aBUGSworstnightmare
Re: RPi 3 missing from dt-blob.dts
Tue Apr 26, 2016 7:40 am
o.k. it's not using the overlay but this blob does the job:
# For use with KD50G21-40NT-A1 module only
# on RPi 3 V1.1 - Jessie
dtparam=audio=on
gpu_mem=256
max_usb_current=1
# Overscan Information
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=800
framebuffer_height=480
# DPI interface comsumes all GPIO of the RPi
# Disable SPI and I2C
dtparam=spi=off
dtparam=i2c_arm=off
# Enable DPI
enable_dpi_lcd=1
# Make DPI default output
display_default_lcd=1
# custom HDMI mode
# https://www.raspberrypi.org/forums/viewtopic.php?p=613926#p613926
# https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
dpi_group=2
dpi_mode=87
# DPI output format definitions
# https://www.raspberrypi.org/forums/viewtopic.php?p=628061#p628061
# DPI structure: https://www.raspberrypi.org/forums/viewtopic.php?p=617719#p617719
# output_format:
#   1: DPI_OUTPUT_FORMAT_9BIT_666
#   2: DPI_OUTPUT_FORMAT_16BIT_565_CFG1
#   3: DPI_OUTPUT_FORMAT_16BIT_565_CFG2
#   4: DPI_OUTPUT_FORMAT_16BIT_565_CFG3
#   5: DPI_OUTPUT_FORMAT_18BIT_666_CFG1
#   6: DPI_OUTPUT_FORMAT_18BIT_666_CFG2
#   7: DPI_OUTPUT_FORMAT_24BIT_888
# rgb_order:
#   1: DPI_RGB_ORDER_RGB
#   2: DPI_RGB_ORDER_BGR
#   3: DPI_RGB_ORDER_GRB
#   4: DPI_RGB_ORDER_BRG
# output_enable_mode:
#   0: DPI_OUTPUT_ENABLE_MODE_DATA_VALID
#   1: DPI_OUTPUT_ENABLE_MODE_COMBINED_SYNCS
# invert_pixel_clock:
#   0: RGB Data changes on rising edge and is stable at falling edge
#   1: RGB Data changes on falling edge and is stable at rising edge
# hsync polarity:
#   0: default for HDMI mode
#   1: inverted
# vsync polarity:
#   1: inverted
# output_enable_polarity:
#   1: inverted
# hsync phase:
#   0: rising edge
#   1: falling edge
# vsync phase:
#   0: rising edge
#   1: falling edge
# output_enable phase:
#   0: rising edge
#   1: falling edge
dpi_output_format=454661
# HDMI timing definitions
#https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
# hdmi_timings= <h_active_pixels>
#		  LCD module horizontal resolution
#               <h_sync_polarity>
# 		  0: active low
#		  1: active high
#               <h_front_porch>
#		<h_sync_pulse>
#		<h_back_porch>
#		<v_active_lines>
#		  LCD module vertical resolution
#		<v_sync_polarity>
# 		  0: active low
#		  1: active high
#		<v_front_porch>
#		<v_sync_pulse>
#		<v_back_porch>
#		<v_sync_offset_a>
#		<v_sync_offset_b>
#		<pixel_rep>
#		<frame_rate>
#		  screen refrech rate (50/60Hz supported only!)#
#		<interlaced>
#		<pixel_freq>
#		  calculates as: <h_active_pixels> * <v_active_lines> * <frame_rate>
#		<aspect_ratio>
#		  HDMI_ASPECT_4_3 = 1
#		  HDMI_ASPECT_14_9 = 2
#		  HDMI_ASPECT_16_9 = 3
#		  HDMI_ASPECT_5_4 = 4
#		  HDMI_ASPECT_16_10 = 5
#		  HDMI_ASPECT_15_9 = 6
#		  HDMI_ASPECT_21_9 = 7
#		  HDMI_ASPECT_64_27 = 8
#hdmi_timing for KD50G21-40NT-A1 configuration notes
#h_active_pixels = 800
#h_sync_polarity = 0
#h_front_porch = 40
#h_sync_pulse = 48
#h_back_porch = 88
#v_active_lines = 480
#v_sync_polarity = 0
#v_front_porch = 13
#v_sync_pulse = 3
#v_back_porch = 32
#v_sync_offset_a = 0
#v_sync_offset_b = 0
#pixel_rep = 0
#frame_rate = 60
#interlaces = 0
#pixel_freq = 32000000
#aspect_ratio = 6
hdmi_timings=800 0 40 48 88 480 0 13 3 32 0 0 0 60 0 32000000 6
adafruit5in_18bitdpi_blob.zip
Compiled blob for 18-bit DPI use with Adafruit Kippah 5in TFT display (18-bit colours)
(4.3 KiB) Downloaded 247 times
Compiled it on latest Jessie; should work with ubuntu mate as well.
