procount
Re: Using device-tree to configure GPIO - basic questions
Wed Feb 06, 2019 11:51 am
Thanks for catching my stupid error on function ordering. Doh!
PhilE wrote:
Wed Feb 06, 2019 11:40 am
goodix_request_input_dev is clearly registering more input types than cypress_request_input_dev,
I'm being really stupid now - Where? because I can't see it. (I must be going blind!)
Yes, I agree it adds these 2 events;
	input_set_abs_params(ts->input_dev, ABS_MT_WIDTH_MAJOR, 0, 255, 0, 0);
	input_set_abs_params(ts->input_dev, ABS_MT_TOUCH_MAJOR, 0, 255, 0, 0);
(I have no need for those, and even when I added them, it only added those 2 events)
It also adds:
input_set_capability(ts->input_dev, EV_KEY, KEY_LEFTMETA);
But that's for a Windows Home key, that I'm not using.
Where is it adding, for example:
     Event code 0 (ABS_X)
     Event code 1 (ABS_Y)
     Event code 47 (ABS_MT_SLOT)
     Event code 57 (ABS_MT_TRACKING_ID)
And is the fact that /dev/input/mouse0 does not exist a consequence of those missing capabilities?
procount
Wed Feb 06, 2019 11:57 am
@PhilE - Many thanks . It was just the configuration ordering that was causing it.
Spoke too soon. I first have to test it with the correct touchscreen fitted. :(
procount
Wed Feb 06, 2019 12:04 pm
And with the correct touchscreen fitted, it works like a charm!
Many thanks @PhilE for being my extra pair of eyes!
procount
Wed Feb 06, 2019 12:06 pm
Just one more question if I may:
Is it acceptable to create a composite device driver that would initialise the LCD screen AND control the touchscreen, or is that considered bad form?
PhilE
Wed Feb 06, 2019 12:12 pm
Upstream (i.e. the Linux kernel maintainers) would probably want a driver for each, especially if they really are separately addressable bits of hardware.
procount
Wed Feb 06, 2019 12:24 pm
That sounds vague enough that it's ok if I want to use it for PINN, but to release it upstream a separate driver would be required.
Currently, the LCD screen and touchscreen driver are separate userland programs. I don't know how to detect the LCD screen on it's own, but I can detect the touchscreen and infer that the LCD screen is also fitted (since they're on the same PCB) and hence initialise it.
This makes it much easier to autodetect different screens and initialise them in one go (since the driver is only loaded when the H/W is detected), otherwise it means switching the userland programs around depending on which touchscreen is detected. I still have the issue of the user having to change the overlay and other settings in config.txt, but it's a little easier.
Return to “Device Tree”
