KubaF
enable_uart=1 does NOT set core_freq=250
Sun May 13, 2018 10:07 pm
The documentation at Mini UART and CPU core frequency says
The Linux console can be re-enabled by adding enable_uart=1 to config.txt. This also fixes the core_freq to 250Mhz
But the core freq change does not seem to happen, because just having
dtoverlay=pi3-miniuart-bt
enable_uart=1
in my /boot/config.txt results in hciuart.service failing to start (Initialization timed out). But changing the config to
core_freq=250
makes it start succesfully.
Is the documentation wrong, or my observation? How can i debug it or verify further? Could the doc and/or the dto be fixed?
The rest of my /boot/config.txt in case it is relevant:
dtparam=i2c_arm=on
dtparam=spi=on
dtparam=audio=on
dtoverlay=dwc2
dtoverlay=w1-gpio
uname -a
Linux raspberrypi 4.14.30+ #1102 Mon Mar 26 16:20:05 BST 2018 armv6l GNU/Linux
ls -l /dev/serial*
lrwxrwxrwx 1 root root 7 May 13 18:12 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 May 13 18:12 /dev/serial1 -> ttyS0
PhilE
Re: enable_uart=1 does NOT set core_freq=250
Mon May 14, 2018 8:17 am
You need to read that section of the documentation together with the preceding paragraph:
Also, when the Linux console uses the mini UART (Raspberry Pi 3, Raspberry Pi Zero W), as a consequence of the UART being disabled, the console is also disabled.
The Linux console can be re-enabled by adding enable_uart=1 to config.txt. This also fixes the core_freq to 250Mhz (unless force_turbo is set, when it will fixed to 400Mhz), which means that the UART baud rate stays consistent.
In other words, in order to use the mini UART for the serial console it must be explicitly enabled with "enable_uart=1", which has the side effect of forcing the core clock to 250MHz.
Your use case is the opposite - using the mini UART for Bluetooth via the pi3-miniuart-bt overlay - which is covered by the overlay documentation:
pi@raspberrypi:~ $ dtoverlay -h pi3-miniuart-bt
Info:   Switch Pi3 Bluetooth function to use the mini-UART (ttyS0) and restore
        UART0/ttyAMA0 over GPIOs 14 & 15. Note that this may reduce the maximum
        usable baudrate.
        N.B. It is also necessary to edit /lib/systemd/system/hciuart.service
        and replace ttyAMA0 with ttyS0, unless you have a system with udev rules
        that create /dev/serial0 and /dev/serial1, in which case use
        /dev/serial1 instead because it will always be correct. Furthermore,
        you must also set core_freq=250 in config.txt or the miniuart will not
        work.
Usage:  dtoverlay=pi3-miniuart-bt
Params: <None>
KubaF
Sun May 20, 2018 4:27 pm
Thank you for the explanation, you were right that I needed to read more carefuly and with context.
Now I finaly realize that simply setting enable_uart=1 (without *-bt overlays) moves the Linux console through the mini UART to the GPIO pins, for some reason I thought that the mini UART is only internal. This way I can let Bluetooth use the better UART and still have USB TTL console.
PhilE
Sun May 20, 2018 4:39 pm
Yes, you've got it. This is a subject that often causes confusion - the goal was to get the best performance out of the system while still giving control to the users, but this had led to a subtle interconnection between the enable_uart and core_freq settings and various uart- and bluetooth-related overlays.
Return to “Device Tree”
Who is online
