neilneil2000
gpio-poweroff 100ms cycle on shutdown
Mon Oct 02, 2017 1:19 pm
I have set up the gpio-poweroff overlay on my Raspberry Pi Zero W but when I shutdown (either -h or -P) rather than a straight transition to logic high, there seems to be a single 5Hz cycle. It is repeatable.
I am wondering if:
- this is the same on all models of RaspberryPi?
- this is expected bahaviour?
- if expected, is this desired behaviour or the result of a limitation?
PhilE
Re: gpio-poweroff 100ms cycle on shutdown
Mon Oct 02, 2017 1:30 pm
gpio-poweroff is a pure software module that only talks to hardware via other drivers. As such (and excluding a patch to allow it to override an exists power-off vector) it is completely cross-platform.
The 100ms pulse before the sustained activate signal is by design - the driver sets the pin on, waits for 100ms, then off, waiting for another 100ms, then high again. However, I couldn't find an explanation for why this might be desirable.
Return to “Device Tree”
Who is online
Users browsing this forum: No registered users and 1 guest
