aklimaj
CM4 BQ25890 dtoverlay help
Thu Jul 22, 2021 12:15 am
I have a custom CM4 board with a BQ25890 TI charger connected to I2C0 on pins 44 and 45. I can see the chip on i2cdetect on bus 0. I am trying to use a dtoverlay to load the BQ25890 module without success.
Here is my overlay.
// Overlay for bq25890
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835";
        fragment@0 {
                target = <&i2c0>;
                __overlay__ {
                #address-cells = <1>;
                #size-cells = <0>;
                bq25890: bq25890@6a {
                        compatible = "ti,bq25890";
                        reg = <0x6a>;
                        //interrupt-parent = <23>;
                        //interrupts = <1>;
                        ti,battery-regulation-voltage = <4200000>;
                        ti,charge-current = <6000000>;
                        ti,termination-current = <50000>;
                        ti,precharge-current = <128000>;
                        ti,minimum-sys-voltage = <3600000>;
                        ti,boost-voltage = <5000000>;
                        ti,boost-max-current = <1000000>;
                        ti,use-ilim-pin;
                        ti,thermal-regulation-threshold = <120>;
                        status = "okay";
I can compile it with no errors.
sudo dtc -@ -I dts -O dtb -o /boot/overlays/bq25890.dtbo /boot/bq25890-overlay.dts
And it looks like it loads.
005644.167: brfs: File read: 1462 bytes
005648.637: brfs: File read: /mfs/sd/overlays/i2c0.dtbo
005661.891: Loaded overlay 'i2c0'
005661.904: dtparam: pins_44_45=on
005686.575: brfs: File read: 1785 bytes
005696.154: brfs: File read: /mfs/sd/overlays/bq25890.dtbo
005701.696: Loaded overlay 'bq25890'
005726.069: brfs: File read: 826 bytes
But it does not appear to be running. Any suggestions?
PhilE
Re: CM4 BQ25890 dtoverlay help
Thu Jul 22, 2021 7:36 am
Does the device appear in the output of "i2cdetect -y 0"?
PhilE
Thu Jul 22, 2021 8:26 am
I think your problem is that there is an I2C multiplexer enabled by default which the i2c0 partially (but not completely) disables.
Out of the box, the "i2c0" DT label and /dev/i2c-0 both select the I2C0 hardware interface enabled on GPIOs 0 & 1. I2C0 on GPIOs 44 & 45 is available at label "i2c_csi_dsi" and /dev/i2c-10.
1. Try removing your use of the i2c0 dtoverlay and then run "sudo i2cdetect -y 10" - the device should appear at address 0x6a.
2. Edit the overlay and change the target of fragment0 to be "&i2c_csi_dsi".
3. Profit!
aklimaj
Thu Jul 22, 2021 7:45 pm
Thanks. I turned dtparam=i2c_vc=on back on and I can see it on i2c 10 and 11.
pi@raspberrypi:~ $ sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@raspberrypi:~ $ sudo i2cdetect -y 10
60: -- -- -- -- -- -- -- -- -- -- 6a -- -- -- -- --
pi@raspberrypi:~ $ sudo i2cdetect -y 11
pi@raspberrypi:~ $
I changed the overlay to &i2c_csi_dsi and it still does not appear to work.
005630.955: brfs: File read: /mfs/sd/overlays/bq25890.dtbo
005636.481: Loaded overlay 'bq25890'
005651.205: brfs: File read: 778 bytes
Maybe the kernel driver isn't compiled and present?
PhilE
Thu Jul 22, 2021 9:03 pm
If you include:
status = "okay";
in the overlay then you won't need the "dtparam=i2c_vc=on".
Can you modprobe the module? Are there any relevant errors in the output of "dmesg"?
6by9
Fri Jul 23, 2021 6:50 am
status = "okay"
needs to be on the i2c0if and i2c0mux nodes, not i2c_csi_dsi or i2c0.
The fact that i2cdetect shows the address and not UU means the kernel driver hasn't been loaded to claim that device.
grep bq25890 /lib/modules/`uname -r`/*
will tell you if the compatible string is found for your kernel build, and which module is associated. modinfo on that module name will map back the other way.
And ignore i2c-11 - it's a quirk of the way the muxes work that it leaves the parent bus exposed. This makes sense for devices such as PCA9548A where the parent bus is physically accessible, but less sense with i2c-mux-pinctrl where it isn't.
aklimaj
Sat Jul 24, 2021 12:36 am
dmesg shows nothing about the BQ25890.
pi@raspberrypi:~ $ grep bq25890 /lib/modules/`uname -r`/*
grep: /lib/modules/5.10.52-v7l+/kernel: Is a directory
6by9
Sat Jul 24, 2021 10:18 am
Follow https://www.raspberrypi.org/documentati ... uilding.md to build your own kernel.
After doing the "make bcmXXX_defconfig" step you'll want to run "make menuconfig" (text based) or "make xconfig" (X GUI option) to allow adding CHARGER_BQ25890 (with menuconfig, press "/" to allow searching, otherwise it should be under Device Drivers/Power Supply Class Support). Then resume the build steps.
Return to “Device Tree”
