Ken76
Windows 10 IOT app on an Raspberry PI 3 device and bluetooth
Mon May 22, 2017 9:24 am
Is it possible to run Windows 10 IOT app on an Raspberry PI 3 device with bluetooth from another computer?
Gisgar3
Re: Windows 10 IOT app on an Raspberry PI 3 device and bluet
Wed Jun 28, 2017 6:31 pm
I do not think this is possible, but you can use a remote connection from an IDE (mainly Visual Studio.) If your app was made using Visual Studio, you can change the debug processor to "ARM" and the start device to "Remote Machine." You will need to use your Raspberry Pi's I.P address to fully connect.
ennisarlu
Re: Windows 10 IOT app on an Raspberry PI 3 device and bluetooth
Thu Nov 16, 2017 5:52 am
Kindly check if Bluetooth Support Service is started or not. Follow these steps and check if the Bluetooth Support Service is started.
a. Press Windows Key + R, type services.msc, hit Enter.
b. Right click on the service named-Bluetooth Support Service.
c. Check if it is started, if not click on Start and close to check.
Let us know the status of the issue to assist you further.
Return to “Windows 10 for IoT”
