rasparator
Something wrong with my device tree for SPI slave device?
Mon Jan 11, 2021 10:05 am
Below is my spi slave nfc device tree connected to spi0 of raspberry PI 4B running kernel 5.10.. Driver has been inbuilt and kernel is booted.
But when i do dmesg | grep spi or dmesg | grep nfc i get this output
https://imgur.com/MNnqsq7
My device tree is below :
&spi0 {
        pinctrl-names = "default";
        pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
        cs-gpios = <&gpio 8 1>, <&gpio 7 1>;
        spidev0: spidev@0{
                compatible = "spidev";
                reg = <0>;      /* CE0 */
                #address-cells = <1>;
                #size-cells = <0>;
                spi-max-frequency = <125000000>;
        spidev1: spidev@1{
                reg = <1>;      /* CE1 */
                #size-cells = <0>;
         stnfc@0{
                reg = <0>;
                compatible = "st,stnfc";
                status = "okay";
                spi-max-frequency = <1000000>;
                enable-gpio = <&gpio 16 GPIO_ACTIVE_LOW>;
                interrupt-parent = <&gpio>;
                interrupts = <19 2>;
inside arch/arm/boot/dts/bcm2711-rpi-4-b.dts
i have already spi and can see spidev using lsmod and also /sys/bus/spi/devices/spi0.0 and spi0.1
https://imgur.com/TF7mVWz
thre is interrupt (gpio 6, pin 31) and wakeup (enable) pin connected to gpio 5 , pin 29)
i have below question ,
is the choice of pins correct?
is the device tree correct
If above two are true , should I be checking the hardware connections?
please assist.
Regards,
R
rasparator
Re: Something wrong with my device tree for SPI slave device?
Wed Jan 13, 2021 5:44 am
can any one please comment on this .
There is a separate thread for the same : viewtopic.php?f=28&t=298021&p=1795784#p1795784
Sorry for duplicating. May be we can discuss it there and I will request Moderator to delete this later.
in short I want to know the association of the new gpio pins (how and where to modify) associated with the driver in the device tree.
I have done a sample implementation in the linked forum.
Thanks in Advance !
Regards
PhilE
Wed Jan 13, 2021 10:07 am
It's good that you posted a nudge - notifications seem to be unreliable, and this was the first I'd seen of your problem.
The reason it is failng to register the driver is that spidev has already claimed CS/CE 0 - you need to delete or disable ('status = "disabled";') the spidev@0 node.
rasparator
Wed Jan 13, 2021 5:27 pm
Sorry I didnt get.
Are you talking about deleting whole spidev block below
spidev0: spidev@0{
                #size-cells = <0>;
I cant find 'status = "disabled" ?
what is notification you are talking about?
Regards
PhilE
Wed Jan 13, 2021 5:32 pm
You would need to add it:
spidev0: spidev@0{
                #size-cells = <0>;
rasparator
Sat Jan 16, 2021 5:50 am
Seems like some kernel Panic.
Kernel is an a reboot loop after this change
PhilE
Sat Jan 16, 2021 3:54 pm
I suggest you disable the stnfc node to confirm that is the cause of the problem.
