nandor65
/dev/ttyS0 issue on Stretch
Thu Nov 16, 2017 4:14 pm
I am unable to enable /dev/ttyS0 on Strech using raspi-config. Exact steps are as follows:
$ sudo raspi-config
Interfacing options -> Serial -> No -> Yes ... Finish -> reboot
after reboot
$ ls -l /dev/ttS0 /dev/ttyAMA0
answers this:
ls: cannot access '/dev/ttyS0': No such file or directory
crw-rw---- 1 root dialout 204, 64 Nov 16 16:56 /dev/ttyAMA0
Also checked /boot/config.txt and it has the line
enable_uart=1
as the last line.
please advise. thank you.
Nandor
PhilE
Re: /dev/ttyS0 issue on Stretch
Thu Nov 16, 2017 4:28 pm
You have a typo in your message ("ttS0" should be "ttyS0") but I'm going to assume that you typed it correctly at the command prompt. You could run
ls /dev/tty*
to confirm.
Which model of Pi are you running on? And what is the software history of your image (what did you install, did you upgrade, etc.)?
PhilE
Thu Nov 16, 2017 4:47 pm
My guess is that you aren't running on a Pi 3B or a Pi Zero W, in which case ttyS0 (uart1) has to be enabled specially. In fact, unless you are on a Compute Module there isn't much point in enabling ttyS0 because there is only one position it can appear on the 40-way header (GPIOs 14 and 15) - ttyAMA0 has the same restriction and it is a better UART.
1. In config.txt add the following line:
dtoverlay=uart1,txd1_pin=<x>,rxd1_pin=<y>
where <x> and <y> are 14/15, 32/33 or 40/41 (or you can mix and match if you really want to). Don't use 14 and 15 if ttyAMA0 is also enabled there.
2. In cmdline.txt add the following somewhere in the line (don't split the line):
8250.nr_uarts=1
After a reboot /dev/ttyS0 should exist. You can confirm the pin usage with "raspi-gpio get".
nandor65
Thu Nov 16, 2017 4:55 pm
hi PhilE,
thanks for your comments.
RPi3 RevB
[email protected]:~ $ ls /dev/tty*
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyAMA0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyprintk
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61
Stretch Lite was downoladed from repository on 13th Nov, SD was written using that image. then I did these steps:
$ sudo raspi-config
Boot Options -> Wait for network at boot
Localisation Options -> Change Timezone
Interfacing Options -> Camera -> Enable
Interfacing Options -> SSH -> Enable
reboot
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get dist-upgrade
$ sudo apt-get clean
$ sudo apt-get install --no-install-recommends xserver-xorg
$ sudo apt-get install --no-install-recommends xinit
$ sudo apt-get install lxde-core lxappearance
$ sudo apt-get install lightdm
$ sudo raspi-config (consol only)
Boot Options -> Desktop/CLI ->B3 Desktop
Interfacing Options -> VNC -> Enable
reboot
Hope this helps.
Nandor
PhilE
Thu Nov 16, 2017 5:06 pm
Can you post the output of the following commands?:
$ dmesg | grep 8250
$ cat /proc/device-tree/soc/[email protected]/status
nandor65
Thu Nov 16, 2017 5:11 pm
[email protected]:~ $ dmesg | grep 8250
[email protected]:~ $ cat /proc/device-tree/soc/[email protected]/status
PhilE
Thu Nov 16, 2017 5:21 pm
Thanks - we're slowly eliminating the impossibilities. On a Pi 3B UART1 is enabled automatically if enable_uart=1 appears in config.txt, except if either the pi3-disable-bt or pi3-miniuart-bt overlays are being used.
More typing:
$ grep -E "^[^#]" /boot/config.txt
$ cat /boot/cmdline.txt
nandor65
Thu Nov 16, 2017 5:24 pm
[email protected]:~ $ grep -E "^[^#]" /boot/config.txt
framebuffer_width=1280
framebuffer_height=720
dtparam=audio=on
start_x=1
gpu_mem=128
enable_uart=1
[email protected]:~ $ cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=5ac82c05-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
nandor65
Thu Nov 16, 2017 5:26 pm
and I would like to add that I did not do those points you suggested in your comment of Thu Nov 16, 2017 5:47 pm since i was not sure if that is for RPi3B.
nandor65
Thu Nov 16, 2017 5:32 pm
and one more addition : I am using bcm2835-v4l2 module loaded.
