bulbisaur685
Pi Zero - Screen and i2s audio using same pins not working
Sat May 15, 2021 8:41 pm
I am making a specific project for which I needed a Raspberry Pi Zero W and a small screen, as well as an i2s audio device. I am using RetroPie V4.7.1 on the system.
The screen is a high resolution 2.8" display by iUniker that I purchased from Amazon (https://www.amazon.com/Raspberry-iUnike ... 270&sr=8-1)
And the i2s audio decoder is from Adafruit (https://www.adafruit.com/product/3678)
I have both devices connected to the pins on the Pi Zero, but when going into the settings for audio I am getting information that the audio is disabled. I have read that this may have something to do with the screen's touch input settings, which I am not using and would be fine with disabling so that there could be audio output via i2s.
I have messed with the codes in the /boot/config.txt file:
#added lines, likely for iUniker screen
gpio=18=op,dh
gpio=7-8=a2
dtparam=spi=on
dtoverlay=ads7846,penirq=27,swapxy=1,xmin=200,xmax=3850,ymin=200,ymax=3850
display_rotate=3
dtoverlay=mzdpi
framebuffer_width=640
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x07f003
hdmi_timings=480 0 41 20 60 640 0 5 10 10 0 0 0 60 0 32000000 1
#adafruit audio lines below
dtoverlay=hifiberry-dac
dtoverlay=i2s-mmap
#my added lines trying to get audio to work
dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
gpio=18-19=a5
gpio=21=a0
I have also read that enabling this next section is supposed to work, but it black screens the entire system when its enabled and I try going into an emulator or audio settings:
#dtparam=audio=on
And I have tried uncommenting
dtparam=i2s=on
but that seems to have no effect.
There are two .dts files added by the iUniker screen as well, the latter being ridiculously long:
/boot/overlays/mzdpi.dts
/dts-v1/;
        compatible = "brcm,bcm2835";
        fragment@0 {
                target = < 0xffffffff >;
                __overlay__ {
                        pinctrl-names = "default";
                        pinctrl-0 = < 0x01 >;
        fragment@1 {
                __overlay__ {
        fragment@2 {
                __overlay__ {
                        dpi16_pins {
                                brcm,pins = < 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x0c 0x0d 0x0e 0x0f 0x10 0x11 0x14 0x15 0x16 0x17 0x18 >;
                                brcm,function = < 0x06 >;
                                brcm,pull = < 0x00 >;
                                phandle = < 0x01 >;
        __symbols__ {
                dpi16_pins = "/fragment@2/__overlay__/dpi16_pins";
        __fixups__ {
                fb = "/fragment@0:target:0";
                vc4 = "/fragment@1:target:0";
                gpio = "/fragment@2:target:0";
        __local_fixups__ {
                fragment@0 {
                        __overlay__ {
                                pinctrl-0 = < 0x00 >;
/boot/bcm2708-rpi-zero-w.dts
/dts-v1/;
/memreserve/	0x0000000000000000 0x0000000000001000;
	compatible = "raspberrypi,model-zero-w\0brcm,bcm2835";
	model = "Raspberry Pi Zero W";
	interrupt-parent = < 0x01 >;
	#address-cells = < 0x01 >;
	#size-cells = < 0x01 >;
	aliases {
		serial0 = "/soc/serial@7e215040";
		serial1 = "/soc/serial@7e201000";
		audio = "/soc/audio";
		aux = "/soc/aux@7e215000";
		sound = "/soc/sound";
		soc = "/soc";
		dma = "/soc/dma@7e007000";