rasparator
Tue Jan 19, 2021 6:53 am
OK i rebuild and did it on fresh sd card
I am getting this :
Linux raspberrypi 5.10.4-v8 #10 SMP PREEMPT Tue Jan 19 11:27:24 IST 2021 aarch64 GNU/Linux
pi@raspberrypi:~ $ dmesg | grep nfc
[ 0.151828] nfc: nfc_init: NFC Core ver 0.1
[ 1.318274] DIGITAL uart driver 'nfcst_uart [0]' registered
[ 4.906362] stnfc spi0.0: Error applying setting, reverse things back
[ 4.906398] stnfc: probe of spi0.0 failed with error -22
pi@raspberrypi:~ $ dmesg | grep spi
[ 4.906273] pinctrl-bcm2835 fe200000.gpio: pin gpio31 already requested by fe201000.serial; cannot claim for spi0.0
[ 4.906333] pinctrl-bcm2835 fe200000.gpio: pin-31 (spi0.0) status -22
[ 4.906398] stnfc: probe of spi0.0 failed with error -22 pi@raspberrypi:~ $
my device tree is this one :
&spi0 {
spidev0: spidev@0{
#size-cells = <0>;
spidev1: spidev@1{
#size-cells = <0>;
stnfc@0{
reg = <0>;
status = "okay";
+pinctrl-0 = <&nfcdrv_spi0_pins>;
enable-gpio = <&gpio 29 GPIO_ACTIVE_LOW>;
interrupts = <31 2>;
&gpio {
spi0_pins: spi0_pins {
brcm,pins = <9 10 11>;
brcm,function = <BCM2835_FSEL_ALT0>;
+nfcdrv_spi0_pins: nfcdrv_spi0_pins {
+ brcm,pins = <29 31>;
+ brcm,function = <BCM2835_FSEL_ALT0>;
spi0_cs_pins: spi0_cs_pins {
brcm,pins = <8 7>;
brcm,function = <BCM2835_FSEL_GPIO_OUT>;
the modules are built inbuilt
PhilE
Tue Jan 19, 2021 8:52 am
That error message doesn't leave much room for doubt:
Are you perhaps using header pin numbers? The pinctrl/gpio driver expects the "Broadcom" GPIO numbers. For example, header pins 8 and 10 usually carry GPIOs 14 and 15. On most Pis, GPIO31 is wired to the UART RX line from the Bluetooth modem, and this is preventing the stnfc driver from also using it.
29 & 31 sound like adjacent pins on the 40-pin header, which would make them GPIOs 5 & 6 respectively. Replace 29 with 5, 31 with 6, and try again.
rasparator
Tue Jan 19, 2021 12:11 pm
Modifications(done in vi arch/arm/boot/dts/bcm2711-rpi-4-b.dts ) in bold :
why do i see spi_bcm2835 and not spi_bcm2711?? its raspberry Pi 4 b .
enable-gpio = <&gpio 5 GPIO_ACTIVE_LOW>;
interrupts = <6 2>;
&gpio {
***I doubt below code ..is it correct. I just need 2 gpios , one for interrupt , another for wakeup)****
brcm,pins = <5 6>;
[ 0.151746] nfc: nfc_init: NFC Core ver 0.1
[ 1.322199] DIGITAL uart driver 'nfcst_uart [0]' registered
[ 4.857241] stnfc spi0.0: NFC: nfc_st_spi driver probe called
[ 4.869001] genirq: Failed to request resources for nfcst (irq 50) on irqchip pinctrl-bcm2835
[ 4.869126] stnfc spi0.0: err: irq request for nfc_st_spi is failed
[ 4.872273] nfcst_spi_probe+0x280/0x2b4
[ 4.870023] Modules linked in: spi_bcm2835(+) vc4(+) bcm2835_isp(C) bcm2835_v4l2(C) bcm2835_codec(C+) bcm2835_mmal_vchiq(C) v4l2_mem2mem cec videobuf2_vmalloc videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 vc_sm_cma(C) videobuf2_common drm_kms_helper snd_bcm2835(C) videodev mc drm drm_panel_orientation_quirks snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd sg syscopyarea sysfillrect sysimgblt fb_sys_fops backlight uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[ 4.872327] spi_drv_probe+0x8c/0xf0
[ 4.872797] spi_add_device+0xc4/0x190
[ 4.872847] of_register_spi_device+0x208/0x390
[ 4.872905] spi_register_controller+0x440/0x7d0
[ 4.872976] bcm2835_spi_probe+0x17c/0x2f0 [spi_bcm2835]
[ 4.873571] bcm2835_spi_driver_init+0x2c/0x1000 [spi_bcm2835]
regards,
PhilE
Tue Jan 19, 2021 12:20 pm
The SPI interfaces on BCM2711 are the same as on older SoCs, so we don't need a new driver.
