gwillemsen
DEP6957 error on UWP C# app deployment
Thu May 17, 2018 7:34 am
I am new to the forum, if I do something wrong just tell me pls.
I recently started using a pi zero w for my personal usages. Just tinkering around with it. A few weeks back I started a project on a normal pi. I am of origin a .NET programmer and not a python programmer so when I read about Windows IoT I wanted to try it. After a bit difficult start I managed to get it online. But now when I want to deploy an application from VS it will not deploy however, it will run the app local. The weird thing about this is that I can deploy the demo apps via the IoT dashboard, so there is nothing wrong with the OS it self. When deploying the same application to the same Pi with a friends laptop, it will work too.
Every time I want to deploy the Pi will not respond in any way(no app starting or so). I also tried manually sending over a compiled package of a empty app over the device portal but got the same result as with visual studio. I did got a different error code from the Device Portal which is:
Failure reason: Windows cannot install package <package name> because this package depends on a framework that could not be found. Provide the framework "Microsoft.NET.CoreRuntime.1.1" published by "CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US", with neutral or ARM processor architecture and minimum version 1.1.25915.0, along with this package to install. The frameworks with name "Microsoft.NET.CoreRuntime.1.1" currently installed are: {} Failure text: Package failed updates, dependency or conflict validation. (0x80073cf3)
From time to time Visual Studio will show a error message in the error list but not always, but it will always say the default "There where deployment errors. Continue?" message box. The error I see in the error list is:
DEP6957: Failed to connect to device '<correct ip address>' using Universal Authentication. Please verify the correct remote authentication mode is specified in the project debug settings. MissingMethodException - Method not found: 'Void Microsoft.Tools.Connectivity.RemoteDevice.set_Protocol(TransportProtocol)'. [0x80131513]
I am using a pi 3 model B for this with Visual Studio 2017 Community Edition 15.7.1. The app has target version: 16299 en min version: 15063.
Does anyone has an idea about what is wrong with my visual studio installation?
Re: DEP6957 error on UWP C# app deployment
Thu May 17, 2018 6:00 pm
Not an answer but have you tried Windows IoT Core 10 Insider Preview version 17661 on your RPi 3B ?
RPi 4B 4GB (SSD Boot)..
gwillemsen
Fri May 18, 2018 11:34 am
I just tried it with version 17661. I got no different result than before using visual studio or via the device portal. I also uninstalled VS community and tried Enterprise 2017 15.7.1, got the same result as before.
Fri May 18, 2018 3:13 pm
https://social.msdn.microsoft.com/Forum ... WindowsIoT
If that doesn't answer it, post a new question on that forum.
gwillemsen
Sun May 20, 2018 2:27 pm
The post you send me did not answer it completely but thanks for the suggestion. The post you send was about a fault in the raspi config, this could not be because a friend of mine(like I stated in the first post) could deploy to the raspberry without any problems. I followed this post https://raspberrypi.stackexchange.com/a/82982 that I found earlier. I followed that post from the 2nd step all the with with the "royal stuff up" solution again because after the reinstall I decided to run all solution I could find again and this one was the first I ran. And magically it worked while when I tried it the first time it did not. I have no idea why but maybe it had something to do with reinstalling visual studio. So if anyone has the same problem and cannot find the solution, try this solution:
  • close all visual studios instances
  • shutdown raspberry
  • reinstall visual studio completely if it does not work without reinstall
  • ipconfig /release
  • ipconfig /renew
  • ipconfig /flushdns
Run these 2 in an elevated prompt
  • netsh int ip reset c:\tcp.txt
  • netsh winsock reset
  • start visual studio elevated
  • check the deploy config is set to debug arm and correct remote machine either using find or manually.
  • uncheck the checkbox at Debug-> "Uninstall and then re-install my package. All the information about the application state is deleted."
Build and deploy the app, and in my case it build and deployed successfully.
Maybe a helpful tip too, try settings a pin on the raspi and see if it asks it when it authentication protocol is on Universal if the previous steps still won't work.
