massaimara98
Compute Module 3 Can't Change i2c1 pins to 44-45 (solved)
Wed Nov 01, 2017 9:29 am
I designed new custom io board for myself. I put i2c output pins on the board which these pins connect to the 44-45 bank1.
if i connect RTC pins to 2-3 , it works. This is the configurations:
/etc/modules
snd-bcm2835
i2c-bcm2708
i2c-dev
/boot/config.txt
dtparam=i2c_arm=on
dtoverlay=i2c-rtc,ds3231
raspi-gpio get
BANK0 (GPIO 0 to 27):
  GPIO 00: level=1 fsel=4 alt=0 func=SDA0
  GPIO 01: level=1 fsel=4 alt=0 func=SCL0
  GPIO 02: level=1 fsel=4 alt=0 func=SDA1
  GPIO 03: level=1 fsel=4 alt=0 func=SCL1
  GPIO 04: level=1 fsel=0 alt=  func=INPUT
  GPIO 05: level=1 fsel=0 alt=  func=INPUT
  GPIO 06: level=1 fsel=0 alt=  func=INPUT
  GPIO 07: level=1 fsel=0 alt=  func=INPUT
  GPIO 08: level=1 fsel=0 alt=  func=INPUT
  GPIO 09: level=0 fsel=0 alt=  func=INPUT
  GPIO 10: level=0 fsel=0 alt=  func=INPUT
  GPIO 11: level=0 fsel=0 alt=  func=INPUT
  GPIO 12: level=0 fsel=0 alt=  func=INPUT
  GPIO 13: level=0 fsel=0 alt=  func=INPUT
  GPIO 14: level=0 fsel=4 alt=0 func=TXD0
  GPIO 15: level=1 fsel=4 alt=0 func=RXD0
  GPIO 16: level=0 fsel=0 alt=  func=INPUT
  GPIO 17: level=0 fsel=0 alt=  func=INPUT
  GPIO 18: level=0 fsel=0 alt=  func=INPUT
  GPIO 19: level=0 fsel=0 alt=  func=INPUT
  GPIO 20: level=0 fsel=0 alt=  func=INPUT
  GPIO 21: level=0 fsel=0 alt=  func=INPUT
  GPIO 22: level=0 fsel=0 alt=  func=INPUT
  GPIO 23: level=0 fsel=0 alt=  func=INPUT
  GPIO 24: level=0 fsel=0 alt=  func=INPUT
  GPIO 25: level=0 fsel=0 alt=  func=INPUT
  GPIO 26: level=0 fsel=0 alt=  func=INPUT
  GPIO 27: level=0 fsel=0 alt=  func=INPUT
BANK1 (GPIO 28 to 45):
  GPIO 28: level=0 fsel=0 alt=  func=INPUT
  GPIO 29: level=0 fsel=0 alt=  func=INPUT
  GPIO 30: level=0 fsel=0 alt=  func=INPUT
  GPIO 31: level=0 fsel=0 alt=  func=INPUT
  GPIO 32: level=0 fsel=0 alt=  func=INPUT
  GPIO 33: level=0 fsel=0 alt=  func=INPUT
  GPIO 34: level=1 fsel=0 alt=  func=INPUT
  GPIO 35: level=1 fsel=0 alt=  func=INPUT
  GPIO 36: level=1 fsel=0 alt=  func=INPUT
  GPIO 37: level=0 fsel=0 alt=  func=INPUT
  GPIO 38: level=0 fsel=0 alt=  func=INPUT
  GPIO 39: level=0 fsel=0 alt=  func=INPUT
  GPIO 40: level=0 fsel=0 alt=  func=INPUT
  GPIO 41: level=0 fsel=0 alt=  func=INPUT
  GPIO 42: level=0 fsel=0 alt=  func=INPUT
  GPIO 43: level=0 fsel=0 alt=  func=INPUT
  GPIO 44: level=0 fsel=0 alt=  func=INPUT
  GPIO 45: level=0 fsel=0 alt=  func=INPUT
BANK2 (GPIO 46 to 53):
  GPIO 46: level=1 fsel=0 alt=  func=INPUT
  GPIO 47: level=1 fsel=0 alt=  func=INPUT
  GPIO 48: level=0 fsel=4 alt=0 func=SD0_CLK
  GPIO 49: level=1 fsel=4 alt=0 func=SD0_CMD
  GPIO 50: level=1 fsel=4 alt=0 func=SD0_DAT0
  GPIO 51: level=1 fsel=4 alt=0 func=SD0_DAT1
  GPIO 52: level=1 fsel=4 alt=0 func=SD0_DAT2
  GPIO 53: level=1 fsel=4 alt=0 func=SD0_DAT3
As i see, 2-3 pins are SDA1,SCL1
if i add cmdline.txt for change to i2c 44-45
dtoverlay=i2c1-bcm2708,sda1_pin=44,scl1_pin=45,pin_func=6
raspi-gpio get output this :
  GPIO 02: level=1 fsel=0 alt=  func=INPUT
  GPIO 03: level=1 fsel=0 alt=  func=INPUT
  GPIO 44: level=0 fsel=6 alt=2 func=SDA1
  GPIO 45: level=0 fsel=6 alt=2 func=SCL1
but it doesnt work. I can see 44-45 SDA1-SCL1 in final raspi-gpio get but when i run hwclock -r or sudo i2cdetect -y 1 doesnt work. I mean hwclock says no rtc, i2cdetect output is shows no registered number
PhilE
Re: Compute Module 3 Can't Change i2c1 pins to 44-45
Wed Nov 01, 2017 10:08 am
The GPIO configuration looks correct, so the overlay has done its job. I'm assuming that /dev/i2c-1 exists, and that i2cdetect gives the following output:
[email protected]:~ $ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
My guess is that you don't have any pullups on the I2C lines. GPIOs 2 and 3 have built-in weak pull-ups of 50 kohms, which is probably why you've got away with it before, but you really need something stronger - say 1.8 kohms. GPIOs 44 and 45 have no built-in pull, so an external pull-up is absolutely necessary.
massaimara98
Wed Nov 01, 2017 8:46 pm
What can i say... You are awesome thank you...
Return to “Device Tree”
Who is online
Users browsing this forum: No registered users and 4 guests
