help will be greatly appreciated.
Thanks!
PhilE
Re: RPI CM3 / GPIO27 as output - doesn't boot anymore
Sat Dec 09, 2017 8:56 am
Does changing the GPIO number to something else allow the board to boot?
PhilE
Sat Dec 09, 2017 9:30 am
My theory is that your overlay is interfering with the GPIO/pinctrl driver's operation, hence the warnings from multiple seemingly unconnected drivers.
Can you post the whole of the output from dmesg?
urosg
Sat Dec 09, 2017 7:05 pm
I did a little more browsing and I think that instead of an device overlay I need to define this in dt-blob as DT overlays are by my understanding (now) used as and underlying part for a device driver where-as plain GPIO which is not used by a device driver should be defined in dt-blob, should one need/want the pin configuration be set as soon as possible in the boot process.
BTW: there is no other output from the dmesg - i.e. can't even do a dmesg as the boot stops and this has been captured from the tty UART console hooked to the module and before these messages there is nothing that would show any more information regarding this, just plain old info.
PhilE
Sat Dec 09, 2017 8:56 pm
Yes, you could use dt-blob.bin to set a GPIO as an output, but then the question is how are you going to use it after that? GPIO27 pulls low from boot, so it will stay low until something switches it to an output and drives it high, and that should be a clean LOW-to-HIGH transition. dt-blob.bin is able to set this up quickest, followed by Device Tree, but this speed only matters if you want an early LOW-to-HIGH transition because the startup state will be LOW from boot regardless.
If you do decide to use dt-blob.bin, you may want to let the firmware reset the LAN9514 on your behalf (obviously that will depend on your application). In dt-blob.dts (the source for dt-blob.bin) you will find pins assigned to the role LAN_RUN. By default it is "absent" for a CM3 but you could set it to be GPIO27, configure it with suitable polarity, and let the firmware manage the reset.
You said you had included the last lines of the boot messages (which is the same kernel log as dmesg would show), so just include them all. Add "loglevel=8" to /boot/cmdline.txt to see all messages.
urosg
Sun Dec 10, 2017 3:20 am
This it the whole log when DT overlay enabled for GPIO27 and loglevel=8 added to cmdline.txt:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.35-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi Compute Module 3 Rev 1.0
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 80c6ee40, node_mem_map b9faa000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] percpu: Embedded 14 pages/cpu @b9f64000 s25600 r8192 d23552 u57344
[    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:6F:E7:FB vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=8
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 936296K/966656K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22168K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
[    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
[    0.000000]       .data : 0x80c00000 - 0x80c79014   ( 485 kB)
[    0.000000]        .bss : 0x80c7b000 - 0x80d3da64   ( 779 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000331] Console: colour dummy device 80x30
[    0.001450] console [tty1] enabled
[    0.001499] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001567] pid_max: default: 32768 minimum: 301
[    0.001929] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001971] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002991] Disabling cpuset control group subsystem
[    0.003180] CPU: Testing write buffer coherency: ok
[    0.003250] ftrace: allocating 22390 entries in 66 pages
[    0.056017] CPU0: update cpu_capacity 1024
[    0.056082] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.056187] Setting up static identity map for 0x100000 - 0x100034
[    0.058407] CPU1: update cpu_capacity 1024
[    0.058414] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.059133] CPU2: update cpu_capacity 1024
[    0.059139] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.059806] CPU3: update cpu_capacity 1024
[    0.059813] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.059896] Brought up 4 CPUs
[    0.060068] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.060098] CPU: All CPU(s) started in HYP mode.
[    0.060124] CPU: Virtualization extensions available.
[    0.060942] devtmpfs: initialized
[    0.071994] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.072315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072377] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.072939] pinctrl core: initialized pinctrl subsystem
[    0.073859] NET: Registered protocol family 16
[    0.076183] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.085109] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.085157] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.085332] Serial: AMBA PL011 UART driver
[    0.087352] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.156663] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[    0.158521] SCSI subsystem initialized
[    0.158696] usbcore: registered new interface driver usbfs
[    0.158804] usbcore: registered new interface driver hub
[    0.158921] usbcore: registered new device driver usb
[    0.165578] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[    0.167037] clocksource: Switched to clocksource arch_sys_counter
[    0.213888] VFS: Disk quotas dquot_6.6.0
[    0.213999] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.214226] FS-Cache: Loaded
[    0.214489] CacheFiles: Loaded
[    0.226718] NET: Registered protocol family 2
[    0.227656] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.227794] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.228005] TCP: Hash tables configured (established 8192 bind 8192)
[    0.228119] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.228186] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.228435] NET: Registered protocol family 1
[    0.228864] RPC: Registered named UNIX socket transport module.
[    0.228897] RPC: Registered udp transport module.
[    0.228925] RPC: Registered tcp transport module.
[    0.228952] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.229955] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.232255] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.248371] FS-Cache: Netfs 'nfs' registered for caching
[    0.249369] NFS: Registering the id_resolver key type
[    0.249419] Key type id_resolver registered
[    0.249447] Key type id_legacy registered
[    0.251887] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.252035] io scheduler noop registered
[    0.252065] io scheduler deadline registered (default)
[    0.252406] io scheduler cfq registered
[    0.252587] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    0.254519] BCM2708FB: allocated DMA memory fa910000
[    0.254572] BCM2708FB: allocated DMA channel 0 @ bb80f000
[    0.263265] Console: switching to colour frame buffer device 82x26
[    0.271784] bcm2835-rng 3f104000.rng: hwrng registered
[    0.274274] vc-cma: Videocore CMA driver
[    0.276711] vc-cma: vc_cma_base      = 0x00000000
[    0.279190] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.281543] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.283978] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.303495] brd: module loaded
[    0.314651] loop: module loaded
[    0.316823] Loading iSCSI transport class v2.0-870.
[    0.319607] usbcore: registered new interface driver smsc95xx
[    0.321835] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.552045] Core Release: 2.80a
[    0.554190] Setting default values for core params
[    0.556405] Finished setting default values for core params
[    0.759069] Using Buffer DMA mode
[    0.761238] Periodic Transfer Interrupt Enhancement - disabled
[    0.763414] Multiprocessor Interrupt Enhancement - disabled
[    0.765583] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.767805] Dedicated Tx FIFOs mode
[    0.770263] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[    0.774719] FIQ FSM acceleration enabled for :
[    0.774719] Non-periodic Split Transactions
[    0.774719] Periodic Split Transactions
[    0.774719] High-Speed Isochronous Endpoints
[    0.774719] Interrupt/Control Split Transaction hack enabled
[    0.786113] dwc_otg: Microframe scheduler enabled
[    0.788439] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058ef90
[    0.790806] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f300 length 36
[    0.793157] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb878000
[    0.795516] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.797857] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.800220] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.802572] Init: Port Power? op_state=1
[    0.804838] Init: Power Port (0)
[    0.807234] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.809547] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.811847] usb usb1: Product: DWC OTG Controller
[    0.814099] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
[    0.816403] usb usb1: SerialNumber: 3f980000.usb
[    0.819415] hub 1-0:1.0: USB hub found
[    0.821562] hub 1-0:1.0: 1 port detected
[    0.824261] dwc_otg: FIQ enabled
[    0.826303] dwc_otg: NAK holdoff enabled
[    0.828369] dwc_otg: FIQ split-transaction FSM enabled
[    0.830459] Module dwc_common_port init
[    0.832731] usbcore: registered new interface driver usb-storage
[    0.835075] mousedev: PS/2 mouse device common for all mice
[    0.838184] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.840659] bcm2835-cpufreq: min=600000 max=1200000
[    0.843249] sdhci: Secure Digital Host Controller Interface driver
[    0.845466] sdhci: Copyright(c) Pierre Ossman
[    0.847725] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    0.852408] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.855225] ledtrig-cpu: registered to indicate activity on CPUs
[    0.857712] hidraw: raw HID events driver (C) Jiri Kosina
[    0.860276] usbcore: registered new interface driver usbhid
[    0.862635] usbhid: USB HID core driver
[    0.865731] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[    0.869896] Initializing XFRM netlink socket
[    0.872352] NET: Registered protocol family 17
[    0.874921] Key type dns_resolver registered
[    0.877849] Registering SWP/SWPB emulation handler
[    0.881149] registered taskstats version 1
[    0.884061] vc-sm: Videocore shared memory driver
[    0.886588] [vc_sm_connected_init]: start
[    0.889539] [vc_sm_connected_init]: end - returning 0
[    0.897160] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.912428] console [ttyAMA0] enabled
[    1.918962] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.936423] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    1.952665] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.969455] of_cfs_init
[    1.974532] of_cfs_init: OK
[    1.980356] Waiting for root device /dev/mmcblk0p2...