		intc = "/soc/interrupt-controller@7e00b200";
		watchdog = "/soc/watchdog@7e100000";
		random = "/soc/rng@7e104000";
		mailbox = "/soc/mailbox@7e00b880";
		gpio = "/soc/gpio@7e200000";
		uart0 = "/soc/serial@7e201000";
		sdhost = "/soc/mmc@7e202000";
		mmc0 = "/soc/mmc@7e202000";
		i2s = "/soc/i2s@7e203000";
		spi0 = "/soc/spi@7e204000";
		i2c0 = "/soc/i2c@7e205000";
		uart1 = "/soc/serial@7e215040";
		spi1 = "/soc/spi@7e215080";
		spi2 = "/soc/spi@7e2150c0";
		mmc = "/soc/mmc@7e300000";
		mmc1 = "/soc/mmcnr@7e300000";
		i2c1 = "/soc/i2c@7e804000";
		i2c2 = "/soc/i2c@7e805000";
		usb = "/soc/usb@7e980000";
		leds = "/leds";
		fb = "/soc/fb";
		thermal = "/soc/thermal@7e212000";
		axiperf = "/soc/axiperf";
	chosen {
		bootargs = "coherent_pool=1M 8250.nr_uarts=1";
	thermal-zones {
		cpu-thermal {
			polling-delay-passive = < 0x00 >;
			polling-delay = < 0x3e8 >;
			thermal-sensors = < 0x02 >;
			coefficients = < 0xfffffde6 0x635d8 >;
			phandle = < 0x29 >;
			cooling-maps {
	soc {
		compatible = "simple-bus";
		ranges = < 0x7e000000 0x20000000 0x2000000 >;
		dma-ranges = < 0x40000000 0x00 0x20000000 >;
		phandle = < 0x2a >;
		txp@7e004000 {
			compatible = "brcm,bcm2835-txp";
			reg = < 0x7e004000 0x20 >;
			interrupts = < 0x01 0x0b >;
			status = "disabled";
			phandle = < 0x2b >;
		dma@7e007000 {
			compatible = "brcm,bcm2835-dma";
			reg = < 0x7e007000 0xf00 >;
			interrupts = < 0x01 0x10 0x01 0x11 0x01 0x12 0x01 0x13 0x01 0x14 0x01 0x15 0x01 0x16 0x01 0x17 0x01 0x18 0x01 0x19 0x01 0x1a 0x01 0x1b 0x01 0x1b 0x01 0x1b 0x01 0x1b 0x01 0x1c >;
			interrupt-names = "dma0\0dma1\0dma2\0dma3\0dma4\0dma5\0dma6\0dma7\0dma8\0dma9\0dma10\0dma11\0dma12\0dma13\0dma14\0dma-shared-all";
			#dma-cells = < 0x01 >;
			brcm,dma-channel-mask = < 0x7f35 >;
			phandle = < 0x0a >;
		watchdog@7e100000 {
			compatible = "brcm,bcm2835-pm\0brcm,bcm2835-pm-wdt";
			#power-domain-cells = < 0x01 >;
			#reset-cells = < 0x01 >;
			reg = < 0x7e100000 0x114 0x7e00a000 0x24 >;
			clocks = < 0x03 0x15 0x03 0x1d 0x03 0x17 0x03 0x16 >;
			clock-names = "v3d\0peri_image\0h264\0isp";
			system-power-controller;
			phandle = < 0x22 >;
		cprman@7e101000 {
			compatible = "brcm,bcm2835-cprman";
			#clock-cells = < 0x01 >;
			reg = < 0x7e101000 0x2000 >;
			clocks = < 0x04 0x05 0x00 0x05 0x01 0x05 0x02 0x06 0x00 0x06 0x01 0x06 0x02 >;
			firmware = < 0x07 >;
			phandle = < 0x03 >;
		rng@7e104000 {
			compatible = "brcm,bcm2835-rng";
			reg = < 0x7e104000 0x10 >;
			interrupts = < 0x02 0x1d >;
			phandle = < 0x23 >;
		mailbox@7e00b880 {
			compatible = "brcm,bcm2835-mbox";
			reg = < 0x7e00b880 0x40 >;
			interrupts = < 0x00 0x01 >;
			#mbox-cells = < 0x00 >;
			phandle = < 0x19 >;
		gpio@7e200000 {
			compatible = "brcm,bcm2835-gpio";
			reg = < 0x7e200000 0xb4 >;
			interrupts = < 0x02 0x11 0x02 0x12 >;
			gpio-controller;
			#gpio-cells = < 0x02 >;
			interrupt-controller;
			#interrupt-cells = < 0x02 >;
			phandle = < 0x0f >;
			dpi_gpio0 {
				brcm,pins = < 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09 0x0a 0x0b 0x0c 0x0d 0x0e 0x0f 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18 0x19 0x1a 0x1b >;
				phandle = < 0x2c >;
			emmc_gpio22 {
				brcm,pins = < 0x16 0x17 0x18 0x19 0x1a 0x1b >;
				brcm,function = < 0x07 >;
				phandle = < 0x2d >;
			emmc_gpio34 {
				brcm,pins = < 0x22 0x23 0x24 0x25 0x26 0x27 >;
				brcm,pull = < 0x00 0x02 0x02 0x02 0x02 0x02 >;
