freefish
(need help)stmpe610-i2c over i2c-gpio
Thu Jun 02, 2016 2:16 pm
I want to use stmpe610 on i2c-gpio interface(/dev/i2c-3)
I found a solution in this post
/viewtopic.php?f=107&t=148572&p=978332
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
        [email protected] {
                target = <&i2c1>;
                __overlay__ {
                        compatible = "brcm,bcm2708-i2c";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        stmpe610_pins: stmpe610_pins {
                                brcm,pins = <23>;
                                brcm,function = <0>; /* in */
                                /*brcm,pull = <2 0>; / * pullup none */
        [email protected] {
                target = <&i2c1>;
                __overlay__ {
                        /* needed to avoid dtc warning */
                        #address-cells = <1>;
                        #size-cells = <0>;
                        status = "okay";
                        [email protected] {
                                #size-cells = <0>;
                                compatible = "st,stmpe610";
                                reg = <0x41>;
                                irq-gpio = <&gpio 23 0x2>; /* IRQF_TRIGGER_FALLING */
                                interrupts = <23 0x2>; /* high-to-low edge triggered */
                                interrupt-parent = <&gpio>;
                                interrupt-controller;
                                stmpe_touchscreen {
                                        compatible = "st,stmpe-ts";
                                        st,sample-time = <4>;
                                        st,mod-12b = <1>;
                                        st,ref-sel = <0>;
                                        st,adc-freq = <2>;
                                        st,ave-ctrl = <3>;
                                        st,touch-det-delay = <4>;
                                        st,settling = <2>;
                                        st,fraction-z = <7>;
                                        st,i-drive = <0>;
Someone help me rewrite this DTS file to use I2C-GPIO(/dev/i2c-3) Interface ?
freefish
Re: (solved)stmpe610-i2c over i2c-gpio
Fri Jun 03, 2016 10:38 am
/dts-v1/;
/plugin/;
        [email protected] {
                target = <&i2c_gpio>;
                __overlay__ {
                        compatible = "i2c-gpio";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                                brcm,pins = <25>;
        [email protected] {
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                        [email protected] {
                                #size-cells = <0>;
                                reg = <0x41>;
                                irq-gpio = <&gpio 25 0x2>; /* IRQF_TRIGGER_FALLING */
                                interrupts = <25 0x2>; /* high-to-low edge triggered */
                                stmpe_touchscreen {
                                        st,mod-12b = <1>;
                                        st,ref-sel = <0>;
                                        st,adc-freq = <2>;
                                        st,ave-ctrl = <3>;
                                        st,settling = <2>;
                                        st,i-drive = <0>;
this is my stmpe610.dts file
I compiled it with
dtc [email protected] -I dts -O dtb -o stmpe610.dtbo stmpe610.dts
[email protected]:/boot/overlays $ sudo dtc [email protected] -I dts -O dtb -o stmpe610.dtbo stmpe610.dts
Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property
sudo dtoverlay stmpe610.dtbo
* Failed to apply overlay '0_stmpe610'
dmesg
[37251.777413] of_resolve_phandles: Could not find symbol 'i2c_gpio'
[37251.777441] create_overlay: Failed to resolve tree
PhilE
Re: (need help)stmpe610-i2c over i2c-gpio
Fri Jun 03, 2016 7:19 pm
That overlay is a bit confused - it's presumably trying to create an i2c-gpio node, but it's referring to it as if it is already there. Take a look at the existing i2c-gpio overlay (https://github.com/raspberrypi/linux/bl ... verlay.dts) to see how it should be created.
If you are loading the i2c-gpio and expecting it to be accessible to other overlays then it won't be. You have to go to certain lengths to make that possible.
If I2C were a point-to-point link then I would recommend creating a dedicated instance of i2c-gpio for your touchscreen, but since it is a bus that could have other devices hung off it then I think it would be better to get i2c-gpio to make itself available to other overlays.
You can have a go by patching arch/arm/boot/dts/overlays/i2c-gpio-overlay.dts like this:
diff --git a/arch/arm/boot/dts/overlays/i2c-gpio-overlay.dts
index 2a2dc98..b72b32e 100644
--- a/arch/arm/boot/dts/overlays/i2c-gpio-overlay.dts
+++ b/arch/arm/boot/dts/overlays/i2c-gpio-overlay.dts
@@ -19,6 +19,21 @@
+       [email protected] {
+               target-path = "/aliases";
+               __overlay__ {
+                       i2c_gpio = "/[email protected]";
+               target-path = "/__symbols__";
+               __overlay__ {
        __overrides__ {
                i2c_gpio_sda = <&i2c_gpio>,"gpios:4";
                i2c_gpio_scl = <&i2c_gpio>,"gpios:16";
and using this as your stmpe610 overlay:
/dts-v1/;
/plugin/;
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                                brcm,pins = <25>;
        [email protected] {
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                        stmpe610: [email protected] {
                                #size-cells = <0>;
                                reg = <0x41>;
                                stmpe_touchscreen {
                                        st,mod-12b = <1>;
                                        st,ref-sel = <0>;
                                        st,adc-freq = <2>;
                                        st,ave-ctrl = <3>;
                                        st,settling = <2>;
                                        st,i-drive = <0>;
        __overrides__ {
                irq_pin = <&stmpe610>, "irq-gpio:4",
                          <&stmpe610_pins>, "brcm,pins:0";
I've tested this as far as verifying that it appears to do the right thing using dtmerge, but I haven't tried it on real hardware.
Note that I've moved the default irq_pin to 25 so as not to clash with the default i2c-gpio pins.
PhilE
Fri Jun 03, 2016 7:20 pm
P.S. If this works for you then I'll patch the standard i2c-gpio overlay in the same way.
freefish
Sat Jun 04, 2016 2:40 am
Yes! It works! Thank you very much!
[email protected]:~ $ dmesg | grep stmpe
[ 6.566124] stmpe-i2c 3-0041: stmpe610 detected, chip id: 0x811
[ 7.177145] input: stmpe-ts as /devices/platform/[email protected]/i2c-3/3-0041/stmpe-ts/input/input4
[email protected]:~ $ sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: Logitech USB Receiver
/dev/input/event1: Logitech USB Receiver
/dev/input/event2: gpio_ir_recv
/dev/input/event3: MCE IR Keyboard/Mouse (gpio-rc-recv)
/dev/input/event4: stmpe-ts
Select the device event number [0-4]:
PhilE
Mon Jun 06, 2016 8:34 am
I've pushed the amended i2c-gpio overlay into the rpi-4.4.y source tree; it will be included in subsequent releases.
Return to “Device Tree”
