Windows IOT 10 10.0.17134.1 Serial Port problem
Posted: Mon Aug 20, 2018 11:29 am
by msg1
Hi
Has anyone else found that they cant access the serial port on the raspberry Pi3 using the IOT core version 10.0.17134.1.
I have used a previous version (didn't keep a record!) and all worked ok.
Now , although I can obtain a list of serial ports using :-
string aqs = SerialDevice.GetDeviceSelector();
var dis = await DeviceInformation.FindAllAsync(aqs);
// status.Text = "Select a device and connect";
for (int i = 0; i < dis.Count; i++)
listOfDevices.Add(dis);
Trying to create an instance of a serial port using this:-
SerialDevice serialPort = null;
serialPort = await SerialDevice.FromIdAsync(listOfDevices[0].Id );
returns a null serial port.
Unfortunately I do not have the previous version and I cant find the previous versions on the web site either!
I have contacted Microsoft and am awaiting a call with them soon.
So two questions if I may:-
1 Has anyone else experienced the same problem.
2. Does anyone else know where I can get previous versions from.
I will keep you up to date with the progress from Microsoft.
Thanks for your help
Regards
Mark
Re: Windows IOT 10 10.0.17134.1 Serial Port problem
Posted: Mon Aug 20, 2018 12:35 pm
by fruitoftheloom
Hi
Regards
Mark
Have you tried the latest Insider Preview Release, believe it is version 17733 ?
https://www.microsoft.com/en-us/softwar ... windowsiot
Posted: Mon Aug 20, 2018 2:25 pm
by msg1
Hi Adieu
Thankyou for your reply..
I have tried to dowdload that version but all I get is this;-
Error
We encountered a problem processing your request. Please try again later.
CloseFAQ
I need to find a stable website and try that version.
Thanks again
Mark
Posted: Mon Aug 20, 2018 2:36 pm
by DirkS
Hi Adieu
:shock: :mrgreen:
Posted: Mon Aug 20, 2018 2:38 pm
by DirkS
Just downloaded both previews without problems.
You don't need a more stable website, but a better internet connection / ISP / downloader...
Posted: Mon Aug 20, 2018 2:41 pm
by fruitoftheloom
Hi Adieu
Error
CloseFAQ
Thanks again
Mark
You need to be signed in with your Microsoft Account, a Hotmail/Outlook one should suffice.....
Posted: Mon Aug 20, 2018 2:55 pm
by msg1
Hi
I will try to download using a different machine / isp combo
Will let you know how I get on
Regards
Mark
Posted: Fri Aug 24, 2018 9:22 am
by msg1
Hi All
Just to close this post as I have solved my original problem.
It turned out to be as simple as enabling the Serial Device in the Package.appxmanifext.xml.
I added :-
<Capabilities>
<DeviceCapability Name="serialcommunication">
<Device Id="any">
<Function Type="name:serialPort" />
</Device>
</DeviceCapability>
</Capabilities>
I have also managed to join the Insider program and download the test version of IOT10 10.0.17733.1000.
Thankyou for your help
Regards
Mark.
Posted: Fri Aug 24, 2018 7:54 pm
by francistiley5
Will definitely try and test this one on my PC. I have the same issue with my Windows 10 got from go2top.
Thank you for sharing this topic. It's very useful and helpful to me.