				phandle = < 0x2e >;
			emmc_gpio48 {
				brcm,pins = < 0x30 0x31 0x32 0x33 0x34 0x35 >;
				phandle = < 0x2f >;
			gpclk0_gpio4 {
				brcm,pins = < 0x04 >;
				brcm,function = < 0x04 >;
				phandle = < 0x30 >;
			gpclk1_gpio5 {
				brcm,pins = < 0x05 >;
				phandle = < 0x31 >;
			gpclk1_gpio42 {
				brcm,pins = < 0x2a >;
				phandle = < 0x32 >;
			gpclk1_gpio44 {
				brcm,pins = < 0x2c >;
				phandle = < 0x33 >;
			gpclk2_gpio6 {
				brcm,pins = < 0x06 >;
				phandle = < 0x34 >;
			gpclk2_gpio43 {
				brcm,pins = < 0x2b >;
				phandle = < 0x35 >;
			i2c0_gpio0 {
				brcm,pins = < 0x00 0x01 >;
				phandle = < 0x36 >;
			i2c0_gpio28 {
				brcm,pins = < 0x1c 0x1d >;
				phandle = < 0x37 >;
			i2c0_gpio44 {
				brcm,pins = < 0x2c 0x2d >;
				brcm,function = < 0x05 >;
				phandle = < 0x38 >;
			i2c1_gpio2 {
				brcm,pins = < 0x02 0x03 >;
				phandle = < 0x39 >;
			i2c1_gpio44 {
				phandle = < 0x3a >;
			jtag_gpio22 {
				brcm,function = < 0x03 >;
				phandle = < 0x3b >;
			pcm_gpio18 {
				brcm,pins = < 0x12 0x13 0x14 0x15 >;
				phandle = < 0x3c >;
			pcm_gpio28 {
				brcm,pins = < 0x1c 0x1d 0x1e 0x1f >;
				phandle = < 0x3d >;
			pwm0_gpio12 {
				brcm,pins = < 0x0c >;
				phandle = < 0x3e >;
			pwm0_gpio18 {
				brcm,pins = < 0x12 >;
				brcm,function = < 0x02 >;
				phandle = < 0x3f >;
			pwm0_gpio40 {
				brcm,pins = < 0x28 >;
				phandle = < 0x40 >;
			pwm1_gpio13 {
				brcm,pins = < 0x0d >;
				phandle = < 0x41 >;
			pwm1_gpio19 {
				brcm,pins = < 0x13 >;
				phandle = < 0x42 >;
			pwm1_gpio41 {
				brcm,pins = < 0x29 >;
				phandle = < 0x43 >;
			pwm1_gpio45 {
				brcm,pins = < 0x2d >;
				phandle = < 0x44 >;
			sdhost_gpio48 {
				phandle = < 0x0b >;
			spi0_gpio7 {
				brcm,pins = < 0x07 0x08 0x09 0x0a 0x0b >;
				phandle = < 0x45 >;
			spi0_gpio35 {
				brcm,pins = < 0x23 0x24 0x25 0x26 0x27 >;
				phandle = < 0x46 >;
			spi1_gpio16 {
				brcm,pins = < 0x10 0x11 0x12 0x13 0x14 0x15 >;
				phandle = < 0x47 >;
			spi2_gpio40 {
				brcm,pins = < 0x28 0x29 0x2a 0x2b 0x2c 0x2d >;
				phandle = < 0x48 >;
			uart0_gpio14 {
				brcm,pins = < 0x0e 0x0f >;
				phandle = < 0x49 >;
			uart0_ctsrts_gpio16 {
				brcm,pins = < 0x10 0x11 >;
				phandle = < 0x4a >;
			uart0_ctsrts_gpio30 {
				brcm,pins = < 0x1e 0x1f >;
				brcm,pull = < 0x02 0x00 >;
				phandle = < 0x4b >;
			uart0_gpio32 {
				brcm,pins = < 0x20 0x21 >;
				brcm,pull = < 0x00 0x02 >;
				phandle = < 0x4c >;
			uart0_gpio36 {
				brcm,pins = < 0x24 0x25 >;
				phandle = < 0x4d >;
			uart0_ctsrts_gpio38 {
				brcm,pins = < 0x26 0x27 >;
				phandle = < 0x4e >;
			uart1_gpio14 {
				phandle = < 0x4f >;
			uart1_ctsrts_gpio16 {
				phandle = < 0x50 >;
			uart1_gpio32 {
				phandle = < 0x51 >;
			uart1_ctsrts_gpio30 {
				phandle = < 0x52 >;
			uart1_gpio40 {
				brcm,pins = < 0x28 0x29 >;
				phandle = < 0x53 >;
			uart1_ctsrts_gpio42 {
				brcm,pins = < 0x2a 0x2b >;
				phandle = < 0x54 >;
			i2c_slave_gpio18 {
				phandle = < 0x55 >;
			jtag_gpio4 {
				brcm,pins = < 0x04 0x05 0x06 0x0c 0x0d >;
				phandle = < 0x56 >;
			dpi_18bit_gpio0 {
				brcm,pins = < 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09 0x0a 0x0b 0x0c 0x0d 0x0e 0x0f 0x10 0x11 0x12 0x13 0x14 0x15 >;
				phandle = < 0x57 >;
			spi0_pins {
				brcm,pins = < 0x09 0x0a 0x0b >;
				phandle = < 0x0d >;
			spi0_cs_pins {
				brcm,pins = < 0x08 0x07 >;
				phandle = < 0x0e >;
			i2c0 {
				phandle = < 0x10 >;
			i2c1 {
