Corvidael
AIY and the VNC project
Wed May 17, 2017 4:01 am
I went the easy route and simply downloaded and burned the ISO for the issue 57 box (which I just received today and now have it up and running)
However, when I went in to enable VNC, I'm getting an error that I need a subscription (as opposed to the regular Raspian image)..
I was really hoping to maintain a headless connection to this beautiful little box without having to have it connected to a monitor.
Anybody know what my options are?
thagrol
Re: AIY and the VNC project
Wed May 17, 2017 11:10 am
Doesn't solve your vnc problem but I'm using mine headless via ssh with X11 forwarding for the odd gui app I need.
Arguing with strangers on the internet since 1993.
Corvidael
Wed May 17, 2017 4:31 pm
thagrol wrote:Doesn't solve your vnc problem but I'm using mine headless via ssh with X11 forwarding for the odd gui app I need.
Yeah, I've got that going, but I'm so addicted to the VNC experience now with all my Pi's, The early days were all XII forwarding and it feels like such a step backwards.
Just curious why the VNC on this image is different than that on the Raspian one, and -- shy of actually buying a license -- if there was a way to replace it with the Raspbian one.
I'll give this a shot: https://www.realvnc.com/download/vnc/raspberrypi/
S0litaire
Contact: ICQ Skype Twitter
Wed May 17, 2017 5:06 pm
What viewer you using? realVNC's own or another?
just make sure you update r-pi first, the version of VNCServer that's in the google image is old and has issues letting clients connect.
Just make sure you enable VNC again in raspi-config after updating.
The RealVNC own viewer should let you connect.
Not tried other viewers yet.
Laters
Bill "Solitaire" C
Anáil nathrach, ortha bhas betha, do cheol déanta
thagrol
Wed May 17, 2017 8:13 pm
Horses for courses I guess.
I use X11 over ssh coz:
  1. I'm old school
  2. My main PC has multiple (3) monitors
  3. My x server is cygwin-x in "multiple window" mode so X apps aren't restricted to a screen size determined by the pi and are integrated into my desktop.
mattmiller
Wed May 17, 2017 8:31 pm
You need to update the image to get VNC to work properly - its fine once you've done it
viewtopic.php?f=114&t=182283#p1157235
Corvidael
Thu May 18, 2017 2:31 am
mattmiller wrote:You need to update the image to get VNC to work properly - its fine once you've done it
Hilarious, maybe. I was so excited when I got home and found the MagPi package on my doorstep, that I spent my entire evening bending cardboard and pressing metal clips together.
sudo apt-get update
and
sudo apt-get upgrade
are things I ALWAYS do, and often. But got too excited with this install.
So here I go:
The following packages will be upgraded:
  alacarte binutils ca-certificates gstreamer1.0-alsa gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x
  initramfs-tools libaudiofile1 libavcodec56 libavformat56 libavresample2 libavutil54 libbluray1 libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev
  libgnutls-deb0-28 libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libgudev-1.0-0 libicu52
  libjasper1 libldap-2.4-2 libopenblas-base libpam-chksshpwd libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g
  libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libsmbclient libswscale3 libsystemd0 libtiff5 libtirpc1 libudev1
  libwbclient0 libxslt1.1 locales multiarch-support pi-greeter piclone pix-plym-splash raspberrypi-bootloader raspberrypi-sys-mods
  raspberrypi-ui-mods raspi-config rc-gui realvnc-vnc-server realvnc-vnc-viewer rpcbind rpi-chromium-mods samba-common samba-libs systemd
  systemd-sysv tzdata udev unzip vim-common vim-tiny wget wiringpi
73 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 110 MB of archives.
After this operation, 2,608 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
SWEET!
Ok, this:
Setting up realvnc-vnc-server (6.1.0.27437) ...
Updating /etc/pam.d/vncserver
Updating /etc/pam.conf... done
Looking for font path... not found.
Generating private key... done
Installed systemd unit for VNC Server in Service Mode daemon
Start or stop the service with:
  systemctl (start|stop) vncserver-x11-serviced.service
Mark or unmark the service to be started at boot time with:
  systemctl (enable|disable) vncserver-x11-serviced.service
Enabling systemd service to match SysV service
Created symlink from /etc/systemd/system/multi-user.target.wants/vncserver-x11-serviced.service to /usr/lib/systemd/system/vncserver-x11-serviced.service.
Installed systemd unit for VNC Server in Virtual Mode daemon
  systemctl (start|stop) vncserver-virtuald.service
  systemctl (enable|disable) vncserver-virtuald.service
(gconftool-2:16395): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
gconfd-2: no process found
Setting up realvnc-vnc-viewer (6.1.0.27437) ...
Setting up rpi-chromium-mods (20170418) ...
Setting up unzip (6.0-16+deb8u3) ...
Setting up wiringpi (2.44) ...
Setting up raspberrypi-bootloader (1.20170427-1) ...
looks like something easily worked through.
Update at 11
Corvidael
Thu May 18, 2017 2:35 am
as we say in Canada:
"Bob's your uncle."
It didn't take any further steps than the update/upgrade/reboot.
Return to “The MagPi”
