Hope I can get some help here
I'm trying to compile the below devicetree overlay to enable and position the full RX/TX/RTS/CTS pins on the (ttyAMA0) UART0 on GPIO30-33
So far I've put UART1 on 14/15 OK
I've temporarily removed the serial console from the boot cmdline.txt
My kernel running on Jessie is :
root@raspberrypi:~/device-tree# uname -a
Linux raspberrypi 4.1.21+ #872 Wed Apr 6 17:27:13 BST 2016 armv6l GNU/Linux
Device tree compiler is :
root@raspberrypi:~/device-tree# dtc --version
Version: DTC 1.4.0
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2708";
fragment@0 {
target = <&uart0>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&uart0_pins>;
status = "okay";
fragment@1 {
target = <&gpio>;
__overlay__ {
uart0_pins: uart0_pins {
brcm,pins = <30 31 32 33>; /* UART0: CTS0 RTS0 TX0 RX0 */
brcm,function = <7>; /* ALT3 */
brcm,pull = <0 0 0 2>;
fragment@2 {
target-path = "/aliases";
__overlay__ {
serial0 = "/soc/uart@7e201000";
https://www.kernel.org/doc/Documentatio ... 5-gpio.txt
This is how I'm compiling it (no errors produced when run):
dtc -@ -I dts -O dtb -o uart0-full.dtbo uart0-full-overlay.dts
cp uart0-full.dtbo /boot/overlays/uart0-full.dtbo
002104.433: Loaded overlay 'mmc'
002127.772: Failed to load overlay 'uart0-full'
002135.698: Loaded overlay 'uart1'
002135.716: dtparam: txd1_pin=14
002136.186: dtparam: rxd1_pin=15
002136.746: dtparam: i2c1=on
002163.148: Loaded overlay 'i2c-rtc'
002163.165: dtparam: ds1307=true
ttyAMA0 appears in /dev, but raspi-gpio doesn't report it working either (no great surprise there!)
Here's the config, dmesg etc
http://pastebin.com/KYWdHfDU
So I'm a bit stuck on what's not working here, are there any gurus that can help?
Andrew.
