abhi143
Headless windows 10 iot core installation problem
Wed May 30, 2018 3:29 am
I have been successfully installed headless rasbain on Pi3. I am trying to install Headless windows 10 iot core on raspberry Pi3. I have laptop installing windows 10.
How to install Headless windows 10 iot core on raspberry Pi3?
Re: Headless windows 10 iot core installation problem
Wed May 30, 2018 4:43 am
If it is a Raspberry Pi 3B+ you'll need the beta version of Win10IoT.
abhi143
Wed May 30, 2018 5:00 am
I have raspberry Pi 3 Model B v1.2, I have flashed windows 10 iot core into SD card with dashboard. How to get laptop screen to setup windows 10 iot core on Raspberry Pi 3
Wed May 30, 2018 7:21 am
Windows 10 IoT does not work the same as Raspbian, it is an Operating System where your App is deployed to the RPi:
https://docs.microsoft.com/en-us/window ... /tutorials
https://docs.microsoft.com/en-gb/window ... evicesetup
Fundamentals are additionally a Windows 10 Desktop Machine and Visual Studio 2017.....
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
abhi143
Wed May 30, 2018 9:05 am
I have loaded windows 10 iot core into SD card and I have connected the card into raspberry Pi without display. I want to use my laptop screen for raspberry Pi. I am stuck here.
I looked the information in second link for wireless connection but that's not working for me.
Wed May 30, 2018 9:21 am
You'll need Visual Studio 2017 on your laptop - to build applications for Win10IoT.
You'll need your Raspberry connected to a TV or HDMI/DVI monitor.
You CAN NOT connect your Raspberry HDMI to your laptop, that does NOT work.
Wed May 30, 2018 9:41 am
Please read through the MS website linked and discover what MS Windows 10 IoT is, as I said before forget about Raspbian this OS is a different beast !!
https://social.msdn.microsoft.com/forum ... WindowsIoT
adieu
abhi143
Wed May 30, 2018 9:50 am
You'll need your Raspberry connected to a TV or HDMI/DVI monitor. You CAN NOT connect your Raspberry HDMI to your laptop, that does NOT work.
feeling very sad because I don't have Desktop HDMI/DVI monitor and TV monitor. That's the reason I am trying to setup headless Pi.
I thought I did setup headless Pi with rasbain so I can do it with windows 10 iot core.
Is there any option to control remotely without buying new monitor ?
Wed May 30, 2018 10:05 am
https://docs.microsoft.com/en-us/window ... adlessmode
Please note you can find everything about W10 IoT Core on their website including support.
adieu
Wed May 30, 2018 12:10 pm
Win10IoT runs a rudimentary website on port 80. I don't know how much control it gives you as I've never looked. DVI monitors and a HDMI to DVI cables are not expensive. You may find a usable monitor at a thrift shop or on Freecycle.
abhi143
Wed May 30, 2018 1:23 pm
Okay I am trying to connect with TV monitor but monitor show no signal on the screen. I don't have HDMI cable monitor
TV --------- VGA cable ---- (VGA to HDMI cable)-------- PI3
Can you help me to connect TV
B.Goode
Wed May 30, 2018 1:32 pm
Just for diagnostic and troubleshooting purposes I would suggest going back to a standard installation of Raspbian Stretch and get your display connected and configured under that accessible and configurable scenario first, and then use the experience gained to reuse the same display with the less flexible Win10IoT.
Wed May 30, 2018 1:40 pm
A HDMi to VGA Cable will NOT work, you need a convertor like:
https://www.amazon.co.uk/dp/B01E8DD6J6/ ... 652835713/
adieu
abhi143
Wed May 30, 2018 2:42 pm
I have tried with Raspbian but the same issue "NO siganal"
abhi143
Wed May 30, 2018 2:45 pm
Thanks guys I appreciate all of your help
@fruitoftheloom exactly I have the same cable in white color
abhi143
Thu May 31, 2018 2:21 am
if windows 10 iot core is installed on raspberry Pi3 and Pi3 is not connected with display. Is it possible to control led connected to Pi.
I am thinking to write C# code on visual studio in laptop. then I have to connect pi remotely to my laptop. I will deploy code on Pi remotely using my laptop. I can get IP address of PI using advanced IP scanner. I don't think i need display because I am using laptop to write the code. so if I don't connect display with monitor that should not be big matter
Is it possible, can I do that ?
Thu May 31, 2018 6:00 am
Did I not provide a link for Headless ????
adieu
Thu May 31, 2018 6:02 am
That is a Convertor not a Cable :shock:
adieu
abhi143
Thu May 31, 2018 6:27 am
[/quote]
Okay I am following the this link to test [*]https://www.c-sharpcorner.com/article/led-on-and-off/
How to ensure that Pi is connected remotely to laptop ?
Thu May 31, 2018 6:32 am
[/quote]
Posting link again:
adieu
abhi143
Thu May 31, 2018 3:07 pm
Posting link again:
I followed this link https://docs.microsoft.com/en-us/window ... device/SSH
I started Putty and entered my Raspberry IP Address. It prompted me login. I typed "Administrator" as my username and default passworwd "[email protected]" . I get access denied.
I even entered New Administrator name and password during setup. They both give me error "Access is denied"
Thu May 31, 2018 3:48 pm
Posting link again:
adieu
Return to “Windows 10 for IoT”
