a3p
[SOLVED] ethernet phandle in overlay
Tue Apr 13, 2021 8:54 am
the ethernet interface does not have a name in the dts, so i'm struggling to reference it in an overlay.
in order to instantiate a ksz9477, i need to reference an ethernet device like this;
port@0 {
  reg = <0>;
  label = "cpu";
  ethernet = <&eth1>;
the driver uses that here:
dsa2.c:760  of_find_net_device_by_node(ethernet);
however on the rpi4, the ethernet device does not have an alias. it's just spec'd like this:
scb {
   ethernet@7d580000 {
i tried referencing it like this:
ethernet = <ethernet@7d580000>;
but that's a syntax error.
i also tried just giving it the path as a string
ethernet = "/scb/ethernet@7d580000";
but that will just make it ignore the entire property, probably because this fails:
 struct device_node *ethernet = of_parse_phandle(dn, "ethernet", 0);
there also appears this syntax
ethernet = <&{/scb/ethernet@7d580000}>;
but that gives me:
[  909.158298] OF: resolver: node label '/scb/ethernet@7d580000' not found in live devicetree symbols table
so presumably that means it has to be in
/sys/firmware/devicetree/base/__symbols__/
which it is not, so i guess overlays just wont work at all?
or is there any way give of_find_net_device_by_node the right thing so it finds the device?
PhilE
Re: ethernet phandle in overlay
Tue Apr 13, 2021 12:01 pm
There is a label on the Pi 4 Ethernet interface - "genet" - so use that ("&genet").
a3p
Tue Apr 13, 2021 4:15 pm
thanks! this worked
Return to “Device Tree”