1. What exactly are these GPIOs meant to do?
2. Why are you declaring them as requiring ALT0? For GPIOs 5 & 6 this makes them GPCLK1 and GPCLK2.
rasparator
Tue Jan 19, 2021 1:07 pm
thre is interrupt (gpio 6, pin 31) and another wakeup (enable) pin connected to gpio 5 , pin 29.
one interrupts the Host , another host to slave for wake up ( active low )
I am not clear what to define for these two pins (interrupts and wakeup) and where?
pasting the DT configuration which works on BeagleboneBlack . I am looking for the similar one for RPI4B. Interrupt and wakeup pins are different there.
+&am33xx_pinmux {
+ spi0_pins: pinmux_spi0_pins {
+ pinctrl-single,pins = <
+ 0x150 (PIN_INPUT | MUX_MODE0) /* P9_22 (A17) spi0_sclk.spi0_sclk */
+ 0x154 (PIN_INPUT | MUX_MODE0) /* P9_21 (B17) spi0_d0.spi0_d0 */
+ 0x158 (PIN_INPUT | MUX_MODE0) /* P9_18 (B16) spi0_d1.spi0_d1 */
+ 0x15c (PIN_INPUT | MUX_MODE0) /* P9_17 (A16) spi0_cs0.spi0_cs0 */
+ spi0_nfc_pins: pinmux_spi0_nfc_pins {
+ 0x040 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* P9_15 (R13) gpmc_a0.gpio1_16 EN */
+ 0x04C (PIN_INPUT_PULLDOWN | MUX_MODE7) /* P9_16 (T14) gpmc_a3.gpio1_19 IRQ */
+&spi0 {
+ status = "okay";
+ pinctrl-names = "default";
+ pinctrl-0 = <&spi0_pins>;
+ stnfc@0{
+ reg = <0>;
+ compatible = "st,stnfc";
+ status = "okay";
+ pinctrl-0 = <&spi0_nfc_pins>;
+ spi-max-frequency = <1000000>;
+ enable-gpio = <&gpio1 16 GPIO_ACTIVE_HIGH>;
+ //enable-gpio = <&gpio1 16 GPIO_ACTIVE_LOW>;
+ interrupt-parent = <&gpio1>;
+ interrupts = <19 IRQ_TYPE_EDGE_RISING>;
+ //interrupts = <19 IRQ_TYPE_EDGE_FALLING>;
Regards
PhilE
Tue Jan 19, 2021 2:01 pm
If the pins are to be used for real GPIO (input and output controlled by the CPU) then it isn't necessary to declare the pins through pinctrl, but it does help to detect clashes (as you've seen).
An input is declared with BCM2835_FSEL_GPIO_IN, and an output with BCM2835_FSEL_GPIO_OUT. If you want to set the pulls as well, include "brcm.pull = ...".
In your case you probably want:
	brcm,pins = <5 6>;
	brcm,function = <BCM2835_FSEL_GPIO_OUT BCM2835_FSEL_GPIO_IN>;
	brcm,pull = <BCM2835_PUD_DOWN>;
rasparator
Tue Jan 19, 2021 3:16 pm
brcm,pins = <5 6>;
after 13 posts and 2 weeks , it worked !!! Thank a ton !!
driver is probed now and an entry has been made in the spi0.1 . Behaviour is same as BBB now.
Regards,R
rasparator
Wed Jan 20, 2021 6:42 pm
back again !!
while interacting with the hardware using som user space programme , I get this :
nfcdriver spi0.0 phy timeout error
nfcdriver spi0.0 send recieve of frame fail with -110
Is this due to some incorrect default polarity of the interrupt or wake up?
or something else?
How to trouble shoot?
Regards
Return to “Device Tree”
