Pololu Maestro Servo controller doesn't work
Posted: Sun Sep 25, 2016 3:35 pm
by nautilus27
I took this official Pololu source as a reference to connect things: https://www.pololu.com/docs/0J40/1.a
And then I found this source: https://github.com/FRC4564/Maestro/blob ... /README.md which seems like very well implemented but the thing is it doesn't work.
Do you recommand any diagnostics to pinpoint the source of the problem?
P.S. the controller is connected over USB. In the lsusb output i can see the controller as "Bus 001 Device 008: ID 1ffb:0089
Re: Pololu Maestro Servo controller doesn't work
Posted: Sun Sep 25, 2016 5:09 pm
by PhilE
This is not a Device Tree issue (USB doesn't use DT), and it sounds like you'd be better off in the Advanced users forum. Be prepared to say what you have tried, what you expect and what actually happens, as a very minimum.
