wuilmerj24
Thermistor 100k NTC B 3950
Thu May 05, 2016 9:44 pm
Hello, I have 100k UN 3950 B NTC sensor, will be compatible with Pi 2 ?
brekee12
Re: Thermistor 100k NTC B 3950
Fri May 06, 2016 12:47 am
It depends what you want to do with it. NTC is a temperature variable resistor. If you have wanted to control the processor temperature with a fun, you could assemble an analog circuit powered by pi supply.
In case you want to measure a temperature you must have to connect an AD converter to the pi and NTC must be connected to the ADC. But be careful, NTC has a logaritmic characteristic, ADs has linear; so you need linearisation circuitry with resistors. NTC-s are most sensible to temperature sensors, so do not be afraid from the first difficulties.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
Elan
Thu Sep 27, 2018 1:30 pm
Any one can advise me how to connect 100K ntc thermistor dupont connector using raspberry pi 3
pcmanbob
Thu Sep 27, 2018 2:23 pm
The answer is the same as above you need an analogue to digital converter because the Thermistor is an analogue device and the pi has only digital i/o.
just one example I found of how it could be done.
https://www.abelectronics.co.uk/kb/arti ... hermistors
Return to “Device Tree”
