PhilE
Re: ads7846 on spi1
Fri May 11, 2018 8:48 am
That's recent enough - it's the last firmware released before the switch to the 4.14 kernel tree.
Start by renaming the compiled overlay to "ads7846-spi1.dtbo" to distinguish it from the original, comment out the current overlay directive in config.txt and replace it with:
dtoverlay=ads7846-spi1
Verify that the driver module gets loaded. Then add the parameters, leaving out keep_vref_on, and splitting the line when it reaches 80 characters.
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 8:52 am
its the firmware delivered with the screen, also with the same parameters.
Perhaps the supplier of the screen has modified the standard overlay - can you upload the original .dtbo (or .dtb) somewhere so I can take a look?
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 8:59 am
Start by renaming the compiled overlay to "ads7486-spi1.dtbo" to distinguish it from the original, comment out the current overlay directive in config.txt and replace it with:
shouldn't be it :
 dtoverlay=ads7486-spi1
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:04 am
sure https://www.dropbox.com/sh/pdkji46ui8ae ... E2hva?dl=0
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 9:11 am
shouldn't be it :
No, this was correct - it was the rename I got wrong (now corrected).
Robin466
Re: ads7846 on spi1
ignore this post
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:21 am
shouldn't be it :
ah that did the trick, overlay is now loaded !
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 9:26 am
The default ads7846 overlay was unmodified, so it had no "keep_vref_on" parameter. This should not have prevented it from being loaded, but it was an error.
Using this configuration:
dtdebug=1
dtoverlay=spi1-1cs,cs0_pin=16,cs0_spidev=off
dtoverlay=ads7846-spi1,penirq=5,penirq_pull=2,speed=50000,swapxy=0
dtparam=pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
post the "sudo vcdbg log msg" output (which will now be more verbose) and the output from "ls -l /boot/overlays/ads7846*".
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:29 am
dtdebug=1
i allready did that without dtdebug=1, but Touch seems to be working right now.
However, its upside down, can raspberry change its orientation ?
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 9:33 am
Cool - our messages crossed.
Please describe carefully what is upside down relative to what.
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:38 am
thank you for your patience and help during this fase ! :D
well if i press top left corner of the touch the cursor moves to de right lower corner so touch is upside down relative to the LCD (have rotated the image Display_rotate=0 (standard is display_rotate=2)
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 9:41 am
With "display_rotate=2" does the touchscreen match the image (but with a rotated image)?
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 9:44 am
Does "lcd_rotate=2" (instead of "display_rotate=0") work (see viewtopic.php?p=815847#p815847)?
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:48 am
Yes, Correct only seems to be a little of in the middle, but calibration will do the trick i gues :-)
how ever when i put the rotate back to 0 the touch is upside down again
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 9:52 am
same story as down below.... :o :(
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 11:24 am
i tried this procedure, however doesn't seem to be working right now...
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 11:29 am
I've asked @jamesh if he has any suggestions.
Re: ads7846 on spi1
Fri May 11, 2018 11:45 am
So this is a SPI based touchscreen, on an LCD panel, but not one of ours?
Quite a few TS drivers I've seen have DT parameters to do swaps/mirrors. Quick look at the kernel driver shows there is a boolean DT parameter
`swap-xy`
Does that work? (See drivers/input/touchscreen/ads7846.c for all the DT parameters)
PhilE
Re: ads7846 on spi1
Fri May 11, 2018 11:57 am
The swap-xy parameter swaps the axes - x becomes y and vice versa, whereas we want to invert both axes.
As I understand it, lcd_rotate reprograms the panel to change the orientation, which is more efficient than rotating the framebuffer, but I can see why it may not work for an arbitrary display.
You may instead be able to tell the Linux/X input system to invert both axes.
Robin466
Re: ads7846 on spi1
Fri May 11, 2018 12:12 pm
guys thank you both for you amazing support i really appreciate it :)
but the solution to this problem was super simple, just as simple as just calibrating the touchscreen :oops:
everything is working fine now, and this methode is proving to be working !
cheers,
Robin
Return to “Device Tree”