[    2.077138] Indeed it is in host mode hprt0 = 00021501
[    2.173398] random: fast init done
[    2.277068] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.286186] Indeed it is in host mode hprt0 = 00001101
[    2.517315] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.526685] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.537290] hub 1-1:1.0: USB hub found
[    2.543765] hub 1-1:1.0: 5 ports detected
[    2.551871] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    2.568445] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    2.867065] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.997309] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.006946] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.019678] smsc95xx v1.0.5
[    3.110666] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6f:e7:fb
[    3.127629] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    3.144543] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
after changing the DT overlay to modify GPIO26 the log output looks the same to me:
[    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000026] Switching to timer-based delay loop, resolution 52ns
[    0.000333] Console: colour dummy device 80x30
[    0.001453] console [tty1] enabled
[    0.001501] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001571] pid_max: default: 32768 minimum: 301
[    0.001928] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002997] Disabling cpuset control group subsystem
[    0.003186] CPU: Testing write buffer coherency: ok
[    0.003255] ftrace: allocating 22390 entries in 66 pages
[    0.056022] CPU0: update cpu_capacity 1024
[    0.056088] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.056192] Setting up static identity map for 0x100000 - 0x100034
[    0.058400] CPU1: update cpu_capacity 1024
[    0.058408] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.059128] CPU2: update cpu_capacity 1024
[    0.059135] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.059801] CPU3: update cpu_capacity 1024
[    0.059808] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.059892] Brought up 4 CPUs
[    0.060064] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.060093] CPU: All CPU(s) started in HYP mode.
[    0.060120] CPU: Virtualization extensions available.
[    0.060938] devtmpfs: initialized
[    0.072001] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.072322] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072384] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.072945] pinctrl core: initialized pinctrl subsystem
[    0.073863] NET: Registered protocol family 16
[    0.076187] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.085103] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.085152] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.085327] Serial: AMBA PL011 UART driver
[    0.087349] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.156641] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[    0.158496] SCSI subsystem initialized
[    0.158671] usbcore: registered new interface driver usbfs
[    0.158779] usbcore: registered new interface driver hub
[    0.158895] usbcore: registered new device driver usb
[    0.165574] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[    0.167029] clocksource: Switched to clocksource arch_sys_counter
[    0.213880] VFS: Disk quotas dquot_6.6.0
[    0.213992] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.214220] FS-Cache: Loaded
[    0.214483] CacheFiles: Loaded
[    0.226682] NET: Registered protocol family 2
[    0.227613] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.227751] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.227962] TCP: Hash tables configured (established 8192 bind 8192)
[    0.228074] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.228141] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.228390] NET: Registered protocol family 1
[    0.228823] RPC: Registered named UNIX socket transport module.
[    0.228855] RPC: Registered udp transport module.
[    0.228883] RPC: Registered tcp transport module.
[    0.228910] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.229920] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.232223] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.248342] FS-Cache: Netfs 'nfs' registered for caching
[    0.249339] NFS: Registering the id_resolver key type
[    0.249389] Key type id_resolver registered
[    0.249417] Key type id_legacy registered
[    0.251859] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.252019] io scheduler noop registered
[    0.252049] io scheduler deadline registered (default)
[    0.252390] io scheduler cfq registered
[    0.252568] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    0.254523] BCM2708FB: allocated DMA memory fa910000
[    0.254575] BCM2708FB: allocated DMA channel 0 @ bb80f000
[    0.263266] Console: switching to colour frame buffer device 82x26
[    0.271795] bcm2835-rng 3f104000.rng: hwrng registered
[    0.274288] vc-cma: Videocore CMA driver
[    0.276733] vc-cma: vc_cma_base      = 0x00000000
[    0.279214] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.281573] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.284010] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.303556] brd: module loaded
[    0.314689] loop: module loaded
[    0.316870] Loading iSCSI transport class v2.0-870.
[    0.319658] usbcore: registered new interface driver smsc95xx
[    0.321888] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.552102] Core Release: 2.80a
[    0.554246] Setting default values for core params
[    0.556464] Finished setting default values for core params
[    0.759095] Using Buffer DMA mode
[    0.761265] Periodic Transfer Interrupt Enhancement - disabled
[    0.763442] Multiprocessor Interrupt Enhancement - disabled
[    0.765612] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.767835] Dedicated Tx FIFOs mode
[    0.770288] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[    0.774738] FIQ FSM acceleration enabled for :
[    0.774738] Non-periodic Split Transactions
[    0.774738] Periodic Split Transactions
[    0.774738] High-Speed Isochronous Endpoints
[    0.774738] Interrupt/Control Split Transaction hack enabled
[    0.786110] dwc_otg: Microframe scheduler enabled
[    0.788429] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058ef90
[    0.790794] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f300 length 36
[    0.793142] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb878000
[    0.795499] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.797839] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.800197] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.802541] Init: Port Power? op_state=1
[    0.804800] Init: Power Port (0)
[    0.807236] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.809548] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.811846] usb usb1: Product: DWC OTG Controller
[    0.814100] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
[    0.816406] usb usb1: SerialNumber: 3f980000.usb
[    0.819405] hub 1-0:1.0: USB hub found
[    0.821553] hub 1-0:1.0: 1 port detected
[    0.824251] dwc_otg: FIQ enabled
[    0.826291] dwc_otg: NAK holdoff enabled
[    0.828356] dwc_otg: FIQ split-transaction FSM enabled
[    0.830440] Module dwc_common_port init
[    0.832706] usbcore: registered new interface driver usb-storage
[    0.835045] mousedev: PS/2 mouse device common for all mice
[    0.838126] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.840599] bcm2835-cpufreq: min=600000 max=1200000
[    0.843190] sdhci: Secure Digital Host Controller Interface driver
[    0.845408] sdhci: Copyright(c) Pierre Ossman
[    0.847673] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    0.852362] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.855169] ledtrig-cpu: registered to indicate activity on CPUs
[    0.857668] hidraw: raw HID events driver (C) Jiri Kosina
[    0.860221] usbcore: registered new interface driver usbhid
[    0.862579] usbhid: USB HID core driver
[    0.865654] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[    0.869794] Initializing XFRM netlink socket
[    0.872248] NET: Registered protocol family 17
[    0.874822] Key type dns_resolver registered
[    0.877765] Registering SWP/SWPB emulation handler
[    0.881025] registered taskstats version 1
[    0.883934] vc-sm: Videocore shared memory driver
[    0.886462] [vc_sm_connected_init]: start
[    0.889404] [vc_sm_connected_init]: end - returning 0
[    0.896974] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.912273] console [ttyAMA0] enabled
[    1.918732] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.936170] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    1.952405] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    1.969146] of_cfs_init
[    1.974206] of_cfs_init: OK
[    1.980087] Waiting for root device /dev/mmcblk0p2...