PhilE
Tue Apr 26, 2016 7:58 am
The vga666 overlay is effectively a dpi18 overlay.
6by9
Tue Apr 26, 2016 8:39 am
PhilE wrote:The vga666 overlay is effectively a dpi18 overlay.
Except missing the Clock and DEN lines on GPIO 0 & 1.
I had taken your dpi24 overlay and trimmed out the last 6 GPIOs to make a true dpi18 overlay, but haven't set my DPI screen up again to test.
Milliways
Thu Jan 19, 2017 5:41 am
6by9 wrote:Update done. https://github.com/raspberrypi/firmware ... t-blob.dts now has pins_3b1 and pins_3b2 sections for the Pi3.
Please note that you will have to use "sudo rpi-update" to get the latest firmware as well to match this blob. Old firmware with a compiled version of this blob will almost certainly result in invalid pin setup.
PS Nice displays :D
I have tried to download the file https://github.com/raspberrypi/firmware ... t-blob.dts
There seems to be no Download option, although there is a `Open this file in GitHub Desktop` button. Clicking this just seems to want to install GitHub Desktop, although it is already installed.
I can't make head nor tail of GitHub Desktop! I have tried reading the instructions, but it only seems to want to create new branches, and I am more comfortable just using git at the command line.
6by9
Thu Jan 19, 2017 6:52 am
Milliways wrote:I have tried to download the file https://github.com/raspberrypi/firmware ... t-blob.dts
Hit the "raw" button to get the raw data.
wget https://raw.githubusercontent.com/raspberrypi/firmware/master/extra/dt-blob.dts
Or if you prefer the command line then clone the repo
git clone --depth 1 https://github.com/raspberrypi/firmware.git
There's also an option at the root of the repo (https://github.com/raspberrypi/firmware) to download a ZIP copy of the whole repo. Same's true for any project on github.
TSTRasp
Sun Aug 20, 2017 5:35 am
Hello, I am a poor guy struggling on a 4.3" DPI display on Pi 3 (viewtopic.php?f=38&t=191081&p=1200453#p1200453).
I am really inspired by reading this post. I followed aBUGSworstnightmare's instruction exactly today, only with Raspbian Stretch other than Jessie. However, I found I can only see something when I set dpi_mode=16. It will be completely nothing if I use dpi_mode=87.
Could someone help me out please? What might be the difference between these dpi modes? Thanks.
T
aBUGSworstnightmare
Mon Aug 21, 2017 5:52 am
No need to mess around with the dt-blob! Simply use the 24bit DPI interface to configure the I/O.
# enable 24-bit DPI interface
dtoverlay=dpi24
# Enable DPI
enable_dpi_lcd=1
procount
Wed Jan 10, 2018 11:03 am
Someone asked me about using the Adafruit Kippah with PINN, but the dt_blob that Adafruit refer to (ref to aBUGsworstnightmare in this thread ) is not compatible:
https://learn.adafruit.com/adafruit-dpi ... stallation
We've only tested this device tree overlay/firmware with Raspbian. Since its a bit of a hack, it doesn't work with the native pre-boot 'NooBS' screen. However, it does come up immediately with Raspbian (e.g. you get to see the rainbow square screen)
Have things moved on? Is it possible to use the dpi24 overlay with NOOBS/PINN now for this display? Or is there some issue with the old firmware we use in NOOBS/PINN that might still be a problem? Can anyone test?
(NOTE: PINN works with the VGA666 overlay for Gert's VGA board, but I needed to do a little mod first to prevent the GPIO from triggering safe mode when the VGA666 board is fitted, but it still requires 'disablesafemode' option in recovery.cmdline. These DPI devices might still not work with NOOBS directly).
6by9
Wed Jan 10, 2018 11:31 am
The Adafruit dt-blob.bin has no entries for Pi0W or CM3, so that would be my guess as to why you are having issues.
The dpi24 (or dpi18 seeing as it is only RGB666) overlay should work, but will only start displaying anything when Linux has started and assigned GPIOs. AIUI PINN is run as a bootloader/controller before Linux, therefore that isn't really a useful solution for you.
DPI isn't really any different from Gert's VGA666 other than also needing GPIOs 0&1 for additional control signals.
procount
Wed Jan 10, 2018 12:59 pm
Actually, PINN (like NOOBS) is a small buildroot linux environment in it's own right, and VGA666 overlay does work with it. So I will advise to try those overlays instead and see if they work. Thanks.
Return to “Device Tree”
