emilnachev
Windows 10 IoT Core support for Raspberry Pi 3 Model B+
Wed Apr 04, 2018 10:03 am
Are you sure that Model B+ can work with image from: https://developer.microsoft.com/en-us/w ... getstarted
Re: Windows 10 IoT Core support for Raspberry Pi 3 Model B+
Wed Apr 04, 2018 3:02 pm
You could try the latest Insider Preview version 17133:
https://social.msdn.microsoft.com/Forum ... WindowsIoT
RPi 4B 4GB (SSD Boot)..
rdelfin
Fri May 04, 2018 2:34 am
There's a workaround to get the RPi 3 B+ to boot Windows 10 IoT. The wifi seems to not have any drivers yet, but bluetooth dongles still work. Link below:
nayebifar
Mon May 07, 2018 6:05 am
I tried to run it on RPi3B+. Nothing comes up. Also, the insider preview version does not work.
I tried to do the workout link (https://social.msdn.microsoft.com/Forum ... WindowsIoT), but, it is confusing and doesn't worth it.
We may need to get RPi 3 (non +) or wait 3 months.
Bison_Lord
Fri May 11, 2018 9:00 pm
I just jumped into raspberry Pi, been coding in C#, was bummed to find out IoT wasn't supported for the 3B+.
If you scroll to the bottom:
[There will be a public preview for Raspberry Pi 3 Model B+ soon
if nothing unforeseen occurs may be later this month
br
Andre
Edited by Andre MarschalekMVP, Moderator Thursday, May 10, 2018 4:29 PM
Looks like there is hope for the end of this month though!
Sat May 12, 2018 7:48 pm
br
Andre
Have you tried the latest Insider Preview Release ??
The release notes rarely keep up, currently version 17661
Last edited by fruitoftheloom on Tue May 29, 2018 6:07 am, edited 1 time in total.
Bison_Lord
Mon May 14, 2018 3:40 pm
No, I’ll be honest, I’m a complete newb. I’m hoping the release they talk about is newb friendly?
I did try to get it to work in the end of april, just following the Microsoft guide for starting out, and it didn’t work.
Took me about 2-3 weeks to figure out that IoT wasn’t supported yet. I have not tried to get it working using the workarounds posted in a couple of those topics.
Is the insider preview something I should look at?
Mon May 14, 2018 4:07 pm
The Insider Preview is basically a Testing Branch, you will need a Microsoft Account !
daniel_yepez
Mon May 28, 2018 10:49 pm
Any news about this issue? I have a raspberry pi3 b+ and windows 10 IOT wont work!
Tue May 29, 2018 5:47 am
Ask Microsoft as it is their Software, though they recently released Insider Preview version 17672 which may be worth a try ??
thadp
Sun Jun 03, 2018 9:16 pm
I also have recently purchased a Pi 3 + and have spent hours googling and trying this method and that method, i took a small victory dance after getting the 10 loT core installed and booting. I have a starter kit that came with a display so i can see that it booted up. Hooked up a keyboard and mouse to the usb. VERY impressed with how nice this all worked until.... they key component i need... doesn't work. It does not see the ethernet. I must have a rj45 connection, it must be on a network or none of this means anything :(.
I have scoured across the internet and reached the end of my rope. My next step is to try the pi 3 (without the +) and see if that works.
I was sooo excited that i got my loT core license and could start building on this device but i am stuck now :(
Fri Jun 08, 2018 8:07 pm
RPi 3B+ needs Insider Preview 17661
https://www.hackster.io/JiongShi/window ... l-b-92b1a3
Guusbuss
Tue Jul 24, 2018 6:33 am
Insider Preview version 17133: will not work without a bit of tweaking (Pi 3 B+).
Follow these steps to get it to boot;
Still trying to fix the Lan issue.
Doesn't detect at all.
Anyone had any luck?
priyanand
Sat Apr 27, 2019 10:00 am
i have recently purchased raspberry pi3 B+ and not able to install win10 iot on it....it can't boot on it...other os like raspbian, emteria work fine with it...but win10 iot latest version not boot on it...kindly make a video how to solve this issue....
B.Goode
Sat Apr 27, 2019 11:57 am
Welcome to the Raspberry Pi forums.
Maybe your comments should be addressed to Microsoft, whose Operating System you wish to use: https://docs.microsoft.com/en-us/window ... /downloads
Sat Apr 27, 2019 12:18 pm
You need to have a Microsoft Account and use the Insider Preview Release version 17744 which I stated above :shock:
https://docs.microsoft.com/en-us/window ... ider/17744
https://social.msdn.microsoft.com/forum ... WindowsIoT
patrickw
Tue Jul 09, 2019 5:54 pm
Since the last reply was a few months ago, I wanted to say I have a RPi 3b+ running Windows IoT Core.
Known Issues:
  • WiFi and BLE are not working with these steps (Ethernet does work)
I used the IoT Core Dashboard: https://docs.microsoft.com/en-us/window ... /downloads
I downloaded the 17661 preview build (.iso) from here: https://www.microsoft.com/en-us/softwar ... windowsiot
I used 7zip to extract the .iso file.
I used 7zip to extract the .msi file within the new folder.
Then using the IoT Core Dashboard, in "Setting up a new device", specify a custom OS build by selecting the Windows_10_IoT_Core_RPi3B+.ffu file from the new folder created by extracting the .msi.
I did not realize at first those extraction steps were needed. They are are not documented. Once I got past that, my RPi 3b+ booted up. It does take a few minutes the first go round.
I hope this helps...
Sun Jul 28, 2019 5:48 am
Known Issues:
https://devblogs.microsoft.com/premier- ... rry-pi-3b/