[    2.087131] Indeed it is in host mode hprt0 = 00021501
[    2.183386] random: fast init done
[    2.287061] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.296196] Indeed it is in host mode hprt0 = 00001101
[    2.527317] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.536708] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.547323] hub 1-1:1.0: USB hub found
[    2.553820] hub 1-1:1.0: 5 ports detected
[    2.562026] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    2.578643] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
[    2.877060] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.007304] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.016965] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.029737] smsc95xx v1.0.5
[    3.130699] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6f:e7:fb
[    3.147705] sdhost-bcm2835 3f202000.sdhost: could not find pctldev for node /soc/[email protected]/sdhost_pins, deferring probe
[    3.164668] pinctrl-bcm2835 3f200000.gpio: could not find pctldev for node /soc/[email protected], deferring probe
the changed DTS is
/dts-v1/;
/plugin/;
        version = "0001";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                                brcm,pins = <26>;
                                brcm,pull = <1>;
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        status = "okay";
Thanks for the direction for the LAN_RUN pin.
One more question about dt-blob.bin, I assume that if it is not present then a default one is loaded from firmware, I do however am wondering if there is a way to "include" a subset of dt-blob.bin only, so that updates to dt-blob would not be needed when new PI version comes out?
urosg
Sun Dec 10, 2017 4:13 am
DISREGARD the content below this note as it is not accurate - I made a mistake in the dt-blob source where I deleted a few internal pin definitions which caused the kernel panic and increased current consumption. Redefining dt-blob from original and just defining the [email protected]_RUN as type="external" and number=<27> seems to work.
I redefined LAN_RUN in dt-blob but now there is a kernel panic cycling after boot also current consumption jumped from regular 300mA to over 500mA.
Also if I defined "type" as "internal" for [email protected]_RUN the LAN module is not initialized.
dt-blob
/dts-v1/;
   videocore {
      pins_cm3 { // Pi 3 CM3
         pin_config {
            [email protected] {
               polarity = "active_high";
               termination = "pull_down";
               startup_state = "inactive";
               function = "input";
            }; // pin
            [email protected] { function = "uart0";  termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
            [email protected] { function = "uart0";  termination = "pull_up"; drive_strength_mA = < 8 >; }; // RX uart0
            [email protected] { function = "input";   termination = "pull_up";    }; // SMPS_SCL
            [email protected] { function = "input";   termination = "pull_up";    }; // SMPS_SDA
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CLK
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CMD
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D0
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D1
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D2
            [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D3
            [email protected] { function = "input";  termination = "no_pulling"; polarity = "active_low"; }; // Hotplug
            [email protected] { function = "output"; termination = "no_pulling"; polarity = "active_low"; }; // EMMC_ENABLE_N
            // added pin defines
            [email protected] { function = "output"; termination = "pull_down"; polarity = "active_high"; startup_state = "inactive"; }; // ETH RESET
            [email protected] { function = "output"; termination = "no_pulling"; polarity = "active_high"; startup_state = "inactive"; }; // CAN RESET
         }; // pin_config
         pin_defines {
            [email protected]_CONTROL_ATTACHED {
               type = "external";
               number = <0>;
            [email protected]_ENABLE {
               type = "external";
               number = <1>;
            [email protected]_CAMERAS {
               type = "internal";
               number = <0>;
            [email protected]_LOW {
               type = "absent";
            [email protected]_DISK_ACTIVITY {
               type = "absent";
            [email protected]_RUN {
               type = "external";
               number = <27>;
            [email protected]_1V8_SEL {
               type = "absent";
            [email protected] {
               type = "absent";
            [email protected] {
               type = "absent";
            [email protected]_MODE {
               type = "absent";
            [email protected]_CARD_DETECT {
               type = "absent";
            [email protected]_SDA {
               type = "absent";
            [email protected]_SCL {
               type = "absent";
         }; // pin_defines
      }; // pins
log output:
[    0.000334] Console: colour dummy device 80x30
[    0.001502] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001932] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001974] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002998] Disabling cpuset control group subsystem
[    0.003193] CPU: Testing write buffer coherency: ok
[    0.003264] ftrace: allocating 22390 entries in 66 pages
[    0.055956] CPU0: update cpu_capacity 1024
[    0.056024] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.056129] Setting up static identity map for 0x100000 - 0x100034
[    0.058385] CPU1: update cpu_capacity 1024
[    0.058393] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.059108] CPU2: update cpu_capacity 1024
[    0.059114] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.059781] CPU3: update cpu_capacity 1024
[    0.059788] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.059871] Brought up 4 CPUs
[    0.060044] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.060073] CPU: All CPU(s) started in HYP mode.
[    0.060099] CPU: Virtualization extensions available.
[    0.060916] devtmpfs: initialized
[    0.071895] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.072217] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072279] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.072840] pinctrl core: initialized pinctrl subsystem
[    0.073763] NET: Registered protocol family 16
[    0.076087] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.085013] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.085062] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.085238] Serial: AMBA PL011 UART driver
[    0.087257] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.156593] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[    0.158455] SCSI subsystem initialized
[    0.158637] usbcore: registered new interface driver usbfs
[    0.158737] usbcore: registered new interface driver hub
[    0.158853] usbcore: registered new device driver usb
[    0.165508] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[    0.166962] clocksource: Switched to clocksource arch_sys_counter
[    0.213847] VFS: Disk quotas dquot_6.6.0
[    0.213957] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.214186] FS-Cache: Loaded
[    0.214450] CacheFiles: Loaded
[    0.226706] NET: Registered protocol family 2
[    0.227632] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.227770] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.227981] TCP: Hash tables configured (established 8192 bind 8192)
[    0.228094] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.228161] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.228393] NET: Registered protocol family 1
[    0.228856] RPC: Registered udp transport module.
[    0.228911] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.229931] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.232224] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.248379] FS-Cache: Netfs 'nfs' registered for caching
[    0.249374] NFS: Registering the id_resolver key type
[    0.249425] Key type id_resolver registered
[    0.249453] Key type id_legacy registered
[    0.251889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.252036] io scheduler noop registered
[    0.252066] io scheduler deadline registered (default)
[    0.252393] io scheduler cfq registered
[    0.258109] BCM2708FB: allocated DMA memory fa910000
[    0.258164] BCM2708FB: allocated DMA channel 0 @ bb80f000
[    0.266866] Console: switching to colour frame buffer device 82x26
[    0.275278] bcm2835-rng 3f104000.rng: hwrng registered
[    0.277677] vc-cma: Videocore CMA driver
[    0.279891] vc-cma: vc_cma_base      = 0x00000000
[    0.282110] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.284367] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.286780] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    0.306417] brd: module loaded
[    0.317439] loop: module loaded
[    0.319481] Loading iSCSI transport class v2.0-870.
