Issue 80 : Pi FM Transmitter
Posted: Fri Mar 29, 2019 5:41 pm
by hippy
https://www.raspberrypi.org/magpi/issues/80
Page 72 :roll:
Not even a mention that this "fun project which allows you to create your own personal radio station" is very likely illegal in most jurisdictions, viz -
viewtopic.php?t=171753
And I'm not sure putting it under a HAM radio project section was the brightest of ideas.
Re: Issue 80 : Pi FM Transmitter
Posted: Fri Mar 29, 2019 5:52 pm
by Andyroo
Well there is a big warning at the start of the project - page 70 :lol:
Its about as good as enabling SMB 1.0 on the SAMBA section :roll:
Shame that little bits like this can cause so much noise in what is a good magazine.
Posted: Fri Mar 29, 2019 5:58 pm
by DougieLawson
Which nobody will read. In just the same way they won't read the warning at https://circuitdigest.com/microcontroll ... ransmitter
If you want to get Ofcom knocking on the door and confiscating equipment, then try broadcasting on 121.5MHz
Posted: Fri Mar 29, 2019 6:04 pm
by Andyroo
No thanks - I dropped out of HAM radios when I got into an argument with the local exam board over wanting to use a TRS-80 to send / receive morse without learning it :lol:
Since then I've stuck to licences for WiFi and TV licences (though the latter is harder to sort than the former).
Posted: Fri Mar 29, 2019 6:57 pm
by bensimmo
nobody around here complained when my son attached a bit of wire to a pi, found some code and broadcast some star wars music on the Lincs FM channel.
He was quite proud of himself, you could pick it up a good 50 to 100m away in the car.
Don't know where he got the idea, but could have been an old MagPi or just good old internet.
Posted: Fri Mar 29, 2019 8:01 pm
by hippy
Or both .... https://www.raspberrypi.org/magpi/raspb ... ransmitter
Posted: Fri Mar 29, 2019 8:43 pm
by Andyroo
Having had the misfortune to have to listen to Lincs FM during car shares I assume the locals saw this as an advantage :lol: :roll: :lol:
Posted: Sat Mar 30, 2019 12:05 am
by jdb
Thanks for bringing this to our attention.