				phandle = < 0x14 >;
			i2s {
				phandle = < 0x0c >;
			sdio_pins {
				phandle = < 0x18 >;
			bt_pins {
				phandle = < 0x09 >;
			uart0_pins {
				brcm,pins = < 0x1e 0x1f 0x20 0x21 >;
				brcm,pull = < 0x02 0x00 0x00 0x02 >;
				phandle = < 0x08 >;
			uart1_pins {
				brcm,pins;
				brcm,function;
				brcm,pull;
				phandle = < 0x12 >;
			audio_pins {
				brcm,pins;
				brcm,function;
				phandle = < 0x1a >;
		serial@7e201000 {
			compatible = "brcm,bcm2835-pl011\0arm,pl011\0arm,primecell";
			reg = < 0x7e201000 0x200 >;
			interrupts = < 0x02 0x19 >;
			clocks = < 0x03 0x13 0x03 0x14 >;
			clock-names = "uartclk\0apb_pclk";
			arm,primecell-periphid = < 0x241011 >;
			cts-event-workaround;
			pinctrl-0 = < 0x08 0x09 >;
			status = "okay";
			phandle = < 0x1b >;
		mmc@7e202000 {
			compatible = "brcm,bcm2835-sdhost";
			reg = < 0x7e202000 0x100 >;
			interrupts = < 0x02 0x18 >;
			clocks = < 0x03 0x14 >;
			dmas = < 0x0a 0x2000000d >;
			dma-names = "rx-tx";
			status = "okay";
			pinctrl-0 = < 0x0b >;
			bus-width = < 0x04 >;
			brcm,overclock-50 = < 0x00 >;
			brcm,pio-limit = < 0x01 >;
			phandle = < 0x24 >;
		i2s@7e203000 {
			compatible = "brcm,bcm2835-i2s";
			reg = < 0x7e203000 0x24 >;
			clocks = < 0x03 0x1f >;
			dmas = < 0x0a 0x02 0x0a 0x03 >;
			dma-names = "tx\0rx";
			#sound-dai-cells = < 0x00 >;
			pinctrl-0 = < 0x0c >;
			phandle = < 0x1d >;
		spi@7e204000 {
			compatible = "brcm,bcm2835-spi";
			reg = < 0x7e204000 0x200 >;
			interrupts = < 0x02 0x16 >;
			#size-cells = < 0x00 >;
			dmas = < 0x0a 0x06 0x0a 0x07 >;
			pinctrl-0 = < 0x0d 0x0e >;
			cs-gpios = < 0x0f 0x08 0x01 0x0f 0x07 0x01 >;
			phandle = < 0x1e >;
			spidev@0 {
				compatible = "spidev";
				reg = < 0x00 >;
				spi-max-frequency = < 0x7735940 >;
				phandle = < 0x58 >;
			spidev@1 {
				reg = < 0x01 >;
				phandle = < 0x59 >;
		i2c@7e205000 {
			compatible = "brcm,bcm2835-i2c";
			reg = < 0x7e205000 0x200 >;
			interrupts = < 0x02 0x15 >;
			pinctrl-0 = < 0x10 >;
			clock-frequency = < 0x186a0 >;
			phandle = < 0x1f >;
		pixelvalve@7e206000 {
			compatible = "brcm,bcm2835-pixelvalve0";
			reg = < 0x7e206000 0x100 >;
			interrupts = < 0x02 0x0d >;
			phandle = < 0x5a >;
		pixelvalve@7e207000 {
			compatible = "brcm,bcm2835-pixelvalve1";
			reg = < 0x7e207000 0x100 >;
			interrupts = < 0x02 0x0e >;
			phandle = < 0x5b >;
		dpi@7e208000 {
			compatible = "brcm,bcm2835-dpi";
			reg = < 0x7e208000 0x8c >;
			clocks = < 0x03 0x14 0x03 0x2c >;
			clock-names = "core\0pixel";
			phandle = < 0x5c >;
		dsi@7e209000 {
			compatible = "brcm,bcm2835-dsi0";
			reg = < 0x7e209000 0x78 >;
			interrupts = < 0x02 0x04 >;
			clocks = < 0x03 0x20 0x03 0x2f 0x03 0x31 >;
			clock-names = "phy\0escape\0pixel";
			clock-output-names = "dsi0_byte\0dsi0_ddr2\0dsi0_ddr";
			phandle = < 0x05 >;
		aux@7e215000 {
			compatible = "brcm,bcm2835-aux";
			reg = < 0x7e215000 0x08 >;
			phandle = < 0x11 >;
		serial@7e215040 {
			compatible = "brcm,bcm2835-aux-uart";
			reg = < 0x7e215040 0x40 >;
			interrupts = < 0x01 0x1d >;
			clocks = < 0x11 0x00 >;
			status = "okay";
			pinctrl-0 = < 0x12 >;
			phandle = < 0x1c >;
		spi@7e215080 {
			compatible = "brcm,bcm2835-aux-spi";
			reg = < 0x7e215080 0x40 >;
			clocks = < 0x11 0x01 >;
			phandle = < 0x5d >;
		spi@7e2150c0 {
			reg = < 0x7e2150c0 0x40 >;
			clocks = < 0x11 0x02 >;
			phandle = < 0x5e >;
		pwm@7e20c000 {