[    0.322044] usbcore: registered new interface driver smsc95xx
[    0.324137] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.554339] Core Release: 2.80a
[    0.556400] Setting default values for core params
[    0.558463] Finished setting default values for core params
[    0.760902] Using Buffer DMA mode
[    0.762953] Periodic Transfer Interrupt Enhancement - disabled
[    0.765105] Multiprocessor Interrupt Enhancement - disabled
[    0.767289] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.769493] Dedicated Tx FIFOs mode
[    0.771955] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[    0.776407] FIQ FSM acceleration enabled for :
[    0.776407] Non-periodic Split Transactions
[    0.776407] Periodic Split Transactions
[    0.776407] High-Speed Isochronous Endpoints
[    0.776407] Interrupt/Control Split Transaction hack enabled
[    0.787781] dwc_otg: Microframe scheduler enabled
[    0.790083] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058ef90
[    0.792451] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f300 length 36
[    0.794798] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[    0.797155] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.799475] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.801832] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.804179] Init: Port Power? op_state=1
[    0.806441] Init: Power Port (0)
[    0.808839] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.811151] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.813453] usb usb1: Product: DWC OTG Controller
[    0.815707] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
[    0.818032] usb usb1: SerialNumber: 3f980000.usb
[    0.821086] hub 1-0:1.0: USB hub found
[    0.823240] hub 1-0:1.0: 1 port detected
[    0.825975] dwc_otg: FIQ enabled
[    0.828047] dwc_otg: NAK holdoff enabled
[    0.830088] dwc_otg: FIQ split-transaction FSM enabled
[    0.832179] Module dwc_common_port init
[    0.834460] usbcore: registered new interface driver usb-storage
[    0.836798] mousedev: PS/2 mouse device common for all mice
[    0.839939] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.842411] bcm2835-cpufreq: min=600000 max=1200000
[    0.844987] sdhci: Secure Digital Host Controller Interface driver
[    0.847235] sdhci: Copyright(c) Pierre Ossman
[    0.851579] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[    0.854068] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.856769] ledtrig-cpu: registered to indicate activity on CPUs
[    0.859236] hidraw: raw HID events driver (C) Jiri Kosina
[    0.861743] usbcore: registered new interface driver usbhid
[    0.864077] usbhid: USB HID core driver
[    0.867121] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[    0.871173] Initializing XFRM netlink socket
[    0.873560] NET: Registered protocol family 17
[    0.876034] Key type dns_resolver registered
[    0.878887] Registering SWP/SWPB emulation handler
[    0.882025] registered taskstats version 1
[    0.884858] vc-sm: Videocore shared memory driver
[    0.887355] [vc_sm_connected_init]: start
[    0.890249] [vc_sm_connected_init]: end - returning 0
[    0.897851] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.897769] console [ttyAMA0] enabled
[    1.907358] sdhost: log_buf @ ba907000 (fa907000)
[    1.986989] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.994952] of_cfs_init
[    1.999772] of_cfs_init: OK
[    2.005192] Waiting for root device /dev/mmcblk0p2...
[    2.017082] Indeed it is in host mode hprt0 = 00021501
[    2.112546] random: fast init done
[    2.216996] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.225775] Indeed it is in host mode hprt0 = 00001101
[    2.293883] mmc0: new high speed MMC card at address 0001
[    2.302125] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[    2.309022] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[    2.317437] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[    2.325732] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[    2.335046]  mmcblk0: p1 p2
[    2.376894] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.389624] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.405998] devtmpfs: mounted
[    2.413092] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[    2.457272] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.466451] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.476875] hub 1-1:1.0: USB hub found
[    2.483181] hub 1-1:1.0: 5 ports detected
[    2.707853] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    2.726791] systemd[1]: Detected architecture 'arm'.
[    2.807017] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.840791] NET: Registered protocol family 10
[    2.849279] systemd[1]: Inserted module 'ipv6'
[    2.857856] systemd[1]: Set hostname to <raspberrypi>.
[    2.911279] uart-pl011 3f201000.serial: no DMA platform data
[    2.937378] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.947020] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.960717] smsc95xx v1.0.5
[    3.060858] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6f:e7:fb
[    3.201079] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[    3.225848] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    3.252325] systemd[1]: Expecting device dev-ttyAMA0.device...
[    3.264612] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    3.278506] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.292277] systemd[1]: Starting Remote File Systems (Pre).
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Show Plymouth Boot Screen.
[  OK  ] Reached target Paths.
         Mounting /boot...
[  OK  ] Mounted /boot.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting LSB: Raise network interfaces....
[  OK  ] Reached target Remote File Systems.
         Starting Trigger Flushing of Journal to Persistent Storage...
         Starting LSB: Switch to ondemand cpu governor (unless ... is pressed)...
         Starting LSB: Prepare console...
[  OK  ] Started Tell Plymouth To Write Out Runtime Data.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
[  OK  ] Started LSB: Switch to ondemand cpu governor (unless s...ey is pressed).
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started LSB: Prepare console.
         Starting LSB: Set console font and keymap...
[  OK  ] Started LSB: Set console font and keymap.
[  OK  ] Started LSB: Raise network interfaces..
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Basic System.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting dhcpcd on all interfaces...
         Starting Regular background program processing daemon...
[  OK  ] Started Regular background program processing daemon.
         Starting System Logging Service...
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting Login Service...
         Starting LSB: Autogenerate and use a swap file...
         Starting LSB: triggerhappy hotkey daemon...
[  OK  ] Started System Logging Service.
[  OK  ] Started Login Service.
[  OK  ] Started LSB: triggerhappy hotkey daemon.
[  OK  ] Started LSB: Autogenerate and use a swap file.
[  OK  ] Started dhcpcd on all interfaces.
[  OK  ] Reached target Network.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting /etc/rc.local Compatibility...
         Starting Permit User Sessions...
[  OK  ] Reached target Network is Online.
         Starting LSB: Start NTP daemon...
[  OK  ] Started Permit User Sessions.
My IP address is 2a00:ee2:1200:6ab:5257:5f9a:5934:301f
[  OK  ] Started /etc/rc.local Compatibility.
         Starting Hold until boot process finishes up...
         Starting Terminate Plymouth Boot Screen...
