MaxT73
Using official touchscreen 7' and RFID reader MFRC522
Mon Jan 04, 2016 2:29 pm
Hi Raspberry community!
I'm on a project with my raspberry pi2 with rasbpian Jessie installed.
I connected the official touchscreen (https://www.raspberrypi.org/blog/the-ea ... i-display/), that work perfectly.
I used this tutorial: https://github.com/mxgxw/MFRC522-python to add a RFID Reader MFRC522
Howerver, to make it work I had to add the following line in /boot/config.txt : device_tree=on . And this line disable the touch part of the screen.
Would anyone have an idea to have both working together?
Thanks for your help,
Regards,
Maxime
6by9
Re: Using official touchscreen 7' and RFID reader MFRC522
Mon Jan 04, 2016 4:21 pm
device tree is enabled by default on all releases since about March 2015. You shouldn't need to enable it manually.
PhilE
Tue Jan 05, 2016 9:48 pm
Yes, device_tree=on will actually disable Device Tree, because the firmware will think you want it to load a DT file called "on" (which will fail). As 6by9 says, DT is enabled by default (device_tree= will disable it, but you don't want to do that).
MaxT73
Thu Jan 07, 2016 4:54 pm
Thank u guys,
Your posts made me think to the issue differently.
I had forgotten a step in my configuration.
The right tutorial to use for having a MFRC522 working on raspberry, without perturbing any other device is this one:
http://raspmer.blogspot.de/2015/07/how- ... pbian.html
All the other tutorials don't say to add "dtoverlay=spi-bcm2708" to the file /boot/config.txt
Cheers,
Maxime.
_ThaNerd_
Thu Dec 14, 2017 7:01 pm
How did you connect both touchscreen and rfid? I am trying to find the schematics for the pin connection...
_ThaNerd_
Sun Dec 24, 2017 7:10 pm
So did you manage to make this setup work? I can't get the touchscreen and rfid work together I get a conflict error on the spi...
Thank u guys,
Cheers,
Maxime.
Return to “Device Tree”