			compatible = "brcm,bcm2835-pwm";
			reg = < 0x7e20c000 0x28 >;
			clocks = < 0x03 0x1e >;
			assigned-clocks = < 0x03 0x1e >;
			assigned-clock-rates = < 0x989680 >;
			#pwm-cells = < 0x02 >;
			phandle = < 0x5f >;
		hvs@7e400000 {
			compatible = "brcm,bcm2835-hvs";
			reg = < 0x7e400000 0x6000 >;
			interrupts = < 0x02 0x01 >;
			phandle = < 0x60 >;
		dsi@7e700000 {
			compatible = "brcm,bcm2835-dsi1";
			reg = < 0x7e700000 0x8c >;
			interrupts = < 0x02 0x0c >;
			clocks = < 0x03 0x23 0x03 0x30 0x03 0x32 >;
			clock-output-names = "dsi1_byte\0dsi1_ddr2\0dsi1_ddr";
			phandle = < 0x06 >;
		csi@7e800000 {
			compatible = "brcm,bcm2835-unicam";
			reg = < 0x7e800000 0x800 0x7e802000 0x04 >;
			interrupts = < 0x02 0x06 >;
			clocks = < 0x03 0x2d >;
			clock-names = "lp";
			power-domains = < 0x13 0x0c >;
			phandle = < 0x61 >;
		csi@7e801000 {
			reg = < 0x7e801000 0x800 0x7e802004 0x04 >;
			interrupts = < 0x02 0x07 >;
			clocks = < 0x03 0x2e >;
			clock-names = "lp";
			power-domains = < 0x13 0x0d >;
			phandle = < 0x62 >;
			port {
				endpoint {
					data-lanes = < 0x01 0x02 >;
		i2c@7e804000 {
			reg = < 0x7e804000 0x1000 >;
			pinctrl-0 = < 0x14 >;
			phandle = < 0x20 >;
		i2c@7e805000 {
			reg = < 0x7e805000 0x1000 >;
			phandle = < 0x15 >;
		vec@7e806000 {
			compatible = "brcm,bcm2835-vec";
			reg = < 0x7e806000 0x1000 >;
			clocks = < 0x03 0x18 >;
			interrupts = < 0x02 0x1b >;
			phandle = < 0x63 >;
		pixelvalve@7e807000 {
			compatible = "brcm,bcm2835-pixelvalve2";
			reg = < 0x7e807000 0x100 >;
			interrupts = < 0x02 0x0a >;
			phandle = < 0x64 >;
		hdmi@7e902000 {
			compatible = "brcm,bcm2835-hdmi";
			reg = < 0x7e902000 0x600 0x7e808000 0x100 >;
			interrupts = < 0x02 0x08 0x02 0x09 >;
			ddc = < 0x15 >;
			clocks = < 0x03 0x10 0x03 0x19 >;
			clock-names = "pixel\0hdmi";
			dmas = < 0x0a 0x11 >;
			dma-names = "audio-rx";
			power-domains = < 0x13 0x05 >;
			hpd-gpios = < 0x0f 0x2e 0x01 >;
			phandle = < 0x65 >;
		usb@7e980000 {
			compatible = "brcm,bcm2708-usb";
			reg = < 0x7e980000 0x10000 0x7e006000 0x1000 >;
			interrupts = < 0x01 0x09 0x02 0x00 >;
			clocks = < 0x16 >;
			clock-names = "otg";
			phys = < 0x17 >;
			phy-names = "usb2-phy";
			interrupt-names = "usb\0soft";
			power-domains = < 0x13 0x06 >;
			phandle = < 0x66 >;
		gpu {
			compatible = "brcm,bcm2835-vc4";
			phandle = < 0x67 >;
		timer@7e003000 {
			compatible = "brcm,bcm2835-system-timer";
			reg = < 0x7e003000 0x1000 >;
			interrupts = < 0x01 0x00 0x01 0x01 0x01 0x02 0x01 0x03 >;
			clock-frequency = < 0xf4240 >;
		interrupt-controller@7e00b200 {
			compatible = "brcm,bcm2835-armctrl-ic";
			reg = < 0x7e00b200 0x200 >;
			phandle = < 0x01 >;
		thermal@7e212000 {
			compatible = "brcm,bcm2835-thermal";
			reg = < 0x7e212000 0x08 >;
			clocks = < 0x03 0x1b >;
			#thermal-sensor-cells = < 0x00 >;
			status = "okay";
			phandle = < 0x02 >;
		v3d@7ec00000 {
			compatible = "brcm,vc4-v3d";
			reg = < 0x7ec00000 0x1000 >;
			interrupts = < 0x01 0x0a >;
			power-domains = < 0x13 0x0a >;
			phandle = < 0x68 >;
		mmc@7e300000 {
			compatible = "brcm,bcm2835-mmc\0brcm,bcm2835-sdhci";
			reg = < 0x7e300000 0x100 >;
			interrupts = < 0x02 0x1e >;
			clocks = < 0x03 0x1c >;
			dmas = < 0x0a 0x0b >;
			phandle = < 0x25 >;
		mmcnr@7e300000 {
			non-removable;
			status = "okay";
			pinctrl-0 = < 0x18 >;
			phandle = < 0x26 >;
		firmwarekms@7e600000 {