PhilE
Thu Nov 16, 2017 5:39 pm
Please add "dtdebug=1" to config.txt, reboot, then run:
$ sudo vcdbg log msg |& grep dt
nandor65
Thu Nov 16, 2017 5:44 pm
[email protected]:~ $ sudo vcdbg log msg |& grep dt
001773.554: brfs: File read: /mfs/sd/bcm2709-rpi-2-b.dtb
001773.578: Loading 'bcm2709-rpi-2-b.dtb' to 0x466130 size 0x4135
001785.313: dtdebug: delete_node(/__local_fixups__)
001793.556: dtdebug: /aliases:i2c_vc=i2c0
001799.356: dtdebug: /__symbols__:i2c_vc=i2c0
001804.103: dtdebug: /__overrides__:i2c_vc=i2c0
001816.125: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
001821.000: dtdebug: /aliases:i2c=i2c1
001826.969: dtdebug: /__symbols__:i2c=i2c1
001831.805: dtdebug: /__overrides__:i2c=i2c1
001836.723: dtdebug: /aliases:i2c_arm=i2c1
001842.731: dtdebug: /__symbols__:i2c_arm=i2c1
001847.608: dtdebug: /__overrides__:i2c_arm=i2c1
001859.827: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
001872.039: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
001872.060: dtparam: pwr_led_gpio=35
001875.455: dtdebug: Found override pwr_led_gpio
001875.500: dtdebug: override pwr_led_gpio: cell target gpios @ offset 4 (size 4)
001884.908: dtparam: uart0_clkrate=48000000
001888.411: dtdebug: /__overrides__ has no uart0_clkrate property
001888.424: Unknown dtparam 'uart0_clkrate' - ignored
001891.825: dtparam: audio=on
001895.241: dtdebug: Found override audio
001895.275: dtdebug: override audio: string target 'status'
001917.962: dtdebug: /aliases:serial0=uart0
001922.954: dtdebug: /aliases:serial1=uart1
002944.768: dtparam: arm_freq=900000000
002948.108: dtdebug: Found override arm_freq
002948.159: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002956.399: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002964.704: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002973.117: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002981.608: dtparam: core_freq=250000000
002985.159: dtdebug: /__overrides__ has no core_freq property
002985.174: Unknown dtparam 'core_freq' - ignored
002985.191: dtparam: cache_line_size=64
002988.495: dtdebug: Found override cache_line_size
002988.542: dtdebug: override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
003005.379: dtdebug: delete_node(/hat)
PhilE
Thu Nov 16, 2017 5:51 pm
Bingo. Are you sure this is a Pi3B?
$ grep Revision /proc/cpuinfo
$ cat /proc/device-tree/model
PhilE
Thu Nov 16, 2017 5:56 pm
You should also consider why you want to use ttyS0 on a non-Compute Module Pi because of the GPIO-usage issue I mentioned earlier.
nandor65
Thu Nov 16, 2017 5:58 pm
[email protected]:~ $ grep Revision /proc/cpuinfo
Revision : a01041
[email protected]:~ $ cat /proc/device-tree/model
Raspberry Pi 2 Model B Rev 1.1
looks like this is a RPi2.
what is the solution for RPi2 then?
PhilE
Thu Nov 16, 2017 6:01 pm
See my second (unusually prescient) post. But why do you want to use ttyS0 at all when you have ttyAMA0 (which is more capable) and you can't use both at once?
nandor65
Thu Nov 16, 2017 6:02 pm
there is a custom built PCB attached to GPIO which controls an IR cut filter. I would like to control this PCB via dev/ttyS0.
nandor65
Thu Nov 16, 2017 6:07 pm
the engineer who built this PCB told me to control via asynchron TTL serial port with these params: 38400bps 8bit 1stop no-parity no-flowcontrol
and I thought i need to use ttyS0.
PhilE
Thu Nov 16, 2017 6:09 pm
See page 102 of the BCM2835 ARM Peripherals guide and you may understand the problem. UART1 uses TXD1 and RXD1, so look for those functions in the table.
PhilE
Thu Nov 16, 2017 6:10 pm
ttyAMA0 is the obvious choice unless you are using it for something else.
nandor65
Thu Nov 16, 2017 6:13 pm
PhilE,
many thanks, looks like I need to do some readings.
N
Return to “Device Tree”
