devunwired
Re: STICKY: Errata
Wed Jul 18, 2018 4:14 am
Issue 71, Page 23 under Android Zero:
Unfortunately, Android Things does not support the Pi Zero – it requires a bit more power than the board can currently provide, so you’ll need at least a Raspberry Pi 2 to run Android Things on, but preferably a Pi 3
This statement is incorrect. Android Things only supports the Raspberry Pi 3 Model B. It will not run on a Raspberry Pi 2.
https://developer.android.com/things/hardware/
hippy
Re: STICKY: Errata
Wed Jul 18, 2018 12:38 pm
Issue 71, Page 75, line 35 of listing, wind_speed.py -
print( calculate_speed(wind_interval), "cm/h")
Should be "cm/s".
yourunclesdog
Re: STICKY: Errata
Sun Nov 04, 2018 9:53 pm
Hey there! I've just noticed that in issue 75 of the magazine, both number 36 and number 30 in the top 50 voted projects have the PolaPi-Zero's name and description. It's nothing major, I just wanted to let you know.
vinntec
Re: STICKY: Errata
Thu Jan 31, 2019 8:42 am
The link to the PDF on the new issue #78 goes to #77.
icd
Re: STICKY: Errata
Sat Nov 16, 2019 8:36 am
Issue 87 Power Up Your Kitchen
The first part covering temperature and alarms - page 69. In section 03, there is a reference to some Python code "... download the code file temperature.py ..." but no indication where that file is located.
Return to “The MagPi”