			compatible = "raspberrypi,rpi-firmware-kms";
			reg = < 0x7e600000 0x100 >;
			interrupts = < 0x02 0x10 >;
			brcm,firmware = < 0x07 >;
			phandle = < 0x69 >;
		smi@7e600000 {
			compatible = "brcm,bcm2835-smi";
			clocks = < 0x03 0x2a >;
			assigned-clocks = < 0x03 0x2a >;
			assigned-clock-rates = < 0x7735940 >;
			dmas = < 0x0a 0x04 >;
			phandle = < 0x6a >;
		axiperf {
			compatible = "brcm,bcm2835-axiperf";
			reg = < 0x7e009800 0x100 0x7ee08000 0x100 >;
			phandle = < 0x27 >;
		gpiomem {
			compatible = "brcm,bcm2835-gpiomem";
			reg = < 0x7e200000 0x1000 >;
		firmware {
			compatible = "raspberrypi,bcm2835-firmware\0simple-bus";
			#address-cells = < 0x00 >;
			mboxes = < 0x19 >;
			phandle = < 0x07 >;
		power {
			compatible = "raspberrypi,bcm2835-power";
			phandle = < 0x13 >;
		fb {
			compatible = "brcm,bcm2708-fb";
			status = "okay";
			phandle = < 0x6b >;
		mailbox@7e00b840 {
			compatible = "brcm,bcm2835-vchiq";
			reg = < 0x7e00b840 0x3c >;
			interrupts = < 0x00 0x02 >;
			phandle = < 0x6c >;
		vcsm {
			compatible = "raspberrypi,bcm2835-vcsm";
			status = "okay";
			phandle = < 0x6d >;
		audio {
			compatible = "brcm,bcm2835-audio";
			brcm,pwm-channels = < 0x08 >;
			pinctrl-0 = < 0x1a >;
			phandle = < 0x21 >;
		sound {
			phandle = < 0x6e >;
	clocks {
		clock@3 {
			compatible = "fixed-clock";
			reg = < 0x03 >;
			#clock-cells = < 0x00 >;
			clock-output-names = "osc";
			clock-frequency = < 0x124f800 >;
			phandle = < 0x04 >;
		clock@4 {
			reg = < 0x04 >;
			clock-output-names = "otg";
			clock-frequency = < 0x1c9c3800 >;
			phandle = < 0x16 >;
	phy {
		compatible = "usb-nop-xceiv";
		#phy-cells = < 0x00 >;
		phandle = < 0x17 >;
	arm-pmu {
		compatible = "arm,arm1176-pmu";
	fixedregulator_5v0 {
		compatible = "regulator-fixed";
		regulator-name = "5v0";
		regulator-min-microvolt = < 0x4c4b40 >;
		regulator-max-microvolt = < 0x4c4b40 >;
		regulator-always-on;
		phandle = < 0x6f >;
	fixedregulator_3v3 {
		regulator-name = "3v3";
		regulator-min-microvolt = < 0x325aa0 >;
		regulator-max-microvolt = < 0x325aa0 >;
		phandle = < 0x70 >;
	__overrides__ {
		cam0-pwdn-ctrl;
		cam0-pwdn;
		cam0-led-ctrl;
		cam0-led;
		cache_line_size;
		uart0 = [ 00 00 00 1b 73 74 61 74 75 73 00 ];
		uart1 = [ 00 00 00 1c 73 74 61 74 75 73 00 ];
		i2s = [ 00 00 00 1d 73 74 61 74 75 73 00 ];
		spi = [ 00 00 00 1e 73 74 61 74 75 73 00 ];
		i2c0 = [ 00 00 00 1f 73 74 61 74 75 73 00 ];
		i2c1 = "\0\0\0 status";
		i2c2_iknowwhatimdoing = [ 00 00 00 15 73 74 61 74 75 73 00 ];
		i2c0_baudrate = [ 00 00 00 1f 63 6c 6f 63 6b 2d 66 72 65 71 75 65 6e 63 79 3a 30 00 ];
		i2c1_baudrate = "\0\0\0 clock-frequency:0";
		i2c2_baudrate = [ 00 00 00 15 63 6c 6f 63 6b 2d 66 72 65 71 75 65 6e 63 79 3a 30 00 ];
		audio = "\0\0\0!status";
		watchdog = "\0\0\0\"status";
		random = "\0\0\0#status";
		sd_overclock = "\0\0\0,overclock-50:0";
		sd_force_pio = "\0\0\0,force-pio?";
		sd_pio_limit = "\0\0\0,pio-limit:0";
		sd_debug = "\0\0\0,debug";
		sdio_overclock = "\0\0\0%brcm,overclock-50:0\0\0\0\0&brcm,overclock-50:0";
		axiperf = "\0\0\0'status";
		arm_freq;
		act_led_gpio = "\0\0\0(gpios:4";
		act_led_activelow = "\0\0\0(gpios:8";
		act_led_trigger = "\0\0\0(linux,default-trigger";
	memory {
		device_type = "memory";
		reg = < 0x00 0x00 >;
	leds {
		compatible = "gpio-leds";
		phandle = < 0x71 >;
		act {
			label = "led0";
			linux,default-trigger = "mmc0";
