Loic Poulain
ttyAMA0 / bluetooth configuration
Mon Jul 31, 2017 11:16 am
Hi there,
I works on vanilla linux/kernel to enable bluetooth over uart.
Since I don't have the schematics, wanted to know a little bit
more about the interconnect.
Today, broadcom 43438 controller rx/tx are connected to pin <32 33>.
Basically ,ttyAMA0/uart0 is configured to manage this controller (from DT).
My questions:
- Would like to enable DMA for this UART, is it supported ?
- Would like to enable hw flow control, any cts/rts rooted to the bcm chip ?
- Any other gpio/irqs (power, suspend, wakeup) ?
PhilE
Re: ttyAMA0 / bluetooth configuration
Tue Aug 01, 2017 6:41 pm
DMA isn't possible because the DMA controller can't do byte accesses - you end up with one data byte per word of output. I've also got a feeling that the DREQ line isn't wired up correctly.
RTS/CTS are on 16&17.
Most of the GPIO information is published. There are no dedicated power/suspend pins.
Loic Poulain
Thu Aug 10, 2017 9:11 am
Thanks, this helps a lot.
What about clocking ? I see in the current DT that gpclk2_gpio43 needs to be enabled.
Is it a clock going to the BCM controller.
Regards
PhilE
Thu Aug 10, 2017 10:24 am
Pi3 and Pi Zero W generate a 32KHz clock signal on GPIO43 for the WiFi+BT combo chip.
Return to “Device Tree”
Who is online
Users browsing this forum: No registered users and 1 guest