Raspbian GNU/Linux 8 raspberrypi ttyAMA0
raspberrypi login: [   13.916973] Unable to handle kernel paging request at virtual address 00031608
[   13.926237] pgd = 80004000
[   13.929958] [00031608] *pgd=00000000
[   13.934561] Internal error: Oops: 8000000f [#1] SMP ARM
[   13.940836] Modules linked in: cfg80211 rfkill mcp251x can_dev spidev bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq uio fixed ipv6
[   13.954738] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.9.35-v7+ #1014
[   13.962436] Hardware name: BCM2835
[   13.966986] task: b9941d80 task.stack: b994a000
[   13.972695] PC is at 0x31608
[   13.976734] LR is at generic_handle_irq+0x34/0x44
[   13.982610] pc : [<00031608>]    lr : [<80172fb0>]    psr: a0000193
[   13.982610] sp : b994bf08  ip : b940005c  fp : b994bf14
[   13.996494] r10: 00000000  r9 : b994a000  r8 : b9805180
[   14.002890] r7 : 00000001  r6 : 00000000  r5 : 00000000  r4 : 80b7cec0
[   14.010599] r3 : 00031608  r2 : 00000000  r1 : 00000011  r0 : b983bcc0
[   14.018297] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   14.026724] Control: 10c5383d  Table: 371c806a  DAC: 00000055
[   14.033695] Process swapper/1 (pid: 0, stack limit = 0xb994a210)
[   14.040948] Stack: (0xb994bf08 to 0xb994c000)
[   14.046512] bf00:                   b994bf3c b994bf18 801735f0 80172f88 b994bf58 80c04670
[   14.057112] bf20: 60000013 ffffffff b994bf8c 80c15f06 b994bf54 b994bf40 8010150c 80173590
[   14.067885] bf40: 80c040a4 80108a58 b994bfb4 b994bf58 8071967c 80101470 00000000 b9f73470
[   14.078707] bf60: 00000000 00000000 b994a000 80c0312c 00000002 80c03198 80c15f06 80c15f06
[   14.089547] bf80: 00000000 b994bfb4 80c040a4 b994bfa8 80108a54 80108a58 60000013 ffffffff
[   14.100536] bfa0: 80108a54 00000000 b994bfc4 b994bfb8 80718dc4 80108a30 b994bfdc b994bfc8
[   14.111680] bfc0: 80161d2c 80718d9c 00000000 80c7b338 b994bff4 b994bfe0 8010dcf0 80161c54
[   14.122933] bfe0: 398e806a 00000055 00000000 b994bff8 0010196c 8010dbcc 55555555 55555555
[   14.134380] [<80172fb0>] (generic_handle_irq) from [<801735f0>] (__handle_domain_irq+0x6c/0xc4)
[   14.146442] [<801735f0>] (__handle_domain_irq) from [<8010150c>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
[   14.159637] [<8010150c>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   14.172023] Exception stack(0xb994bf58 to 0xb994bfa0)
[   14.178825] bf40:                                                       00000000 b9f73470
[   14.190367] bf60: 00000000 00000000 b994a000 80c0312c 00000002 80c03198 80c15f06 80c15f06
[   14.201868] bf80: 00000000 b994bfb4 80c040a4 b994bfa8 80108a54 80108a58 60000013 ffffffff
[   14.213374] [<8071967c>] (__irq_svc) from [<80108a58>] (arch_cpu_idle+0x34/0x4c)
[   14.224083] [<80108a58>] (arch_cpu_idle) from [<80718dc4>] (default_idle_call+0x34/0x48)
[   14.235503] [<80718dc4>] (default_idle_call) from [<80161d2c>] (cpu_startup_entry+0xe4/0x160)
[   14.236968] Unable to handle kernel paging request at virtual address 00031608
[   14.236970] pgd = 80004000
[   14.236973] [00031608] *pgd=00000000
[   14.265784] [<80161d2c>] (cpu_startup_entry) from [<8010dcf0>] (secondary_start_kernel+0x130/0x13c)
[   14.278015] [<8010dcf0>] (secondary_start_kernel) from [<0010196c>] (0x10196c)
[   14.286856] Code: aa000068 e5943114 e3833020 e5843114 (ed9f6b6c)
[   14.294548] ---[ end trace f66af876771daa75 ]---
[   14.294550] Internal error: Oops: 80000007 [#2] SMP ARM
[   14.294565] Modules linked in: cfg80211 rfkill mcp251x can_dev spidev bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq uio fixed ipv6
[   14.294570] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.9.35-v7+ #1014
[   14.294572] Hardware name: BCM2835
[   14.294574] task: 80c06cc0 task.stack: 80c00000
[   14.294576] PC is at 0x31608
[   14.294579] LR is at generic_handle_irq+0x34/0x44
[   14.294583] pc : [<00031608>]    lr : [<80172fb0>]    psr: a0000193
[   14.294583] sp : 80c01ec8  ip : b940005c  fp : 80c01ed4
[   14.294585] r10: ba7ffa80  r9 : 80c00000  r8 : b9805180
[   14.294588] r7 : 00000001  r6 : 00000000  r5 : 00000000  r4 : 80b7cec0
[   14.294590] r3 : 00031608  r2 : 00000000  r1 : 00000011  r0 : b983bcc0
[   14.294593] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   14.294596] Control: 10c5383d  Table: 38e4806a  DAC: 00000055
[   14.294598] Process swapper/0 (pid: 0, stack limit = 0x80c00210)
[   14.294601] Stack: (0x80c01ec8 to 0x80c02000)
[   14.294605] 1ec0:                   80c01efc 80c01ed8 801735f0 80172f88 80c01f18 80c04670
[   14.294611] 1ee0: 60000013 ffffffff 80c01f4c 80c15f06 80c01f14 80c01f00 8010150c 80173590
[   14.294616] 1f00: 80c040a4 80108a58 80c01f74 80c01f18 8071967c 80101470 00000000 b9f65470
[   14.294621] 1f20: 00000000 00000000 80c00000 80c0312c 00000001 80c03198 80c15f06 80c15f06
[   14.294627] 1f40: ba7ffa80 80c01f74 80c040a4 80c01f68 80108a54 80108a58 60000013 ffffffff
[   14.294632] 1f60: 80108a54 00000000 80c01f84 80c01f78 80718dc4 80108a30 80c01f9c 80c01f88
[   14.294637] 1f80: 80161d2c 80718d9c 808023f0 ffffffff 80c01fac 80c01fa0 80713650 80161c54
[   14.294642] 1fa0: 80c01ff4 80c01fb0 80b00d28 807135d8 ffffffff ffffffff 00000000 80b006f8
[   14.294647] 1fc0: 00000000 80b56a30 00000000 80c7b294 80c0311c 80b56a2c 80c089a8 0000406a
[   14.294652] 1fe0: 410fd034 00000000 00000000 80c01ff8 0000807c 80b00980 00000000 00000000
[   14.294659] [<80172fb0>] (generic_handle_irq) from [<801735f0>] (__handle_domain_irq+0x6c/0xc4)
[   14.294666] [<801735f0>] (__handle_domain_irq) from [<8010150c>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
[   14.294672] [<8010150c>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   14.294674] Exception stack(0x80c01f18 to 0x80c01f60)
[   14.294677] 1f00:                                                       00000000 b9f65470
[   14.294682] 1f20: 00000000 00000000 80c00000 80c0312c 00000001 80c03198 80c15f06 80c15f06
[   14.294687] 1f40: ba7ffa80 80c01f74 80c040a4 80c01f68 80108a54 80108a58 60000013 ffffffff