			gpios = < 0x0f 0x2f 0x00 >;
			phandle = < 0x28 >;
	__symbols__ {
		cpu_thermal = "/thermal-zones/cpu-thermal";
		soc = "/soc";
		txp = "/soc/txp@7e004000";
		clocks = "/soc/cprman@7e101000";
		rng = "/soc/rng@7e104000";
		dpi_gpio0 = "/soc/gpio@7e200000/dpi_gpio0";
		emmc_gpio22 = "/soc/gpio@7e200000/emmc_gpio22";
		emmc_gpio34 = "/soc/gpio@7e200000/emmc_gpio34";
		emmc_gpio48 = "/soc/gpio@7e200000/emmc_gpio48";
		gpclk0_gpio4 = "/soc/gpio@7e200000/gpclk0_gpio4";
		gpclk1_gpio5 = "/soc/gpio@7e200000/gpclk1_gpio5";
		gpclk1_gpio42 = "/soc/gpio@7e200000/gpclk1_gpio42";
		gpclk1_gpio44 = "/soc/gpio@7e200000/gpclk1_gpio44";
		gpclk2_gpio6 = "/soc/gpio@7e200000/gpclk2_gpio6";
		gpclk2_gpio43 = "/soc/gpio@7e200000/gpclk2_gpio43";
		i2c0_gpio0 = "/soc/gpio@7e200000/i2c0_gpio0";
		i2c0_gpio28 = "/soc/gpio@7e200000/i2c0_gpio28";
		i2c0_gpio44 = "/soc/gpio@7e200000/i2c0_gpio44";
		i2c1_gpio2 = "/soc/gpio@7e200000/i2c1_gpio2";
		i2c1_gpio44 = "/soc/gpio@7e200000/i2c1_gpio44";
		jtag_gpio22 = "/soc/gpio@7e200000/jtag_gpio22";
		pcm_gpio18 = "/soc/gpio@7e200000/pcm_gpio18";
		pcm_gpio28 = "/soc/gpio@7e200000/pcm_gpio28";
		pwm0_gpio12 = "/soc/gpio@7e200000/pwm0_gpio12";
		pwm0_gpio18 = "/soc/gpio@7e200000/pwm0_gpio18";
		pwm0_gpio40 = "/soc/gpio@7e200000/pwm0_gpio40";
		pwm1_gpio13 = "/soc/gpio@7e200000/pwm1_gpio13";
		pwm1_gpio19 = "/soc/gpio@7e200000/pwm1_gpio19";
		pwm1_gpio41 = "/soc/gpio@7e200000/pwm1_gpio41";
		pwm1_gpio45 = "/soc/gpio@7e200000/pwm1_gpio45";
		sdhost_pins = "/soc/gpio@7e200000/sdhost_gpio48";
		sdhost_gpio48 = "/soc/gpio@7e200000/sdhost_gpio48";
		spi0_gpio7 = "/soc/gpio@7e200000/spi0_gpio7";
		spi0_gpio35 = "/soc/gpio@7e200000/spi0_gpio35";
		spi1_gpio16 = "/soc/gpio@7e200000/spi1_gpio16";
		spi2_gpio40 = "/soc/gpio@7e200000/spi2_gpio40";
		uart0_gpio14 = "/soc/gpio@7e200000/uart0_gpio14";
		uart0_ctsrts_gpio16 = "/soc/gpio@7e200000/uart0_ctsrts_gpio16";
		uart0_ctsrts_gpio30 = "/soc/gpio@7e200000/uart0_ctsrts_gpio30";
		uart0_gpio32 = "/soc/gpio@7e200000/uart0_gpio32";
		uart0_gpio36 = "/soc/gpio@7e200000/uart0_gpio36";
		uart0_ctsrts_gpio38 = "/soc/gpio@7e200000/uart0_ctsrts_gpio38";
		uart1_gpio14 = "/soc/gpio@7e200000/uart1_gpio14";
		uart1_ctsrts_gpio16 = "/soc/gpio@7e200000/uart1_ctsrts_gpio16";
		uart1_gpio32 = "/soc/gpio@7e200000/uart1_gpio32";
		uart1_ctsrts_gpio30 = "/soc/gpio@7e200000/uart1_ctsrts_gpio30";
		uart1_gpio40 = "/soc/gpio@7e200000/uart1_gpio40";
		uart1_ctsrts_gpio42 = "/soc/gpio@7e200000/uart1_ctsrts_gpio42";
		i2c_slave_gpio18 = "/soc/gpio@7e200000/i2c_slave_gpio18";
		jtag_gpio4 = "/soc/gpio@7e200000/jtag_gpio4";
		dpi_18bit_gpio0 = "/soc/gpio@7e200000/dpi_18bit_gpio0";
		spi0_pins = "/soc/gpio@7e200000/spi0_pins";
		spi0_cs_pins = "/soc/gpio@7e200000/spi0_cs_pins";
		i2c0_pins = "/soc/gpio@7e200000/i2c0";
		i2c1_pins = "/soc/gpio@7e200000/i2c1";
		i2s_pins = "/soc/gpio@7e200000/i2s";
		sdio_pins = "/soc/gpio@7e200000/sdio_pins";
		bt_pins = "/soc/gpio@7e200000/bt_pins";
		uart0_pins = "/soc/gpio@7e200000/uart0_pins";
		uart1_pins = "/soc/gpio@7e200000/uart1_pins";
		audio_pins = "/soc/gpio@7e200000/audio_pins";
		spi = "/soc/spi@7e204000";
		spidev0 = "/soc/spi@7e204000/spidev@0";
		spidev1 = "/soc/spi@7e204000/spidev@1";
		pixelvalve0 = "/soc/pixelvalve@7e206000";
		pixelvalve1 = "/soc/pixelvalve@7e207000";
		dpi = "/soc/dpi@7e208000";
		dsi0 = "/soc/dsi@7e209000";
		pwm = "/soc/pwm@7e20c000";
