sandysound
Questions regarding shutdown-ledboard.py example in MagPi
Sat May 16, 2020 6:12 pm
Have been trying to use this script from MagPi: https://magpi.raspberrypi.org/articles/ ... spberry-pi
Its from a github:https://github.com/TonyLHansen/raspberr ... edboard.py
#!/usr/bin/env python3
from gpiozero import Button, LEDBoard
from signal import pause
import warnings, os, sys
offGPIO = int(sys.argv[1]) if len(sys.argv) >= 2 else 21
offtime = int(sys.argv[2]) if len(sys.argv) >= 3 else 6
mintime = 1       # notice switch after mintime seconds
actledGPIO = 47   # activity LED
powerledGPIO = 35 # power LED
def shutdown(b):
    # find how long the button has been held
    p = b.pressed_time
    # blink rate will increase the longer we hold
    # the button down. E.g., at 2 seconds, use 1/4 second rate.
    leds.blink(on_time=0.5/p, off_time=0.5/p)
    if p > offtime:
        os.system("sudo poweroff")
def when_pressed():
    # start blinking with 1/2 second rate
    leds.blink(on_time=0.5, off_time=0.5)
def when_released():
    # be sure to turn the LEDs off if we release early
    leds.off()
with warnings.catch_warnings():
    warnings.simplefilter("ignore")
    leds = LEDBoard(actledGPIO, powerledGPIO)
btn = Button(offGPIO, hold_time=mintime, hold_repeat=True)
btn.when_held = shutdown
btn.when_pressed = when_pressed
btn.when_released = when_released
pause()
The problem I am having is figuring out how to manipulate it, I would like to be able to adjust the amount of time the button is pressed for before initiating a shutdown. How do i do that in this script?
And do I need to run it as python3 or will python be fine?
The script does work for me, but there is a long pause between initiating shutdown and it actually happening when compared to other scripts.
Also, what is the difference between running this as a cron job and using rc.local?
klricks
Re: Questions regarding shutdown-ledboard.py example in MagPi
Sun May 17, 2020 2:37 am
The program has 2 command line parameters which allow the user to input variables without having to make changes to the code.
The 1st one is the GPIO number for the button and the 2nd is the hold time before shutdown.
If you do not specify the 2 numbers then it will default to use GPIO 21 and 6 seconds.
For example if you want to use GPIO 5 instead and 10 seconds hold time:
python3 shutdown-ledboard.py 5 10
Or you could modify the defaults in the code:
offGPIO = int(sys.argv[1]) if len(sys.argv) >= 2 else 5
offtime = int(sys.argv[2]) if len(sys.argv) >= 3 else 10
You need to use python3 for Python 3 (python for Python 2 code).
cron allows you to run a program or command at a certain time of day, week, month etc. (Endless possibilities)
For example you could set cron to start a program every Wednesday at 15:00:00 etc.
There is also a cron setting @reboot to run the program or command once at boot time.
@reboot does not always work especially for programs that need GUI as the program will attempt to run before the desktop is ready.
/etc/rc.local is much easier to use but wont work for GUI programs.
For GUI programs (and non GUI) use autostart:
/etc/xdg/lxsession/LXDE-pi/autostart
Be sure to use the full paths in your commands in rc.local or autostart:
python3 /home/pi/shutdown-ledboard.py 21 3
sandysound
Mon May 18, 2020 11:16 am
Ahhhhhhhh! Thankyou for your clear and concise answer!
Much obliged!
RpiMatt
Re:Upgrading Raspberry Pi OS (formerly Raspbian)
Thu May 28, 2020 1:46 pm
Can I upgrade from the 32-bit Raspberry Pi OS to the all-new 64-bit Raspberry Pi OS when the 64-bit is more stable?
Re: Re:Upgrading Raspberry Pi OS (formerly Raspbian)
Thu May 28, 2020 4:58 pm
It's a bit early to ask since the 64bit stuff is still in beta testing.
The way I'm planning to do it is with a fresh install for the machines that are 64bit ready, so I don't keep any clag, cruft and junk from Raspbian (aka RaspiOS32).
Return to “The MagPi”