[   14.294694] [<8071967c>] (__irq_svc) from [<80108a58>] (arch_cpu_idle+0x34/0x4c)
[   14.294701] [<80108a58>] (arch_cpu_idle) from [<80718dc4>] (default_idle_call+0x34/0x48)
[   14.294706] [<80718dc4>] (default_idle_call) from [<80161d2c>] (cpu_startup_entry+0xe4/0x160)
[   14.294714] [<80161d2c>] (cpu_startup_entry) from [<80713650>] (rest_init+0x84/0x88)
[   14.294724] [<80713650>] (rest_init) from [<80b00d28>] (start_kernel+0x3b4/0x3c0)
[   14.294727] Code: bad PC value
[   14.294729] ---[ end trace f66af876771daa76 ]---
[   14.294732] Kernel panic - not syncing: Fatal exception in interrupt
[   14.294739] CPU3: stopping
[   14.294744] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.9.35-v7+ #1014
[   14.294745] Hardware name: BCM2835
[   14.294754] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[   14.294765] [<8010c058>] (show_stack) from [<80455880>] (dump_stack+0xd4/0x118)
[   14.294773] [<80455880>] (dump_stack) from [<8010e1e4>] (handle_IPI+0x2a4/0x2c4)
[   14.294779] [<8010e1e4>] (handle_IPI) from [<801014e0>] (bcm2836_arm_irqchip_handle_irq+0x7c/0xac)
[   14.294785] [<801014e0>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   14.294788] Exception stack(0xb994ff58 to 0xb994ffa0)
[   14.294791] ff40:                                                       00000000 b9f8f470
[   14.294796] ff60: 00000000 00000000 b994e000 80c0312c 00000008 80c03198 80c15f06 80c15f06
[   14.294801] ff80: 00000000 b994ffb4 80c040a4 b994ffa8 80108a54 80108a58 60000013 ffffffff
[   14.294808] [<8071967c>] (__irq_svc) from [<80108a58>] (arch_cpu_idle+0x34/0x4c)
[   14.294814] [<80108a58>] (arch_cpu_idle) from [<80718dc4>] (default_idle_call+0x34/0x48)
[   14.294820] [<80718dc4>] (default_idle_call) from [<80161d2c>] (cpu_startup_entry+0xe4/0x160)
[   14.294826] [<80161d2c>] (cpu_startup_entry) from [<8010dcf0>] (secondary_start_kernel+0x130/0x13c)
[   14.294831] [<8010dcf0>] (secondary_start_kernel) from [<0010196c>] (0x10196c)
[   14.294833] CPU2: stopping
[   14.294837] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.9.35-v7+ #1014
[   14.294839] Hardware name: BCM2835
[   14.294847] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[   14.294853] [<8010c058>] (show_stack) from [<80455880>] (dump_stack+0xd4/0x118)
[   14.294860] [<80455880>] (dump_stack) from [<8010e1e4>] (handle_IPI+0x2a4/0x2c4)
[   14.294866] [<8010e1e4>] (handle_IPI) from [<801014e0>] (bcm2836_arm_irqchip_handle_irq+0x7c/0xac)
[   14.294873] [<801014e0>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   14.294875] Exception stack(0xb994df58 to 0xb994dfa0)
[   14.294878] df40:                                                       00000000 b9f81470
[   14.294883] df60: 00000000 00000000 b994c000 80c0312c 00000004 80c03198 80c15f06 80c15f06
[   14.294889] df80: 00000000 b994dfb4 80c040a4 b994dfa8 80108a54 80108a58 60000013 ffffffff
[   14.294896] [<8071967c>] (__irq_svc) from [<80108a58>] (arch_cpu_idle+0x34/0x4c)
[   14.294902] [<80108a58>] (arch_cpu_idle) from [<80718dc4>] (default_idle_call+0x34/0x48)
[   14.294908] [<80718dc4>] (default_idle_call) from [<80161d2c>] (cpu_startup_entry+0xe4/0x160)
[   14.294914] [<80161d2c>] (cpu_startup_entry) from [<8010dcf0>] (secondary_start_kernel+0x130/0x13c)
[   14.294919] [<8010dcf0>] (secondary_start_kernel) from [<0010196c>] (0x10196c)
[   15.388334] SMP: failed to stop secondary CPUs
[   15.394446] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
[   15.403261] Unable to handle kernel paging request at virtual address 00031608
[   15.412150] pgd = 80004000
[   15.416452] [00031608] *pgd=00000000
[   15.421618] Internal error: Oops: 80000007 [#3] SMP ARM
[   15.428443] Modules linked in: cfg80211 rfkill mcp251x can_dev spidev bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq uio fixed ipv6
[   15.443414] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.9.35-v7+ #1014
[   15.454378] Hardware name: BCM2835
[   15.459333] task: 80c06cc0 task.stack: 80c00000
[   15.465387] PC is at 0x31608
[   15.469730] LR is at generic_handle_irq+0x34/0x44
[   15.475879] pc : [<00031608>]    lr : [<80172fb0>]    psr: a0000193
[   15.475879] sp : 80c01be0  ip : b940005c  fp : 80c01bec
[   15.490189] r10: 00031600  r9 : 80c00000  r8 : b9805180
[   15.496760] r7 : 00000001  r6 : 80c01f18  r5 : 00000000  r4 : 80b7cec0
[   15.504603] r3 : 00031608  r2 : 00000000  r1 : 00000011  r0 : b983bcc0
[   15.512405] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   15.520897] Control: 10c5383d  Table: 38e4806a  DAC: 00000055
[   15.527895] Process swapper/0 (pid: 0, stack limit = 0x80c00210)
[   15.535142] Stack: (0x80c01be0 to 0x80c02000)
[   15.540705] 1be0: 80c01c14 80c01bf0 801735f0 80172f88 80c01c30 80c04670 60000113 ffffffff
[   15.551340] 1c00: 80c01c64 00000000 80c01c2c 80c01c18 8010150c 80173590 80c040a4 80209a48
[   15.562106] 1c20: 80c01cbc 80c01c30 8071967c 80101470 00000041 00000000 00000007 00000000
[   15.572881] 1c40: 80c7b4e8 60000193 80c08998 00000000 00000000 80c7b4e8 00031600 80c01cbc
[   15.583747] 1c60: 80c040a4 80c01c80 80209a44 80209a48 60000113 ffffffff 80209a44 7f000000
[   15.594780] 1c80: 80209b64 80171f84 8016ad4c 80c01cc4 00000000 80c7b2c4 60000193 80c08998
[   15.605961] 1ca0: 0000000b 000315f8 fffffffc 00031600 80c01d54 80c01cd0 8010c490 80209840
[   15.617271] 1cc0: 8094dfc4 00000000 00010000 00010000 80c00210 0000000b 00000000 8094df3c
[   15.628748] 1ce0: 00000008 7f000000 00000000 80c08998 62171fc0 50206461 61762043 0065756c
[   15.640289] 1d00: 80c01d24 80c01d10 80209b64 80171f84 80171fc0 80c01d2c 80c01d54 80c01d38
[   15.651922] 1d20: 8011573c 80209b38 8094f830 00031608 80000007 80c01e78 00000000 00000000
[   15.663596] 1d40: 80c00000 ba7ffa80 80c01d6c 80c01d58 80118eb4 8010c068 80c01e78 00031608
[   15.675260] 1d60: 80c01dc4 80c01d70 8071a040 80118e4c 80c01dbc 80c01d80 80148224 80719344
[   15.686934] 1d80: 80c01d9c 80c01d90 805da554 805da210 80c01ddc 80c01da0 8018cc4c 80c095f4