		hvs = "/soc/hvs@7e400000";
		dsi1 = "/soc/dsi@7e700000";
		csi0 = "/soc/csi@7e800000";
		csi1 = "/soc/csi@7e801000";
		vec = "/soc/vec@7e806000";
		pixelvalve2 = "/soc/pixelvalve@7e807000";
		hdmi = "/soc/hdmi@7e902000";
		vc4 = "/soc/gpu";
		v3d = "/soc/v3d@7ec00000";
		mmcnr = "/soc/mmcnr@7e300000";
		firmwarekms = "/soc/firmwarekms@7e600000";
		smi = "/soc/smi@7e600000";
		firmware = "/soc/firmware";
		power = "/soc/power";
		fb = "/soc/fb";
		vchiq = "/soc/mailbox@7e00b840";
		vcsm = "/soc/vcsm";
		clk_osc = "/clocks/clock@3";
		clk_usb = "/clocks/clock@4";
		usbphy = "/phy";
		vdd_5v0_reg = "/fixedregulator_5v0";
		vdd_3v3_reg = "/fixedregulator_3v3";
		leds = "/leds";
		act_led = "/leds/act";
The error that typically displays when I attempt to open an emulator or the audio settings is the following:
ALSA lib pcm_dmiz.c:1108:(snd_pcm_dmix_open) unable to open slave
lvl0:  AudioManager Error - Unable to open SDL audio: ALSA: Couldn't open audio device: No such file or directory
I've been struggling with this for about two weeks now and after exhausting Google and forum posts, I'm asking for help. Thanks in advance, let me know if there are any more details needed!
aBUGSworstnightmare
Re: Pi Zero - Screen and i2s audio using same pins not working
Mon May 17, 2021 6:00 am
You're using DPI so you should change 'hdmi_timings' into 'dpi_timings'
See https://www.raspberrypi.org/documentati ... /README.md
Sorry, but which DPI mode do you intend to use?
for I2S you will need GPIO18 to GPIO21. In case of having output only GPIO20 is free. There is no DPI mode which allows this.
Last edited by aBUGSworstnightmare on Mon May 17, 2021 6:41 pm, edited 1 time in total.
PhilE
Mon May 17, 2021 9:39 am
I2S audio appears as "PCM" in the alt function descriptions - PWM is used for the analogue audio out. The command "raspi-gpio funcs 18-21" shows the options for those pins:
GPIO, DEFAULT PULL, ALT0, ALT1, ALT2, ALT3, ALT4, ALT5
18, DOWN, PCM_CLK, SD10, DPI_D14, SPI6_CE0_N, SPI1_CE0_N, PWM0_0
19, DOWN, PCM_FS, SD11, DPI_D15, SPI6_MISO, SPI1_MISO, PWM0_1
20, DOWN, PCM_DIN, SD12, DPI_D16, SPI6_MOSI, SPI1_MOSI, GPCLK0
21, DOWN, PCM_DOUT, SD13, DPI_D17, SPI6_SCLK, SPI1_SCLK, GPCLK1
(Note that my output is from a BCM2711 - yours will be slightly different, but not in a significant way for your use case).
Alt0 is required for I2S - the pin functions will automatically be set by any I2S audio overlay such as "dtoverlay=hifiberry-dac" (no "gpio=" hackery required). "dtoverlay=i2s-mmap" hasn't been needed for years, and you'll probably find that the overlay doesn't exist.
It isn't possible to select two different Alt functions on the same pin - the most recent setting persists, but the kernel will reject an attempted usage if it clashes with an existing usage (it doesn't know about settings applied by the firmware, excluding overlays, so they are overwritten). The key points are:
1. The PCM functions only appear on GPIOs 18-21 (on the 40-pin header - there are some other mappings above GPIO 28)
2. You could probably manage without DIN (GPIO20) for I2S audio, but the others are essential.
3. There is only one 2-channel PWM peripheral on BCM2835. It can appear on the header at GPIOs 12-13 or GPIOs 18-19, but using it (I assume for backlight control) will require that you disable the built-in analogue audio - "dtparam=audio=off".
Return to “Device Tree”
