Contents list from Issue 1 to 99 setup in Word - minimal formatting - free to use by all without restriction. Can't figure out how to upload so contact me on 1hughdoc@gmail.com. I won't respond to a million requests, however!
Regards,
Hugh
Re: Magazine Contents List
7zip file attached - I hope!
- Attachments
- RasPi Index 2020.7z
- (173.45 KiB) Downloaded 135 times
Thank you!
Excellent work. It is possible to force the Pi Bookshelf App to use an index rather than what it currently displays and it's perhaps possible to add a search function. The long slog is getting an index to start with and your work saves a lot of effort there - the challenge is in keeping it up to date in the future.
I may do a new version listing by article name and issue number - but thats for the future!
If you do another go-around on this, would you consider publishing it as a CSV file rather than, or in addition to, a .DOC? A CSV can be easily inhaled into other applications and/or parsed programmatically without any .doc file overhead garp.
Thx (and thanks for the original publish! Very handy!)
Pi tools:
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easily run your network's DHCP/DNS on a Pi: https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
In case anyone wants it, here is Hugh's index in a .csv format.
First class - many thanks! New list by article name and issue number planned for New Year!
Regards,
Hugh
Regards,
Hugh
Hi HugoD
Thanks for generating the original list.
& To KCarscadden
Thanks for generating the CSV file. I know that is easy to do but it does save time to just download a file.
Best Wishes and Happy, Healthy ( probably the most important at the present time ) and a prosperous New Year
Jim
& To KCarscadden
Jim
Best Wishes
Jim
a New RPi P4Gb User, RPi 400
Jim
Thank you for the list and alternates. Always looking back for previous tips, and projects. My Pi 400 is working great and think i'm on my way to dropping W10. But still some apps not available for Pi so i't will have to sit in corner until a need it.
Hi, Started new version of the contents list but require assistance on format. Was going to simply list contents by name and issue/page but some of the names are not indicative of article content so I considered breaking them up into subject category e.g. network, hardware, etc. Would that be of assistance in searching or would it be best to simply limit it to search phrase then issue, etc? Finding information is simple if you know what to look for but sometimes the contents are hidden behing highlighted titles!! Any suggestions? This lock-down gives me time to work!
Regards,
Hugh
Regards,
Hugh