[   15.698607] 1da0: 00000007 80719df8 00031608 80c01e78 80c00000 ba7ffa80 80c01e74 80c01dc8
[   15.710275] 1dc0: 801012a8 80719e04 b9f66678 801955f8 80c01e0c 80c01de0 801955f8 805da448
[   15.721945] 1de0: 4f656663 00000003 00000000 b8f51e00 b8f51e08 80c03180 80c01e84 80c01e08
[   15.733618] 1e00: 80157224 8045b4e8 801978c4 80195528 00000000 b9f665d4 80b7b5c0 b9f665d4
[   15.745289] 1e20: 00000003 b9f665c0 80c01e8c 80c01e38 80187b3c 80197860 80c01e54 80c01e48
[   15.756954] 1e40: 805da554 805da210 80c01e94 00031608 a0000193 00031608 a0000193 ffffffff
[   15.768626] 1e60: 80c01eac b9805180 80c01ed4 80c01e78 807197b4 80101270 b983bcc0 00000011
[   15.780300] 1e80: 00000000 00031608 80b7cec0 00000000 00000000 00000001 b9805180 80c00000
[   15.791966] 1ea0: ba7ffa80 80c01ed4 b940005c 80c01ec8 80172fb0 00031608 a0000193 ffffffff
[   15.803639] 1ec0: 80172fa0 7f000000 80c01efc 80c01ed8 801735f0 80172f88 80c01f18 80c04670
[   15.815315] 1ee0: 60000013 ffffffff 80c01f4c 80c15f06 80c01f14 80c01f00 8010150c 80173590
[   15.826985] 1f00: 80c040a4 80108a58 80c01f74 80c01f18 8071967c 80101470 00000000 b9f65470
[   15.838655] 1f20: 00000000 00000000 80c00000 80c0312c 00000001 80c03198 80c15f06 80c15f06
[   15.850330] 1f40: ba7ffa80 80c01f74 80c040a4 80c01f68 80108a54 80108a58 60000013 ffffffff
[   15.862002] 1f60: 80108a54 00000000 80c01f84 80c01f78 80718dc4 80108a30 80c01f9c 80c01f88
[   15.873671] 1f80: 80161d2c 80718d9c 808023f0 ffffffff 80c01fac 80c01fa0 80713650 80161c54
[   15.885346] 1fa0: 80c01ff4 80c01fb0 80b00d28 807135d8 ffffffff ffffffff 00000000 80b006f8
[   15.897018] 1fc0: 00000000 80b56a30 00000000 80c7b294 80c0311c 80b56a2c 80c089a8 0000406a
[   15.908682] 1fe0: 410fd034 00000000 00000000 80c01ff8 0000807c 80b00980 00000000 00000000
[   15.920356] [<80172fb0>] (generic_handle_irq) from [<801735f0>] (__handle_domain_irq+0x6c/0xc4)
[   15.932564] [<801735f0>] (__handle_domain_irq) from [<8010150c>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
[   15.945833] [<8010150c>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   15.958221] Exception stack(0x80c01c30 to 0x80c01c78)
[   15.965017] 1c20:                                     00000041 00000000 00000007 00000000
[   15.976610] 1c40: 80c7b4e8 60000193 80c08998 00000000 00000000 80c7b4e8 00031600 80c01cbc
[   15.988175] 1c60: 80c040a4 80c01c80 80209a44 80209a48 60000113 ffffffff
[   15.996507] [<8071967c>] (__irq_svc) from [<80209a48>] (panic+0x218/0x274)
[   16.005085] [<80209a48>] (panic) from [<8010c490>] (die+0x434/0x440)
[   16.013125] [<8010c490>] (die) from [<80118eb4>] (__do_kernel_fault.part.0+0x74/0x1f4)
[   16.024314] [<80118eb4>] (__do_kernel_fault.part.0) from [<8071a040>] (do_page_fault+0x248/0x3b0)
[   16.036487] [<8071a040>] (do_page_fault) from [<801012a8>] (do_PrefetchAbort+0x44/0xa8)
[   16.047787] [<801012a8>] (do_PrefetchAbort) from [<807197b4>] (__pabt_svc+0x54/0x80)
[   16.058813] Exception stack(0x80c01e78 to 0x80c01ec0)
[   16.065494] 1e60:                                                       b983bcc0 00000011
[   16.076800] 1e80: 00000000 00031608 80b7cec0 00000000 00000000 00000001 b9805180 80c00000
[   16.088076] 1ea0: ba7ffa80 80c01ed4 b940005c 80c01ec8 80172fb0 00031608 a0000193 ffffffff
[   16.099425] [<807197b4>] (__pabt_svc) from [<00031608>] (0x31608)
[   16.107126] Code: bad PC value
[   16.111733] ---[ end trace f66af876771daa77 ]---
[   16.117893] Kernel panic - not syncing: Fatal exception in interrupt
[   17.219401] SMP: failed to stop secondary CPUs
[   17.225380] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
[   17.234090] Unable to handle kernel paging request at virtual address 00031608
[   17.242868] pgd = 80004000
[   17.247067] [00031608] *pgd=00000000
[   17.252097] Internal error: Oops: 80000007 [#4] SMP ARM
[   17.258758] Modules linked in: cfg80211 rfkill mcp251x can_dev spidev bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq uio fixed ipv6
[   17.273279] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.9.35-v7+ #1014
[   17.283820] Hardware name: BCM2835
[   17.288597] task: 80c06cc0 task.stack: 80c00000
[   17.294532] PC is at 0x31608
[   17.298758] LR is at generic_handle_irq+0x34/0x44
[   17.304783] pc : [<00031608>]    lr : [<80172fb0>]    psr: a0000193
[   17.304783] sp : 80c018f8  ip : b940005c  fp : 80c01904
[   17.318867] r10: 00031600  r9 : 80c00000  r8 : b9805180
[   17.325342] r7 : 00000001  r6 : 80c01c30  r5 : 00000000  r4 : 80b7cec0
[   17.333116] r3 : 00031608  r2 : 00000000  r1 : 00000011  r0 : b983bcc0
[   17.340880] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   17.349360] Control: 10c5383d  Table: 38e4806a  DAC: 00000055
[   17.356349] Process swapper/0 (pid: 0, stack limit = 0x80c00210)
[   17.363590] Stack: (0x80c018f8 to 0x80c02000)
[   17.369151] 18e0:                                                       80c0192c 80c01908
[   17.379684] 1900: 801735f0 80172f88 80c01948 80c04670 60000113 ffffffff 80c0197c 00000000
[   17.390288] 1920: 80c01944 80c01930 8010150c 80173590 80c040a4 80209a48 80c019d4 80c01948
[   17.400914] 1940: 8071967c 80101470 00000041 00000000 00000007 00000000 80c7b4e8 60000193
[   17.411622] 1960: 80c08998 00000000 00000000 80c7b4e8 00031600 80c019d4 80c040a4 80c01998
[   17.422502] 1980: 80209a44 80209a48 60000113 ffffffff 80209a44 7f000000 80209b64 80171f84
[   17.433526] 19a0: 0000000b 80c019dc 00000006 80c7b2c4 60000193 80c08998 0000000b 000315f8
[   17.444664] 19c0: fffffffc 00031600 80c01a6c 80c019e8 8010c490 80209840 8094dfc4 00000000
[   17.455974] 19e0: 00020000 00020000 80c00210 0000000b 00000000 8094df3c 00000008 7f000000
[   17.467363] 1a00: 00000000 80c08998 62171fc0 50206461 61762043 0065756c 80c01a3c 80c01a28
[   17.478829] 1a20: 80209b64 80171f84 80171fc0 80c01a44 80c01a6c 80c01a50 8011573c 80209b38
[   17.490443] 1a40: 8094f830 00031608 80000007 80c01b90 00000000 00000000 80c00000 00031600
[   17.502109] 1a60: 80c01a84 80c01a70 80118eb4 8010c068 80c01b90 00031608 80c01adc 80c01a88
