how to run C# code on raspberry Pi 3 using windows 10 iot core
Posted: Sat Apr 28, 2018 7:34 am
by Fan174
I have installed windows 10 iot core on raspberry Pi 3. I want to run c# code on windows 10 iot core. I am confused I don't know how to run C# code on windows 10 iot core using raspberry Pi 3. I think visual studio 2017 will not run on raspberry Pi.
Please someone help me how to run C# code on raspberry Pi 3 using windows 10 ?
Re: how to run C# code on raspberry Pi 3 using windows 10 iot core
Posted: Sat Apr 28, 2018 8:44 am
by markkuk
You write the application using Visual Studio running on a Windows 10 PC, then deploy it to the RPi over network. See: https://docs.microsoft.com/en-us/window ... deployment
Posted: Sat Apr 28, 2018 8:57 am
by Fan174
I have connected led with current limit resistor with pi. I want to turn on/off one led from any PC via web.
Is it possible with vs2017.? I think I have to write code on window PC then deploy on PI, Is it what I need ?
Posted: Sat Apr 28, 2018 9:05 am
by DougieLawson
Go here: https://developer.microsoft.com/en-us/w ... getstarted follow the tutorial pieces for Raspberry Pi on there. You use VS2017 on Windows 10 (on your laptop) to deploy programs in python or C# or C/C++ on your Raspberry Pi running the cut-down Win10 IoT Core (which is NOT in any way like Win10 on a PC).
NOTE: Win10 IoT is still not supported on RPi3B+ hardware.
Posted: Sat Apr 28, 2018 11:51 am
by Fan174
I already saw that tutorials but still I am not clear Do i need to write program on windows PC then I have to deploy on raspberry Pi
but I have installed windows 10 iot core successfully I am using raspberry pi model b v1.2
Posted: Sat Apr 28, 2018 1:05 pm
by ghans
You need to write C# code on an extra computer to deploy it onto the Pi.
You can NOT write C# programs on a Pi running Windows 10 IoT Core itself.
ghans
Posted: Sat Apr 28, 2018 1:45 pm
by Fan174
ghans
That's what I wanted to confirm, I think I got it but not sure. lets suppose I have one PI installed on windows 10 iot core and I have four windows PC. If I am using one of of them to write #c code then my question is that can I use remaining window PC to control device. I want to control the device from any(four windows) PC's
Posted: Sat Apr 28, 2018 2:12 pm
by B.Goode
I think I got it but not sure. lets suppose...
I've got a crazy suggestion...
Why not try it for yourself? It won't cost you anything apart from a little of your time, you will know you can rely on the outcome, and win or lose you will gain a lot of practical experience.
Posted: Sat Apr 28, 2018 2:34 pm
by DougieLawson
That's a more succinct way of saying what I was trying to get across. Get the baby steps done with the Microsoft tutorial. Once that works you'll know your way round VS2017 and the deployment to your Raspberry and you own first project will be a billion times easier. I think that's why they have tutorial, example programs that do banal things like winking an LED.
Posted: Sat Apr 28, 2018 3:49 pm
by Heater
Fan174,
...lets suppose I have one PI installed on windows 10 iot core and I have four windows PC. If I am using one of of them to write #c code then my question is that can I use remaining window PC to control device. I want to control the device from any(four windows) PC's
OK. We have two distinct problems here:
1) How do you develop a program on a Win 10 PC to run on Windows IoT on a Pi?
2) How to communicate with that program, when it's completed, from other PCs?
I guess the tutorials and such linked to above get you started with 1).
For 2) we need more information: How do you want to communicate to the Pi from those other PC? A web interface? Other?
I cannot advise. I would not use Win IoT or C# for such a task.
Posted: Sat Apr 28, 2018 4:27 pm
by bensimmo
Third Problem.
English is not the first language?
What languages do you speak, someone may be able to speak it.
Does a Video help ?
https://www.youtube.com/watch?v=JPRUbGIyODY
Posted: Mon Apr 30, 2018 6:56 am
by Fan174
I got the idea thank you very much for your every help
