pi@raspberrypi:~ $ raspi-gpio get 14
GPIO 14: level=1 fsel=4 alt=0 func=TXD0
pi@raspberrypi:~ $ raspi-gpio get 15
GPIO 15: level=1 fsel=4 alt=0 func=RXD0
dtoverlay=pi3-miniuart-bt
enable_uart=1
● hciuart.service - Configure Bluetooth Modems connected by UART
Loaded: loaded (/lib/systemd/system/hciuart.service; enabled)
Active: activating (start) since Fri 2016-09-23 14:46:04 UTC; 33s ago
Control: 420 (hciattach)
CGroup: /system.slice/hciuart.service
└─420 /usr/bin/hciattach /dev/serial1 bcm43xx 460800 noflow -
Active: failed (Result: exit-code) since Fri 2016-09-23 14:46:42 UTC; 1min 38s ago
Process: 420 ExecStart=/usr/bin/hciattach /dev/serial1 bcm43xx 460800 noflow - (code=exited, status=1/FAILURE)
core_freq=250
@PhilE,PhilE wrote:With pi3-miniuart-bt applied, enable_uart=1 does nothing at all because the uart is enabled by default.
dtoverlay=pi3-disable-bt
sudo systemctl disable hciuart
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=....
sudo service disable hciuart
disable: unrecognized service
Try running:yoodog wrote:but running
gave me this
A bad '/boot/cmdline.txt' file can crash a Pi. The only part you should remove from this file is "console=serial0,115200", the rest of the file must stay exactly as it is. The '/boot/cmdline.txt' file must only contain 1 line, take care not to split the line when editing, and do not try to add comments.yoodog wrote:and removed this from cmdline.txt.
after reboot Pi fails with VFS panic - odd, will try again on a clean install of latest noob.
Well spotted - I've corrected my post. Thanks.sudo systemctl disable hciuart
ls -l /dev/serial*
PhilE wrote:Those 54 GPIOs are the full complement of those provided by the BCM283x. TXD0 and RXD0 are on GPIOs 32 and 33 because ttyAMA0 is used to drive the Bluetooth modem on a Pi3. I can also tell from that output that you don't have "enable_uart=1" in config.txt, otherwise TXD1 and RXD1 (ttyS0) would be selected on GPIOs 14 and 15.
Not possible. The only accessible GPIO pins that can be used to connect to the Pi's UARTs are physical pins 8 &10, so you can only connect to 1 UART. This applies to all models of the Pi, except the Compute Module series.rodizio wrote:Now I would like to:
- Disable BT and have both the hardware and software serial ports accessible on some pins for external connections.
- Do the same on the Pi Zero and Pi1/2
Is that possible somehow?