[   17.513777] 1a80: 8071a040 80118e4c 80d0cbb0 80000193 00000001 00000051 80c7eb1c 80c00000
[   17.525438] 1aa0: 80c01ac4 80c01ab0 807193a4 801e35a0 00000000 80c095f4 00000007 80719df8
[   17.537105] 1ac0: 00031608 80c01b90 80c00000 00031600 80c01b8c 80c01ae0 801012a8 80719e04
[   17.548775] 1ae0: 804a8938 804a882c b917ec10 60000193 80c01b0c 80c01b00 804a8968 804a8914
[   17.560440] 1b00: 80c01b34 60000193 00000000 0000014d 00000000 0000014c 80c9e580 0000647c
[   17.572115] 1b20: 80c01b44 60000193 00000000 0000014d 80c01b54 80c01b40 801f6368 801f6080
[   17.583786] 1b40: 0000014d 00000000 80c01b64 80c01b58 80171020 801f6360 80c01bdc 80c01b68
[   17.595451] 1b60: 80171724 00031608 a0000193 00031608 a0000193 ffffffff 80c01bc4 b9805180
[   17.607121] 1b80: 80c01bec 80c01b90 807197b4 80101270 b983bcc0 00000011 00000000 00031608
[   17.618791] 1ba0: 80b7cec0 00000000 80c01f18 00000001 b9805180 80c00000 00031600 80c01bec
[   17.630461] 1bc0: b940005c 80c01be0 80172fb0 00031608 a0000193 ffffffff 80172fa0 7f000000
[   17.642123] 1be0: 80c01c14 80c01bf0 801735f0 80172f88 80c01c30 80c04670 60000113 ffffffff
[   17.653792] 1c00: 80c01c64 00000000 80c01c2c 80c01c18 8010150c 80173590 80c040a4 80209a48
[   17.665461] 1c20: 80c01cbc 80c01c30 8071967c 80101470 00000041 00000000 00000007 00000000
[   17.677120] 1c40: 80c7b4e8 60000193 80c08998 00000000 00000000 80c7b4e8 00031600 80c01cbc
[   17.688787] 1c60: 80c040a4 80c01c80 80209a44 80209a48 60000113 ffffffff 80209a44 7f000000
[   17.700456] 1c80: 80209b64 80171f84 8016ad4c 80c01cc4 00000000 80c7b2c4 60000193 80c08998
[   17.712120] 1ca0: 0000000b 000315f8 fffffffc 00031600 80c01d54 80c01cd0 8010c490 80209840
[   17.723787] 1cc0: 8094dfc4 00000000 00010000 00010000 80c00210 0000000b 00000000 8094df3c
[   17.735458] 1ce0: 00000008 7f000000 00000000 80c08998 62171fc0 50206461 61762043 0065756c
[   17.747131] 1d00: 80c01d24 80c01d10 80209b64 80171f84 80171fc0 80c01d2c 80c01d54 80c01d38
[   17.758797] 1d20: 8011573c 80209b38 8094f830 00031608 80000007 80c01e78 00000000 00000000
[   17.770472] 1d40: 80c00000 ba7ffa80 80c01d6c 80c01d58 80118eb4 8010c068 80c01e78 00031608
[   17.782145] 1d60: 80c01dc4 80c01d70 8071a040 80118e4c 80c01dbc 80c01d80 80148224 80719344
[   17.793807] 1d80: 80c01d9c 80c01d90 805da554 805da210 80c01ddc 80c01da0 8018cc4c 80c095f4
[   17.805483] 1da0: 00000007 80719df8 00031608 80c01e78 80c00000 ba7ffa80 80c01e74 80c01dc8
[   17.817154] 1dc0: 801012a8 80719e04 b9f66678 801955f8 80c01e0c 80c01de0 801955f8 805da448
[   17.828824] 1de0: 4f656663 00000003 00000000 b8f51e00 b8f51e08 80c03180 80c01e84 80c01e08
[   17.840496] 1e00: 80157224 8045b4e8 801978c4 80195528 00000000 b9f665d4 80b7b5c0 b9f665d4
[   17.852168] 1e20: 00000003 b9f665c0 80c01e8c 80c01e38 80187b3c 80197860 80c01e54 80c01e48
[   17.863841] 1e40: 805da554 805da210 80c01e94 00031608 a0000193 00031608 a0000193 ffffffff
[   17.875509] 1e60: 80c01eac b9805180 80c01ed4 80c01e78 807197b4 80101270 b983bcc0 00000011
[   17.887182] 1e80: 00000000 00031608 80b7cec0 00000000 00000000 00000001 b9805180 80c00000
[   17.898859] 1ea0: ba7ffa80 80c01ed4 b940005c 80c01ec8 80172fb0 00031608 a0000193 ffffffff
[   17.910524] 1ec0: 80172fa0 7f000000 80c01efc 80c01ed8 801735f0 80172f88 80c01f18 80c04670
[   17.922199] 1ee0: 60000013 ffffffff 80c01f4c 80c15f06 80c01f14 80c01f00 8010150c 80173590
[   17.933873] 1f00: 80c040a4 80108a58 80c01f74 80c01f18 8071967c 80101470 00000000 b9f65470
[   17.945536] 1f20: 00000000 00000000 80c00000 80c0312c 00000001 80c03198 80c15f06 80c15f06
[   17.957204] 1f40: ba7ffa80 80c01f74 80c040a4 80c01f68 80108a54 80108a58 60000013 ffffffff
[   17.968874] 1f60: 80108a54 00000000 80c01f84 80c01f78 80718dc4 80108a30 80c01f9c 80c01f88
[   17.980542] 1f80: 80161d2c 80718d9c 808023f0 ffffffff 80c01fac 80c01fa0 80713650 80161c54
[   17.992204] 1fa0: 80c01ff4 80c01fb0 80b00d28 807135d8 ffffffff ffffffff 00000000 80b006f8
[   18.003870] 1fc0: 00000000 80b56a30 00000000 80c7b294 80c0311c 80b56a2c 80c089a8 0000406a
[   18.015538] 1fe0: 410fd034 00000000 00000000 80c01ff8 0000807c 80b00980 00000000 00000000
[   18.027195] [<80172fb0>] (generic_handle_irq) from [<801735f0>] (__handle_domain_irq+0x6c/0xc4)
[   18.039393] [<801735f0>] (__handle_domain_irq) from [<8010150c>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
[   18.052656] [<8010150c>] (bcm2836_arm_irqchip_handle_irq) from [<8071967c>] (__irq_svc+0x5c/0x7c)
[   18.065051] Exception stack(0x80c01948 to 0x80c01990)
[   18.071842] 1940:                   00000041 00000000 00000007 00000000 80c7b4e8 60000193
[   18.083454] 1960: 80c08998 00000000 00000000 80c7b4e8 00031600 80c019d4 80c040a4 80c01998
[   18.095038] 1980: 80209a44 80209a48 60000113 ffffffff
[   18.101784] [<8071967c>] (__irq_svc) from [<80209a48>] (panic+0x218/0x274)
[   18.110361] [<80209a48>] (panic) from [<8010c490>] (die+0x434/0x440)
[   18.118394] [<8010c490>] (die) from [<80118eb4>] (__do_kernel_fault.part.0+0x74/0x1f4)
[   18.129578] [<80118eb4>] (__do_kernel_fault.part.0) from [<8071a040>] (do_page_fault+0x248/0x3b0)
[   18.141736] [<8071a040>] (do_page_fault) from [<801012a8>] (do_PrefetchAbort+0x44/0xa8)
[   18.153028] [<801012a8>] (do_PrefetchAbort) from [<807197b4>] (__pabt_svc+0x54/0x80)
[   18.164053] Exception stack(0x80c01b90 to 0x80c01bd8)
[   18.170732] 1b80:                                     b983bcc0 00000011 00000000 00031608
[   18.182090] 1ba0: 80b7cec0 00000000 80c01f18 00000001 b9805180 80c00000 00031600 80c01bec
[   18.193420] 1bc0: b940005c 80c01be0 80172fb0 00031608 a0000193 ffffffff
[   18.201661] [<807197b4>] (__pabt_svc) from [<00031608>] (0x31608)
[   18.209363] Code: bad PC value
[   18.213969] ---[ end trace f66af876771daa78 ]---
[   18.220118] Kernel panic - not syncing: Fatal exception in interrupt
[   19.321630] SMP: failed to stop secondary CPUs
[   19.327608] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Return to “Device Tree”
