rasp14
[SOLVED] Multiple dtoverlay=gpio-shutdown line in config.txt
Fri Apr 23, 2021 8:24 am
Is it possible to use multiple GPIO pin to trigger shutdown event via config.txt? I got a button connected to GPIO 3 that act as standard shutdown and power button. In addition, I use another pin GPIO 5 that connect to a sensor. When sensor output state fall from one to zero, I want to trigger shutdown event as well.
Here is what i add to my config.txt
dtoverlay=gpio-shutdown,gpio_pin=3,active_low=1,debounce=4000
dtoverlay=gpio-shutdown,gpio_pin=5,active_low=1
It seems like only the last line work as intended. I'm guessing it only works on single pin? Is there any other way to achieve what i want via config.txt? I prefer not to add additional service to poll the pin state if possible, and due to hardware limitation, I cannot add any component or wiring on the board to share the pin.
Thanks in advance.
PhilE
Re: Multiple dtoverlay=gpio-shutdown line in config.txt
Fri Apr 23, 2021 9:13 am
Multiple instances of the gpio-shutdown overlay won't work because they end up occupying the same area in the Device Tree.
However, since all you are trying to do is detect a pull-to-ground, why not use the "Wired-AND" configuration and attach the button to the same GPIO as the sensor?
rasp14
Sat Apr 24, 2021 1:19 am
Well, i know i can share the gpio but as mentioned in my op, i can't add anything on board due to hardware limitation.
Is it possible to add this feature in future? I think it is neater to be able to put multiple gpio-shutdown line in config.txt so I don't have to write a special service just to deal with this additional gpio. I don't even have to add anything on board as well which can save time and cost.
cleverca22
Sat Apr 24, 2021 9:21 am
it should be possible to just write your own overlay to handle that
https://github.com/raspberrypi/linux/bl ... verlay.dts
the names for shutdown_button_pins, pin_state, shutdown_button, and maybe button and shutdown, must all be unique
you could probably skip the __overrides__ section (that lets you configure it further), and just make a single overlay, that does both pins at once
looking closer, i think you just want to
  • add 2 pins to the brcm,pins array
  • double up the entries in brcm,function and brcm,pull
  • duplicate the "button: shutdown {" region, making the gpios= of each point to a different pin, and giving them unique names
https://www.raspberrypi.org/documentati ... ce-tree.md
then you can follow these directions to compile your custom overlay to /boot/overlays/custom-shtudown-pins.dtbo, and load it with dtoverlay=custom-shutdown-pins
rasp14
Sun Apr 25, 2021 5:23 pm
Thanks for this. Learned something new today. It's beyond my capability for now, I'll try it when i have the time.
PhilE
Sun Apr 25, 2021 7:41 pm
I've taken another approach and used the gpio_pin parameter to rename the shutdown_button and shutdown_button_pins nodes so that they don't clash with other instances. There's a test build of the updated overlay here: https://drive.google.com/file/d/1ly_tPl ... sp=sharing
cleverca22
Sun Apr 25, 2021 8:27 pm
ah, that sounds much better, but i'm not familiar with how to implement that auto-rename, i should check your diff on git to learn how!
PhilE
Sun Apr 25, 2021 9:21 pm
The same technique is used in gpio-key. In fact, gpio-shutdown is just a special case of gpio-key.
rasp14
Thu May 13, 2021 5:02 am
Can you provide an example on how to use this file?
PhilE
Thu May 13, 2021 7:37 am
Install it with:
$ sudo cp gpio-shutdown.dtbo /boot/overlays
(although the updated version is now part of standard kernel builds)
Use it with:
# Use the defaults - GPIO 3, active-low
# Add a second GPIO - 20 - and make it active-high
dtoverlay=gpio-shutdown,gpio_pin=20,active_low=0
rasp14
Fri May 14, 2021 1:53 pm
Install it with:
Use it with:
I see. Thank you very much! If i use back the code in my original post, by right it should work as separate instance that monitor pin3 and pin5 right?
PhilE
Fri May 14, 2021 2:53 pm
Yes, provided you have the latest version of the overlay.
rasp14
Sat May 15, 2021 2:24 am
I've tested it and confirm the new overlay is working as expected. Thank you very much!
This overlay will available in next kernal update right? I just need to run apt-get update && apt-get upgrade to get the latest overlay file?
PhilE
Sat May 15, 2021 7:40 am
That's correct.
Return to “Device Tree”
