Agentatechie
Win10 IoT direct UART access on Pi3 without using USB-TTL adapter
Mon Sep 11, 2017 9:58 am
Has anyone used Windows IoT to directly use the TTL UART pins on the Raspberry Pi3 (direct microcontroller to Pi3 without using a USB-TTL adapter)?
Came across the below extract from: https://developer.microsoft.com/en-us/w ... serialuart
which makes me think that the RPi3 drivers might not support it (yet???)
The code for this sample uses the Windows.Devices.SerialCommunication namespace.
The SerialDevice class will be used to enumerate, connect, read, and write to the serial devices connected to the device.
NOTE: The SerialDevice class can be used only for supported USB-to-TTL devices (on PC, Raspberry Pi 2 or 3, and MinnowBoard Max) and the on-board UART (on MinnowBoard Max).
Re: Win10 IoT direct UART access on Pi3 without using USB-TTL adapter
Mon Sep 11, 2017 11:12 am
May be prudent to also ask on the MSDN Forum for their Operating System:
https://social.msdn.microsoft.com/forum ... WindowsIoT
Adieu
Agentatechie
Tue Sep 12, 2017 10:00 pm
Already done that and got a good response from Andre. Pointed me to another document which explains using the UART pins (8,10) directly - so looks like it does work.
Who is online
Users browsing this forum: No registered users and 2 guests
