HermannSW
How to wait for SPI1 being ready during boot?
Fri Oct 13, 2017 8:59 am
In this posting
viewtopic.php?f=63&t=194423&p=1217626#p1217978
I realized that SPI1 interface enabled in /boot/config.txt
dtparam=spi=on
dtoverlay=spi1-3cs
is only available in /etc/rc.local for configuring a display on SPI1 after a 1 second delay:
sleep 1
sudo modprobe fbtft_device name=rpi-display gpios=reset:13,dc:26,led:28 rotate=270 cs=2 busnum=1
This may be the reason why a dt overlay I tried to generate for display on SPI1 did not work (too early).
Is there something equivalent to "sleep 1" I could place between "dtoverlay=spi1-3cs" and "dtoverlay=rpi-displa1" in /boot/config.txt to delay processing of "dtoverlay=rpi-displa1" until after SPI1 is available?
Or better, a "wait until SPI1 is up"?
(I did change "target = <&spi0>;" to "target = <&spi1>;" in fragment@0 of new "rpi-displa1.dts" without the needed wait effect)
--> Raspberry camera / gstreamer / raspivid / raspiraw (bookmark list):
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/raspiraw      https://github.com/Hermann-SW/userland      https://twitter.com/HermannSW
PhilE
Re: How to wait for SPI1 being ready during boot?
Fri Oct 13, 2017 9:05 am
All of the overlays specified in config.txt are applied before the ARM cores execute a single instruction. The kernel uses the information to load and configure devices drivers such as spi-bcm2835, which then enables the interface. A pause in the overlay application will make no difference at all to your problem - the delay you have now is in roughly the right place, although it isn't very elegant.
HermannSW
Fri Oct 13, 2017 11:30 am
Thanks for that information -- I only asked in this forum because I did not get a response in the other forum's posting.
Good to know that eanbling display on SPI1 is not possible in /boot/config.txt.
Others did use 2 displays on SPI0 only with different chip select lines, perhaps worth a try whether with that config both displays can be enabled by two device tree overlays in /boot/config.txt.
Return to “Device Tree”
Who is online
Users browsing this forum: No registered users and 2 guests
